Question about Sewing Machines
Skipping stitches or won't sew
Everthing is moving freely, but its not catching the bottom thread at from the bobbin. Almost like the needle isn't going down far enough, but I checked that, changed needles, bobbins... what do i do next?
  • tom sh Feb 15, 2008
    My sewing machine skips stitches. Needles, bobbins tension, reassembly, rewinding, different bobbins, length and stich timing, you name it, we have mulled over it. We are looking for a hammer!
  • Anonymous Dec 01, 2008
    How do I retime the needle? TT_TT
Re-timing is a possible solution but there is a couple of other possible causes. Bent needles are the first thing to check (but you said you changed needles). Another cause in this machine is wear. This machine has been around long enough for the guides for the needle shaft to have worn. You can check this by grasping the needle clamp screw and pushing it front to back. If there is more play than about half the thickness of you thread you're probably going to drop stitches. To verify this is the problem take a piece of string and loop it around the needle clamp screw and pull backwards on it while sewing. If your machine stops dropping stitches you've found your problem and need to take your machine for service.
Posted on Jan 11, 2009
Skipping right side stitch on a zigzag stitch, so when i am running a zigzag stitch when the needle goes through the fabric and comes back up it pulls the stitch back with it ??
check your bobbin and is the needle good and sharp and the proper length.make sure its not bentthe tiniest defectt n a needle can mess up any stitch.
how does it work on regular stitching.
most problems with machines involve.bad needles incorrect threading of bobbin or spool,dirty bobbin,incorrect needle.
it sounds like the needle isnt catching the bobbin thread.
hope this helps
Apr 05, 2017 | Sewing Machines
Bottom stitch skips stitches
MY FIRST THOUGHT IS THE TIMING IS OFF A LITTLE. BEFORE SPENDING YOUR HARD EARNED MONEY FOR A REPAIRMAN TRY THESE POSSIBLE CURES:
1. TRY TO SEW WITH THE NEEDLE ALL THE WAY TO THE LEFT AND THEN TRY IT ON THE RIGHT. IF ONE OF THE TWO SEWS BETTER THAN THE OTHER YOU CAN BE ASSURED IT IS THE TIMING WHICH MEANS YOU NEED A REPAIRMAN.
2. JUST FOR GOOD HABITS DO THESE BEFORE GOING TO THE REPAIRMAN: CHANGE NEEDLE AND THOROUGHLY CLEAN THE BOBBIN AREA WITH CANNED AIR AND A QTIP TO CLEAN DIRT OUT. AFTERWARDS PLACE A DROP OF SEWING MACHINE OIL ON THE RACE THAT YOUR BOBBIN CASE FALLS IN.
3. PLACE TWO INCHES OF THREAD UNDER THE PRESSER FOOT. TURN THE HAND WHEEL TOWARDS YOURSELF AND WATCH IF THE UPPER THREAD WRAPS ON TOP OF THE BOBBIN CASE WHILE THE NEEDLE IS RISING. THE THREAD SHOULD PULL AROUND THE BOBBIN CASE WITHOUT CATCHING ON THE BRACKETS THAT HOLD THE BOBBIN CASE. IF IT DOES CATCH A LITTLE BIT YOU MAY NEED TO MOVE THE BRACKET AWAY FROM THE BOBBIN CASE ABOUT ONE PAPER WIDTH.
Jan 29, 2015 | Sewing Machines
My Bernina 200 bobbin thread snagged and now the bobbin thread will not catch the top thread when I sew, thus, there are no stitches made in the fabric.
1. CHANGE NEEDLE.
2. ADJUST BOBBIN TENSION. MAKE SURE YOU ARE USING THE RIGHT BOBBIN FOR THE MACHINE. THE WRONG ONE WILL NOT ROTATE FREELY. HANG FROM FINGER AND BOB. SHOULD EXTEND ONE INCH WHEN ADJUSTED RIGHT.
3. ADJUST TOP TENSION. (START AT 3)4. EXTEND TWO INCHES OF THREAD FROM BOBBIN. HOLD TOP THREAD TO THE FRONT AND A LITTLE TO THE RIGHT.
5. TURN HAND WHEEL TOWARDS YOU. THE BOTTOM THREAD SHOULD COME UP FROM UNDER THE PLATE.
6. IF THE THREAD DOESN'T FEED FROM THE BOBBIN TO THE TOP OF THE PLATE THE TIMING IS OFF AND WILL NEED TO BE ADJUSTED.
Jan 02, 2015 | Bernina Sewing Machines
Skipping stitches on bobbin thread Juki DDL555-5. any suggestions?
sounds like u have the wrong needle or machine is out of time. if its a needle feed machine u might have the wrong bobbin case. try lowering the needle slightly. machine is easy to time. theres a mark on the needle bar which u align with the bottom of the bar guide then loosen the hook (3 screws) and move hook till it just starts to meet the needle. careful of side to side movment. bobbin case has to remain in the finger.
Mar 27, 2014 | Juki Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
My New Home skips stitches. I have cleaned it, changed needles, adjusted the tension and tried different bobbins .
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
it's also possible that the machine could be slightly out of time
Aug 29, 2012 | Sewing Machines
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    Timing
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    Thread
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
Every 4 or 5 stitches the bobbin thread fails to catch the top thread resulting in skipped stitches
double check needle position and needle type. It will also do this on stretchy material, do to material catching on the thread
Aug 30, 2010 | Janome 1017 Mechanical Sewing Machine
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
276 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
