Question about HP mx705 17" CRT Monitor
Monitor Fading My monitor will spontaneously begin to fade out and develop bright white lines running diagonally across the screen. For awhile, I could tap the side and it would return to normal, but now I have to really biff it to make it go back - and it doesn't stay for long. I don't want to hit it again, because I'd hate to break the stupid thing. Any ideas? It's giving me quite the massive headache.
Get a new one of hp no luck thear just by a bigger beter one thean kick the old one
Posted on Feb 02, 2008
Fading colour
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | ViewSonic VA1703wb Monitor
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
Color is fading bright n dark
Could be your monitor is going bad, plug a montior into your computer, if the new monitor does not fade, then you found that the old monitor needs replacment, however if both monitors are fading, try to
Restart ur computer and get into the BIOS. check if the line is there also. then plug in an external monitor into the VA connector of the system and check if the line appears there also.
If in both the cases, there is a line, then the problem is with the video card. if the line is only seen on the notebook display, then the problem is with the built-in screen, which means you will need to get the screen replaced, or get a new monitor. Check ur warranties.
If the video card is found to be the problem, then depepnding on the video card (on-board or extendible) it will need to be replaced. Again, check ur warranties for any free service.
Jun 18, 2010 | Dell Dimension 2400 PC Desktop
There is a Fading strip of white Running across my screen
try resetting your phone factory setting it will help.
Jul 02, 2009 | Nokia E63 Cell Phone
Monitor fades and turns blue
this sounds like a transistor issue concerning the ccfl lamps the power transistors are deteriorating and they will eventually go bad you can have them replaced and that should fix the issue. otherwise I would say have the capacitors that feed the ccfl's may be getting old and need replacement as well, its not something the average customer will want to do but if you have a service center that does electronic repair then that would be bst.
Hope this helps
Jan 30, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Monitor gets brighter
Well... it's time for a replacement. It's seems your AD Board begin slowly to dies out... Eventually will turn to white screen.
You'll need a new AD Board.
Mar 10, 2008 | Fuji FP-768 17" Flat Panel LCD Monitor
Monitor problem
It sounds to me like your monitor is going......if the computer itself is functioning fine, and you have even reset the monitor to the default, and still having problems, I would say it's time for a new monitor. You can find reasonable ones on ebay. I got two 19" monitors off of there and I am thrilled with them. Just be sure to check the ratings of the seller before bidding or buying.
Good luck.
Dec 01, 2007 | E-Machines 6809 Notebook
Monitor problem
Sounds like you have a coincidental hardware failure. The reset button usually sets the monitor to factory default which is good in most uses. A rolling pattern on the screen is occasionally due to electronic interferrence such as a mobile phone in the vacinity. As you say your screen is fading completely suggests a hardware failure and nothing to do with your pressing the reset. If your monitor is less than 3 years old (standard screen warranty) I would contact the manufacturer and they may send you a new one.
Sep 06, 2007 | Acer AL1717 17" LCD Monitor
Screen keeps fading
I don't know for sure if this will help but it's worth a try. Go to Start, control pannel, system, advanced, performance, settings, and click adjust for best performance. This is a Windows XP fix but the same thing may apply to older OS's (95, 98, 2000, ME, NT (although you may have to set it a diferent way). Many other things could be your problem but this is an easy thing to try.
Feb 01, 2007 | Yamaha iiyama 17NE1-S e-yama 17" LCD...
HP mx705 17" CRT Monitor Logo
85 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
