Question about Kodak EasyShare C875 Digital Camera
Kodak C875 memory card
I have a Kodak c875 and it does not matter what kind of memory card (SD card) I put in it, it won't work. It keeps telling me to format it and I do and It still won't work. I have bought two brand new cards and they won't work either. I can only hold pictures in internal memory, which sucks!!! Help please!!!
  • Anonymous Jul 01, 2008
    My camera has the same problem.  I already took some pics with the camera before that error, so now I'm worried if I format the card it will erase everything.  My card won't work in other cameras either.
    Sniper:
  • 58 Answers
If the cards your using are 2gb or less and it loops on the formatting msg, the cam needs to be serviced
if you're using more than 2, it's really not gonna work with more than 2 as it's not sdhc ready
Posted on Feb 13, 2008
My Kodak C875 digital camera says internal memory full how can I fix it
Do you have the optional sd memory card instaleld in the camera?
Have you formated the sd memory card or MMC card as suggested on page 37 of the user manual.
on page 36 on image storage settings = If set on Auto it uses the external card if there is one installed rather than the internal memory.
You need to have a memory card installed in the camera !
see page 5 of the user manual.
http://resources.kodak.com/support/pdf/en/manuals/urg00594/C875_GLB_en.pdf
Jan 03, 2015 | Kodak EasyShare C875 Digital Camera
Sandisk sdhc card
The C875 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Jun 10, 2012 | Kodak EasyShare C875 Digital Camera
What memory card can i put in my easyshare c875 kodak
The C875 works with MMC and SD cards. MMC cards are going obsolete, so you'll probably not be able to find many of them. When getting an SD card, make sure it's not an SDHC card. SD cards top out at 2GB while SDHC cards start at 4GB and go up from there. SDHC cards will not work in the C875.
Aug 29, 2011 | Kodak EasyShare C875 Digital Camera
I cannot format a new 4 GB memory card on my Kodak Easyshare C875
The C875 works with MMC and SD cards. Your new 4GB card is actually an SDHC card. While it fits into the slot it is electronically incompatible and will not work. You need to use SD cards, which max out at 2GB.
Aug 09, 2011 | Kodak Cameras
New kodak easy share c85 put in scan disk 8gb cannot format
The C875 works with MMC and SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to stay with cards 2GB and smaller.
Apr 19, 2011 | Kodak EasyShare C875 Digital Camera
I bought a 8GB SDHC memory card for my camera, when i insert it into my camera it tells me that the card needs formatting when i select format it doesn't do anything it just reasks me. How do i get it to...
The C875 works with SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and won't work. You need to go with SD cards, 2GB and smaller.
Nov 24, 2010 | Kodak EasyShare C875 Digital Camera
Memory card compatibility. camera won't read or
The C875 works with SD and MMC cards, which max out at 2GB. It will not work with larger SDHC cards.
May 14, 2010 | Kodak EasyShare C875 Digital Camera
My C875 Kodak Camera will not read the memory card, but it will read the internal memory
make sure that the internal memory is sets on Auto, for you to check that first...
-Press menu button and look for setup then press Ok button
-Under setup look for IMAGE STORAGE it should be on auto if its Internal memory you need to select the image storage press ok button the select Auto then press Ok button again.
-make sure the Memory card that you are using is just 1GB or 2GB SD card only do not go over than that because it will not be compatible on the camera C875
GudluCK!
Nov 03, 2009 | Kodak EasyShare C875 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
782 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
