Tv repair I have a covergence problem on my sony projection TV. Ichanged the Convergence chips, with no luck. I'm not sure if I purchased bad chips Please help shazadzahid
  • 8,617 Answers
Did you check for open resistors coming out of the ICs. These commonly go open when the ICs go out. The are located right next to the ICs there are numerous resitors all with no color bands very easy to locate. Check these resistors.
Posted on Feb 03, 2008
My panasonic PT-47wxc43g projection tv has developed shrinkage in the middle of the screen on both the top and bottom. The picture has an hourglass on its side appearance. The picture is now also too large...
This could be a problem in the convergence board which will cost of repair would range 400.00 or so.
You can get the convergence repair kit at the following link which contains the parts and step by step detailed instructions.
http://www.tvrepairkits.net/panasonic_repair_kits
Thanks
Kevin
Jun 29, 2009 | Televison & Video
I have a Sony KP-51ws510 that has wavey or fuzzy corners opposite of one another?
The problems ur tv having it is call a convergence problems,it dead.Very common problems,for old DLP tvs design.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than tv covergence board is dead.Tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Sony KP-51WS510 51" Rear Projection...
Sony KP-57WV700 Convergence Repair Failed - TV won't stay on
Sorry ur convergence ICS are shorted and dead.Because u put in solders and take out solders to many times.The heat of ur soldering iron,and the electrostatics will kill the ICS,if keep putting heat in the ICS legs alots times.Buy the convergence kit again,replaced every componnents in that kit to ur tv.Because,the kit been research and put together.What the most common componnents that burn and dead in the convergence circuits.
May 04, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
IHAVE A COVERGENCE PROBLEM WITH SONY KP-65WS510 THE RED AND BLUE ARE OUT OF SYNC.
Ur tv convergence are dead.U know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 01, 2010 | Sony KP-65WS510 65" Rear Projection...
Sony KP53S76 Projection TV Convergence IC Bad
Should be a 392-150 make sure you replace both.
Feb 15, 2010 | Televison & Video
My phillips 60 in projection tv is showing to
The two convergence ICs and 12 feed resistors are the most likliest cause. Whats your model number as you can get convergence repair kits which have parts and CD with instructions at www.tvrepairworld.com
Jul 16, 2009 | Televison & Video
Sony KP-61XBR200 Convergence problem, when i press auto focus on the front of tv it runs its process then at the end reads (E 14G) the green color makes a bad shadow on the screen. when i cover up the...
one of the covergance chips has died
i replace both when i service a covergance
problem, they cost around 20.00 to 40.00 etch
and there easy to locate inside the tv to
get a part #
Jun 24, 2009 | Sony KP-61XBR300 61" Rear Projection...
Red Covergance Issue
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Jan 27, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony rear projection convergence
This is a convergence problem that is either bad connections on the convergence ICs or defective ICs. IF you can solder and feel comfortable working inside the set, you can fiox this yourself. Let me know if you wish to attempt the repair and I'll post more details and instructions.
Dan
Nov 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
