Question about GE Energy Star 3.7 IEC Cu. Ft. Front Load Washer with Stainless Steel Basket
GE Frontload Washer Adora series duet pair
Washer cycle stopped. F-1 blinking on control panel. Cannot open the door? I can turn the power button on/off. Cannot get any cycle to start.
  • misttie Feb 17, 2008
    Can't get the cycle to start
    Genius:
  • 1,554 Answers
You may or may not hear clicking as it tries to start.
See this link for troubleshooting it. and to open door.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Posted on Feb 03, 2008
GE Quiet Power 3 won't start when door is closed.
What is the exact model number? This may be an issue with the cables that connect the door to the power supply.
Apr 06, 2018 | GE Dishwashers
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
It's STUCK
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer. Please post back for any further assistance.
Daniel
Jul 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Determined the problem with my frontload Whirlpool Duet washer...the drain was definitely clogged. How do I reset it? Do I unplug it?
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
HELP! I have a whirlpool HE3 frontload washer and it is stuck on "Control Locked". I did try holding "end of cycle" button for 3-5 sec. and I also unplugged washer for at least 30 min. as suggested with no...
you can manually open the door by first unplugging unit from power,then remove lower toe kick panel under door,reach up to find the door latch assembly and feel for a small tear-shaped plastic tab located on bottom of door latch and pull downwards 1/4" till you hear a click and door should open manually
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star 3.7 IEC Cu. Ft. Front Load Washer with Stainless Steel Basket Logo
182 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
