Unable to get a sky picture on tv after connecting philips wireless tv link slv3220 to sky box and tv into piggy back scart. friend has tried this with same unit and no problems
    Problem Solver:
  • 40 Answers
Swap out the sky box and see if that helps...or take your box to your friends house and see if it works there..........
Posted on Feb 03, 2008
I cant get dvd recorder to record ext 2
Firstly, is the scart lead plugged in fully? Does it get the sound or nothing?
Is the recorder sitched to the correct input? It may be trying to pull a signal from the TV which may not be passing through the picture from the sky box.
Also, is the scart lead fully wired? Some only work one way so try spinning it round between the recorder and sky box.
Nov 24, 2011 | Philips DVDR70 DVD Recorder
New toshiba tv connect to sky plus box and perfect picture but no sound
The first thing to do is check the connections between the Sky box and the TV. If you are using a SCART cable, it's possible that one of the pins in the SCART plugs has bent or become detached from the wire inside. If you have another SCART cable from a VCR or DVD player, try switching them over.
If this doesn't work, or if you are using another connection method between the Sky box and the TV, please post back and I will try to assist you further.
Regards,
BElectric
Nov 29, 2010 | Toshiba Televison & Video
When i plug my new tv into the sky box via a scart, the tv picture is distorted and a major buzzing noise is coming from the tv. sky have checked and said the box is fine. when u connect to another tv it...
Have you tried another scart lead? Also tried all of the tv scart sockets? Don't try and cure this by using an expensive upmarket scart lead, you'll just be wasting your money. The cheapest leads work just as well when the function correctly.
You could also try reversing your current lead by swapping the tv end to the Sky box and vice-versa, as there are many leads which cause feedback issues, and also a lot of "cut" leads (designed to prevent feedback looping) which must be fitted the correct way around. A "cut" lead is one where the wire to pin 19 at the tv end and to pin 20 at the video/Sky box end has been cut.
Note that scart leads MUST be fitted with the tv and Sky box switched off to avoid damage. Most people (including professional installers) regularly ignore this precaution though.
If all else fails then take the tv back and exchange it under the Sale of Goods Act; it's certainly not uncommon for new tv's to have faulty scart sockets.
If I've solved your problem then please take a moment to rate my answer. If not, then please report back with the make and model of TV and I'll try a more specific answer.
Jan 14, 2010 | Televison & Video
Hi, i have just bought a logik wireless av sender so send my sky signal to the tv in the bedroom. the instructions in the manual are very basic and i cant get it to work. any ideas. on the tv in the...
Red and white are only Audio ports.
IF there is a scart port plug your av receiver into the scart. Take note on which number your on ie channel there should be several numbers you can choose on your tx/rx then go down stairs to your sky box and ensuring that you are on the same number as the one upstairs.
Then just plug it into the back of your sky Box.. the number on your sender are incase your getting interfearance from other sources in the home. have a play with this and see what works best
Hope this Helps
Little Dish Fitter
Aug 22, 2009 | Televison & Video
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
Hi I have just set up
Ok, have solved it!
I hadn't placed the "magic eye" in the right position on the Sky digi box.
Now have Sky in my kitchen, a good picture, sound and the remote works great!
Mar 20, 2008 | Philips Televison & Video
WIRELESS LINK FOR SKY+ BOX
your sky box should have 2 scarts ;input and tv.I have one so as can watch sky upstairs and on projector screen.
reciever sender is in av on tv upstairs sender downstairs is in scart next to tv scart on skybox scart lead in tv scart connected to av on tv.some senders need to be turned on.when you plug in adapter and led is on doesnt necessarily mean sender is on .is this a new sender with instructions youve bought
Jan 01, 2008 | Acer TravelMate 2300 Notebook
TV, Sky, DVDR, VCR + Wii connection
i cant see any problem with the connections. have you tried to connect the dvdr along with sky to another tv set? and did the same problem occured? if not, try connecting it the same way with another tv. and see if thesame problem would occur. if the same problem appears check if the connections from sky to dvdr scart if it is loose or not. try to clean the solid wire of the cable. if proble still persists dvdr is faulty. if not, defenitely there is a problem with the tv. and i suggest for you to have it checked.
Oct 06, 2007 | Televison & Video
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
