Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
MFC-440CN: Prints but does not scan
My MFC-440CN is connected to the network. I can print from any station but cannot scan, either from control panel or network station. Fault given at Control Panel is "Check Connection." Fault given from Vista Control panel when Test Scanner selected is "Test failed because device is not available. Verify connection and try again." The other control panel functions 'see' the device and report the correct IP.
  • 1 more comment
  • Anonymous Feb 09, 2008
    How do I scan? I do not have my manual to verify if my connections are correct.
  • misha69 Sep 24, 2008
    yep, same issue here. We're all mac. Can anyone help?
  • Anonymous Jan 26, 2009
    I get the same "check connection" error in the printer display as well - I updated the firmware and am on Mac OSX 10.5.2
Go to system/computer control panel, select "scanners and cameras". you should see your brother system in there (if u were able to print to it but not scan). Right click on it, select properties, and select "Network Properties" Tab. Choose select "specify your machine by address" rather by "by name". Most home/home office users dont have a local domain server at home, so even though your printer was named, it cannot be located by tcp-ip using the name, but rather by ipaddress. This solves the issue.
Posted on Mar 07, 2010
I had the same problem with my scan feature. While I don't have an absolute solution, I simply went into the Brother ControlCenter and used the scan feature in the program instead of the scan feature located on the machine. The ControlCenter is located in the Brother LAN folder if you used the default setup.
I hope this helps!!!
Posted on Jan 30, 2009
  • 832 Answers
You might find an answer here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc440cn_all&Cat=8
Posted on Feb 03, 2008
    New Friend:
I fought with this issue four days before I spoke to an excellent tech at brother phone support. I have a DCP-9040CN on a wired network with multiple PCs running a variety of Windows operating systems. All the PCs can print to the Brother but cannot scan or copy.
Here is the 100% solution:
1. Run the twain reset utility at http://support.visioneer.com/utilities/twain_reset.exe
2. Next, there is a registry key that blocks network scanning. Open regedit and check the following key HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Brother\ControlCenter\3.0\DCP-9040CN LAN\DeviceInfo\"EnableScan"=dword:00000001
If this key is set to "0", you will never be able to scan or copy through the network even though you have the ability to print.
That's all there is to it. You may even be able to skip the twain reset and get by with only step number two.
Posted on Dec 12, 2013
Brother MFC-440CN - print quality terrible, almost non-existent in spite of many cleaning operations.
It sounds like the printhead needs to be replaced. Brother may cover the cost of repair if you call them at 877-276-8437 and tell them the prints are "missing black ink". Very common problem that a new printhead should fix.
Oct 08, 2012 | Brother MFC-440CN InkJet Printer
MFC 440cn anything i try to print the machine is working but nothing prints out on the page
Is this a new printer, check that the ink cartridges are fresh, could have dried up. Also if you just installed cartridges, check that the protective tape is off of it.
May 03, 2011 | Brother MultiFunction Center MFC-440CN...
How do I network brother mfc-440cn printer - what
  1. Plug the printer into a computer on your network.
  2. This computer must be on and remain on for the printer to work.
  3. Add this local printer to this computer in "Control Panel" - "Printers".
  4. Now share the printer.
  5. Go to another computer on your network.
  6. Add this printer (as a network printer) to this computer in "Control Panel" - "Printers".
  7. The system should find the printer and add it...
Nov 15, 2009 | Brother MFC 420CN All-In-One InkJet...
NO CONNECTION (LAN) on Brother MFC-440CN
I had the SAME problem. I have 3 pc laptops and 1 Mac. The Mac could still print, but the pc's were hosed. I called BrotherUSA and this fixed the problem!
Go to your printer and after making sure it's connected to the network with the Ethernet cable, go to Menu > Print Reports > Network Config. This will print a page that shows your printer's IP address. We need to config that address in your Printer, Fax and Scanner settings in Control Panel.
Go to Control Panel > Printers & Faxes. Right click on your printer > Properties > Ports tab. Click Add Port and select Standard TCP/IP Port. Click New Port and click Next on the wizard. Enter the IP address of your printer in the first field (the second one will auto-fill). Click Next and Finish. Printer's done!
Right click on your PC-FAX in Printers & Faxes and Properties. Click on the ports tab and just check the box that you just created for Standard TCP/IP Port. Click OK. Fax is done!
Go back to Control Panel and select Scanners & Cameras. Right click on your printer/scanner > Properties > Network Setting tab. Select the Specify your machine by address radio button and, if it's not already in there, enter the IP address of your printer. Click OK. Scanner's done!
This will work as long as your router is running. You may need to repeat this process after a power outage or if you need to reboot your wireless router. Not too bad, though! I just wish everything was as easy as a Mac!!!
Jun 25, 2009 | Brother MultiFunction Center MFC-440CN...
Connecting my Brother MFC 440cn printer to the internet
It turns out my dad had the usb cable plugged into the ethernet port instead of the usb port. It works fine now.
Thanks for the response.
Oct 26, 2008 | Computers & Internet
MFC-440CN
GO TO CONTROL PANEL SELECT PRINTERS AND OTHER HARDWARE AND UNDER PICK A TASK (WINDOWS XP SELECT VIEW INSTALLED PRINTERS
THEN UNDER THE FILE DROP DOWN MENU SELECT printing preferences THEN OPEN TAB THAT SAYS QUALITY AND SELECT BLACK AND WHITE THEN SAVE SETTING AND YOURE DONE
Jan 14, 2008 | Office Equipment & Supplies
Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Sep 27, 2007 | Brother MultiFunction Center MFC-440CN...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
7,622 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
