Medallion Vermont Casting model CF9080
The burners on my grill do not come to full strength. I replaced the gas tank with a newly filled tank. Since I was having pressure issues, I had the attendant purge air from the tank while he filled it. With 3 of 5 burners lite the flames struggled to stay lite. The temperature stopped at 250 degree after 30 minutes. When I light the side burner it pulls gas from the other burners to a point where they almost extinguish themselves. I can't see an clogged lines. The outside temperature is 40 degrees. Could the regulator be an issue? What else should I do? Thanks, Harcourt
  • 625 Answers
Sounds like the regulator. there isn't much of anything left to go wrong! the gas comes out of a very small orifice in the burner tube and mixes with atmospheric air before being burned at the jet.
Posted on Feb 03, 2008
Replacing ignitor electrodes on vermont castings grill
They are screwed in, you need to remove the screws and they slide out
Jun 26, 2013 | Vermont Casting VM450SSP Grill
I have a Vermont Casting VM450SSP Grill that needs a new Hose Regulator-S/B Valve Assembly. I have ordered two separate times what "Appliance Factory Parts" thinks is the part I need and both...
This ma=y be a case of changes in parts for your VC Grill. The ownership of Vermont Castings changed 6 years ago, when Majestic Fireplace, who was then the owner went bankrupt and Monesson Hearth products bought VC in the bankruptcy. Shortly there after, Monesson made some sweeping changes to the grill line (your model was discontinued) and really up graded what Majestic Fireplace had done with that line of grills. Overall, they started building a better quality grill.
Unless you have a piped in high pressure propane gas system, the one that Appliance Factory Parts furnished you should work fine (based on what I saw on their website). In addition, if you purchased your grill, prior to the change in 20lb LP Gas Grill Tanks Valves, 6 years ago. Some manufacturers changed their grill hoses to conform with the new OPD Valve grill tanks. It wasn't required, they just did it, to avoid regulators locking up, when the tank valve is opened to fast.
Hope this helped answer and solve the problem for you. Happy Grilling!!
Jun 18, 2011 | Vermont American Tool Company VM450SSP...
I have a Vermont Casting 3 burner BBQ, Model VM400XBP, 36,000BTU grill that won't go above 300 degrees? How can I fix it?
It could be something as simple as a triggered safety feature within the gas tank itself. These new tanks will react to the gas leaving the tank at a high flow rate causing low burner temps. To remedy: shut off gas and remove tank. Open and close all valves on the grill. Reattach the tank and SLOWLY open the valve 2 turns. Then retry. See page 13
Apr 28, 2010 | Vermont American Tool Company VM600BSP...
My grill does not seem to be getting gas. I put a new propane tank on and still nothing. It seems to be clogged somewhere? Is this possible. I bought a new tank hose last season could that be bad? The...
Take the tank loose from the grill and open all the burners. Then close the burners and reconnect the tank.
SLOWLY open the tank just a little bit and light the burners with a stick lighter. That's what I do. Those new tans have a safety device in them that locks off the gas if the tank tilted even slightly or the gas valves are opened too fast.
Apr 11, 2010 | Vermont Casting The Extreme VCS5005BI...
Vermont castings Medallion CF9080 wiring burst into flames
First of all i would find out what city this company was in, and who owned it, then i would contact the district attourney in that city and see what they can do too get this remidied, this may be what is called a fly by night company, and they may or may not have a parent company....hope this helps....
May 22, 2009 | Grilling
Vermont casting ignitor dont work install new new button and batteries
igniter to burner gap on 4 burner jenn aire 480 (vermont casting built} gas grill
Apr 19, 2009 | Vermont American Tool Company VM600BSP...
Heating & Cooling Logo
557 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
