Question about Panasonic SC-HT830V System
No Display 20JF20...panasonic ht830v.I have the same problem everyone else is having. NO Display. Seems the pc board is NLA from panasonic. Please help. There has to be a replacement.
  • 3 more comments
  • shailb Jul 12, 2008
    Same problem here since last 3 days...unit just 2 years old. First the disc trays stopped working, had them replaced and now no display although unit works fine...can someone please help with suggested resolution...
  • grshoppa Oct 25, 2008
    I have the same problem but can not seem to locate the part anywhere. Panasonic says no longer available. There has to be somebody that has one
  • no83 Nov 22, 2008
    Same problem. Lightly used product for three years. Display just kicked it today.
    Sounds like this is widespread. Unacceptable. Panasonic needs to make this right.
  • hellsflare Nov 28, 2008
    I have the same problem to please ! help ! some one.Do not want to throw it away!!!
  • gayethiri May 11, 2009
    We have the same problem.No display in the front panel even the power light does not show up ..but the system is working.Did anybody find any solution.Please let us know.If LED is not working how can we fix it.Our model is SC HT833V.
  • 23 Answers
Could be an easy fix. Try shorting across this fuse protector IP1280 (looks like a resistor) on the power board. See more detailed solution I posted in this forum for a similar question.No Display - 4a63623.jpg
Posted on Jun 06, 2010
  • 2 more comments
  • shitforbr782
    shitforbr782 Aug 24, 2010
    I've jumpered the fuse protector IP1280...it is a yellow resistor looking thing...and, IT WORKS!!! The display functions normally. Now, the next question...is it okay to leave it jumpered? Could I just solder the jump and not have a fuse protector there at all and be okay?
  • mhueffman
    mhueffman Feb 18, 2012
    I jumped the IP1280 as well and display is now working again. Not sure if it is OK to leave like this or not? Just twisted it until the two wires made contact.
  • mhueffman
    PS, the actual display board itself looked like something shorted out as it looked burnt under the display. not sure what caused this but guess the fuse protector did it's job?
  • John Feb 19, 2012
    That is normal. The display is a vacuum tube. The 'getter' to remove impurities. Same reason vacuum tubes have mirrored glass on the top.
This is what my display board looked like, thought the problem was here but jumping the fuse protector on the back as already posted solved the problem. Any ideas what might have caused this? Power surge??? All other appliances are fine, no recent power outages here.
Posted on Feb 18, 2012
  • John Feb 19, 2012
    That is normal, the display s a vacuum tube. All tubes have a "getter" to remove impurities. It is why tubes have mirror appearance on top.
Panasonic sc-ht830v \r\n I could not find a fuse
for as long as they have the same ampere rating that won't cause a problem
Jun 07, 2010 | Panasonic SC-HT830V System
SC HT830V PANASONIC DISPLAY LIGHT DONT COME ON BUT EVERYTHING ELSE WORKS
Try shorting across this fuse protector (looks like a resistor) on the power board. See more detailed solution in this forum for a similar question.4a63623.jpg
May 19, 2010 | Panasonic SC-HT830V System
PANASONIC SA-HT830V EVERYTHING SEEMS TO WORK
Try shorting across this fuse protector IP1280 (looks like a resistor) on the power board. See more detailed solution I posted in this forum for a similar question.4a63623.jpg
May 18, 2010 | Panasonic SC-HT830V System
ANY IDEA WHERE I CAN GET A VEPV0037A PART FOR MY PANASONIC SYSTEM
May be the grid power to the display. Try shorting across this fuse protector IP1280 (looks like a resistor) on the power board. See more detailed solution I posted in this forum for a similar question.4a63623.jpg
Nov 02, 2009 | Panasonic SC-HT830V System
Where can I get a vepv0037a display board
It may not be needed. Try shorting across this fuse protector IP1280 (looks like a resistor) on the power board. See more detailed solution I posted in this forum for a similar question.4a63623.jpg
Sep 26, 2009 | Panasonic SC-HT830V System
No display
Sep 05, 2009 | Panasonic SC-HT830V System
VEPV0037A display board
Try this. Try shorting across this fuse protector IP1280 (looks like a resistor) on the power board. See more detailed solution I posted in this forum for a similar question.4a63623.jpg
Jun 27, 2008 | Panasonic SC-HT830V System
SC-HT830V connect to cable box Explorer 8000HD
1-connect your cable plug to(rf in)in your panasonic home unit.
2-press up and down arrow and select(antenna setting)and press enter.3- go to cable tv and select it.
Feb 17, 2008 | Panasonic SC-HT830V System
Need Help
This is a major defect in the SA-HT830V dual deck that Panasonic did not honor! I've had two of these and the full lighted display blew out on both of them and one music channel does not work on the dvd player anymore. Piece of junk and I'm very upset with Panasonic for not helping/supporting their products!
Oct 20, 2007 | Panasonic Audio Players & Recorders
Panasonic SC-HT830V System Logo
521 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
