Question about Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum
My vacum will not start
Discovered a shirt under my son's bed via the vacuum cleaner. Part of the shirt go wraped around the bristles. I shut the vacuum off removed the shirt but now it won't turn on. Please advise and thank you.
  • 46 Answers
Replace the fuse in the plug
Posted on Feb 09, 2008
When do you replace the brush on a vacuum cleaner
Replace when the bristles are worn or frayed or if they are not stiff. To check the length of the bristles, make sure your vacuum is unplugged, lay it upside down and lay a card or straight edge across the bottom plate to see how much bristle sticks out. If it's even the the bottom plate it's time to replace it.
Feb 20, 2015 | Vacuums
The bristles will not turn when vacume is on and I try to vacume
Alot of those vaccums have a little drive belt on them. You might look for that. Also some string might be caught on the side of the brushes.
Sep 13, 2014 | Vacuums
How do i change the belt on the dirt devil vacume cleaner
Hi there! Below are steps to replacing the belt on your vacuum. I have also included a link to the instruction manual which has illustrations if needed.
1. Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips screwdriver to remove the four (4) screws. Arrows show location of screws.
2. Lift nozzle guard off.
3. Slide belt off motor shaft.
4. Lift and remove brushroll. Dispose of old belt.
5. Place new belt in area of brushroll without bristles.
6. Slide belt onto motorshaft.
7. With new belt in place, pull and slide brushroll into nozzle making sure that the brushroll end caps are in the correct orientation. Rotate brushroll manually to make sure belt is properly aligned.
8. Reattach nozzle guard.
9. Secure by aligning the three (3) tabs in the base slots. Be sure to replace all four (4) screws.
http://bit.ly/1s8GQSX
Hope this helps!
Jul 27, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Vacuum not picking up
Try plugging the hose that goes to brake booster and see if the noise stops couse it seems to me it has a leak..if not spray carb cleaner around the vacume hoses while it is running and where the leak is will couse the idle to go down..
May 10, 2013 | Vacuums
I have a Lux Floor Pro Heavy Duty carpet cleaner. Whis attachments (scrubbers) do I attach to the bottom to wash a non-plush carpet. I have three attachments that have hard bristles and three that have...
NEVER USE THE HARD BRUSHES ON CARPET ! You can burn up your motor, break the drive belt,or strip the drive gears The black bristle brushes are for all carpet types.
The hard bristle brushes are made for hardwood and other smooth surfaces.
Oct 24, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Fuse auto shut off
Find the current rating for the vacuum cleaner motor (on a plate somewhere on the machine). Is it somewhat less than the breaker rating in the panel? If so, then either the motor is overloading the breaker due to bad bearings or a shorted winding in the motor or the breaker is failing. Check the current draw of the running motor with a clamp-on ammeter (a friend with one or an electrician). It should be close to the rating on the plate. If in excess, then the motor needs to be repaired or replaced. The motor normally works harder when it is pulling full vacuum--it speeds up if the air flow is plugged.
Sep 08, 2009 | Hoover S5620 Vacuum
I neen parts for a wap vacum cleaner and bags
Here's an amazing thing about FixYa... help via the UK!
Go to www.transplant.co.za and have a look on their "Contact Us" page.  You will find an email address and also two South Africa phone numbers.  They are Wap/Alto agents and will undoubtedly be able to help.
Helpful?  I value your feedback, so please rate me!
Apr 20, 2009 | Vacuums
I am trying to put a belt on my Kirby Classic vacum cleaner i just can't figure it out.
HERE is the belt installation instruction. On your vacuum it is a bit different how the brush roll is installed but I am sure you will be able to figure this out. Adjust screws on the both ends of the brush roll to have bristles sticking out by about 1/8 of the inch.
HERE is also a video on belt installation but the one with pictures is more in depth.
Good Luck
Jan 24, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I have a dirt devil that is only 2 years old, I used it and sparks began to shoot out from the front grill area. I called dirt devil's corporate office at 12noon today July 25th, and was told that with out...
The sparks may be from the carbon brushes in the motor. Bagless vacuums do not filter dirt out as well as a bag does so dirt and grit gets sucked into the motor. Filters should be cleaned frequently and replaced at least once a year. If the filter gets clogged the motor can overheat. If you got two years out of a $39 vacuum you did well. Many people are lucky to get a year.
Mar 24, 2017 | Dirt Devil Vacuums
Kirby G6 drive mode
look under the vacume cleaner and take off the cover make, shure the belt is where it needs to be, you should have a setting on the vacume cleaner that gives you an addjustment for the carpet your on, raze it up.
Nov 26, 2007 | Kirby G6 Bagged Upright Vacuum
Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum Logo
203 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
