Question about Epson Stylus Photo R200 InkJet Printer
Epson r 200
Changed ink and now lights keeps flashing
  • tommytaz Feb 05, 2008
    thanks m8 not worked but appreciate any help at all
    Problem Solver:
  • 5 Answers
Try turning printer off for 5 minutes, then turning it back on.
swampduck
Posted on Feb 05, 2008
Epson stylus sx115
Hi, there is a possibility that the ink cartridges that you installed are not recognized properly. As a solution for that, try reseating the affected cartridges. You may also ask your vendor if they can replace the cartridges. Upon trying a different cartridges and issue persists, please contact Epson to process the warranty for your printer or ask a nearest service center in your area.
Nov 16, 2011 | Epson Office Equipment & Supplies
Epson Stylus C66 PRINTER KEEPS ON FLASHING RED LIGHTS ON THE INK BUTTON AND PAPER BUTTON
Check the status monitor on the PC, this will tell you the error. If service error it need the wast ink pad counter resetting
Mar 13, 2010 | Epson Stylus R265 InkJet Photo Printer
Epson 2400 paper red light and ink red light
It sounds like your printer has reached what is often called the "service required" stage...
To solve this you need to handle two things.
1. Get the printer protection counter (or waste-ink as it's sometimes called) reset.
2. Replace the waste ink pads OR redirect your waste ink flow to an external tank
It's important to note that Epson will encourage you to do a waste pad replacement through one of their service centers, but if you're out of warranty this will cost a significant amount of money (approx: $100 - 200)
To solve these as a DIY you can do the following:
1. Resetting the counter...
Get a resetter, either the SSC utility (google: epson SSC utility) or the IPR utility that Epson have now made available via their website here
The latter is only available to North American printer owners so the SSC is a safer bet.
2. Redirecting waste ink to an external container.
This is something I'd heartily recommend instead of trying to change the waste pads yourself... It's simple enough to do and a little googling using keywords "Epson R2400 waste ink tank" should get you all the info you need.
There are simple kits available that offer everything you need or you can easily go for a DIY with bits you have to hand.
Hope that helps...
Mar 07, 2009 | Epson Stylus Photo R2400 InkJet Printer
Epson stylus c66
The Waste Ink Pads are saturated and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the red lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
The C64/66 service manual can be downloaded from here:
http://www.eserviceinfo.com/downloadsm/12748/Epson_C64%20and%20C84.html
Should you decide to have a go at changing the waste ink pads, let me know and I can supply some notes on opening the case - it's a pig and the service manual is not that helpful.
Oct 22, 2008 | Epson Stylus C66 Inkjet Printer
Epsomc44ux red and green light fashing does nothing
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C44 Service Manual". You will often find them for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40,42,44,60,62 service manuals, as far as ink pad replacement goes, they are the same.
Oct 16, 2008 | Epson Stylus C44UX InkJet Printer
Epson stylus c45 (Problem)
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C45 Service Manual". You will often find them
Jun 14, 2008 | Epson Stylus C46 InkJet Printer
Repairing
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson stylus c66
If your having an error that says "Parts inside the printer are at the end of there Service life" it means that you ink pad is full/ what you can do is change your ink pad and then download an ink pad reset utility so that you can reset the settings/ Make sure to change ink pad before you reset it becuase ink will leak if you don't change it. For the flashing lights, try to check for obstructions inside the printer if not, make sure that ink clicked in and the cover for the tray is closed
Mar 27, 2007 | Epson Stylus C66 Inkjet Printer
Epson Stylus Photo R200 InkJet Printer Logo
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
