Question about JVC AV-48WP30 48" Rear Projection Television
Red lines and shadows, convergence wont work
I tried adjusting convergence, just trying to keep from having to call a repairman as I know it costs.
How can I fix startiing with access to the boards.
  • Anonymous Mar 28, 2009
    Red shadows and magic focus will not work
  • JVC Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
77eRed lines and shadows, convergence wont work - f0900cb.jpglass=
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergenRed lines and shadows, convergence wont work - 2c07611.pnge bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
578ba6c.jpg Red lines and shadows, convergence wont work - 2c07611.pngef="http://www.fixya.com/support/t497723-colors_dont_line_up#" >TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 29, 2009
    President:
  • 3,130 Answers
You can go to tvrepairkits.com and get everything you need for this TV including pictorial instructions and if you hit a snag there is free live on-line tech assistance with a kit purchase in case you hit a snag with the repair
Posted on Jun 18, 2009
    Scholar:
  • 90 Answers
Go in and find the conv ICs, they will be mounted on a big heatsink and the wires going to the conv yokes will most likely plug in somewhere closeby.
Conv ICs are the workhorse of the CRT RPTV, and it is not unusual at all for them to need to be changed out at some time in the life of a CRT RPTV.
Mr Bob
Posted on Feb 04, 2008
  • Robert Jones
    Robert Jones Feb 04, 2008
    PS -
    The wires for the conv yokes at the CRT necks are the thin ones. The thicker ones are for the hor and vert sweeps, which must never be disconnected from their circuitry during
    CRT operation.
    If your beam loses sweep on any of the CRTs, it will instantly score/gouge your phosphors on your CRT faces, vaporizing the phosphors there and ruining the CRTs. The beam is very powerful, but in normal operation moves incredibly fast, not damaging anything. Any slowdown of the movement of the very powerful beam that draws the picture, acts like the searing vaporizing beam in Tom Cruise's War of the Worlds.
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
Convergence is out...trying to manually adjust but only have blue and green lines....no red...how can i fix this?
Tv have 100% convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 22, 2010 | JVC AV-56WP74 56" Rear Projection...
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
Model 50UX58K - picture has distortion & shadow on right side of screen
Hi, if the shadow is colored lines then you probably need the convergence ICs and possible reisitors near them replaced .
If the shadows is just like a ghost of the image or a bar from top to bottom, then check if it does it on every input (dvd for example) , there are blanking bars that you can't see past the edges of the picture and when you have a bad cable signal you can see the ghost of the blanking bar sometimes. if it does it does not show the shadow when watching a DVD then its a signal issue with your cable/satelitte .
If your convergence is the issue, try the adjustments first and if that doesn't correct it, you can replace the ICs using kit # x480293 or stk392-110 (2 ICs) soldered in very technical for even a technician.
repairman cost about $250-$350
hope this helps
Eric
Sep 01, 2009 | Hitachi 50UX58K 50" Rear Projection...
Red shadow
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 22, 2009 | Mitsubishi WS48511 48" Rear Projection...
Shadowed colors inpicture
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Mar 12, 2009 | Hitachi 46F500 46" Rear Projection...
Convergence On Panasonic PT-47WX54j
You dont need codes for the service menu you need to repair the convergence circuit. If the lines wont line up in the customer menu they wont line up in the service menu either. Do you know how to solder? If so we can fix this yourself with a little instruction. Otherwise you will need to call a repairman. A good repairman will run you $300-$500 depending on your area. Let me know what you want to do.
Tim Nolan
Sep 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Sony kp57ws510
you need to replace both convergence ICs they are STK392-560 and you will also need a couple 3.5amp pico fuses and a couple 4.7 ohm 1/2watt resistors. You can get replacement parts at the following link and they provide free instalation instructions and free online tech support to help you with the instalation process. Heres the link.
http://servicemanuals.vstore.ca/
Aug 07, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Red sideways hourglass
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Jul 20, 2008 | Philips 60PW9363 60" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
449 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
