Question about Whirlpool GSX9885J Top Load Washer
FI appears FI keeps appearing. I have to press cancel at least twice before cycle begins to work. what to do
    President:
  • 878 Answers
Sits, F1 has to do with either the recirculation pressure switch or the control board itself. Under the panel on the right side is the pressure switch. You want to make sure the tube going to this switch is not crimped or clogged. Take it off and see if you can blow through it. My bet would be on the pressure switch. Catriver.
Posted on Feb 02, 2008
Codes f26 and then f27 for maytag model MFH 0710
F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start. unsure of f27
Dec 23, 2016 | Maytag Washing Machines
Howe do I cancel the movie after it starts. so that I can watch another movie.
Try pressing the home button twice (quickly) and when the app appears, swipe it upwards to close the app.
You can then re-open it and begin a new movie.
Oct 09, 2014 | Apple iPad Tablets & eReaders
My maytag commercial washer display a code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
HE4t 45981 Washer dl f and F11
The DL F error is saying that the door lock mechanism is faulty and will need to be replaced.
Mar 05, 2012 | Washing Machines
Fault code f26
Jul 30, 2011 | Maytag Washing Machines
F-28 flashing. Door will not open
While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
Check your washer plug to see if the connections are tightly screwed. You can also plug off for half an hour to reset.
How abt a nice rating for the free help? Thnks
May 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite smartwash QuietPak9 F H error code
Press the Pause/Cancel button twice to clear the display then check if water is introduced into the machine. Drain the water from the machine by selecting Drain and Spin then pressing the Start button for one second. Empty the machine after the water is completely drained.
Start a new cycle with Hot/Cold water temperature and check how long before the error code appears after the cycle is started. When the code appears, press the Pause/Cancel button to clear the display then check again if water is introduced into the machine.
The pressure switch is not tripping and must be replaced if the error code appears about 8 minutes after the cycle is started and about 40 liters of water is introduced into the machine.
The flow meter is not working if the error code appears less than a minute after the cycle is started and about 3 liters of water is introduced into the machine.
The valve solenoids may not be working or the levers are stuck if the error code appears less than a minute after the cycle is started and no water is introduced into the machine.
Let us know which case above is observed for specific troubleshooting and repair guide.
Mar 09, 2010 | Kenmore Elite 45986 Front Load Washer
Keeps going on test cycle
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Mar 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Apr 08, 2007 | Kenmore 17342 / 17349 Built-in Dishwasher
Whirlpool GSX9885J Top Load Washer Logo
65 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
