Question about Pioneer VSX-D209 Receiver
VSxD209 My Pioneer VSX D209 only works when I put the CD player. Doesn't work when the radio or DVd are on HELP
  • 2 more comments
  • denisr Feb 02, 2008
    The monitor is not on, the radio dosn't work
    Dear Devocap
    I did reconnect everything but the radio is in amplifier.
    I see ont display
    MONO, Tuned and SP>A
    BUt their is no sound for the radio.
    Denis Hoping a solution
    I have pushed the MPX button the mono turns off, but no stereo appeared. I have only to speakers that are plug in surround R&L
    Hoping...
  • Anonymous Mar 23, 2014
    installed today in my 99 ford truck, stereo works great, but the cd player will not work. took the cd and then stopped working
  • 407 Answers
Pioneer vsx d209 only support cd ... if you try to run dvd or raido pioneer stop. the best way go to pioneer home site look support only dvd or radio vision............
Posted on Feb 02, 2008
    Sergeant:
  • 201 Answers
Hey there denisr, please take look at the display screen on the unit. If you see MONITOR, indicated in the display, then this is your problem . Simply deactivate via the button on the front of your machine. Hope it helps. Good Luck!
  • 1 more comment
  • Devocap
    Devocap Feb 02, 2008
    Hey there denisr, Have you checked all your connections, and antennae. I would recommend you unplug all the affected components. Check all the wires for damage or breaks. Once you are certain they are good, reconnect. Hope it helps! Good Luck!
  • Devocap
    Hey there denisr, try pushing the MPX button, thus returning the receiver to stereo reception mode. Let me know if this helps. Good luck!
  • Devocap
    Hey there denisr, I would suggest you unplug your speakers and plug them into the connections on the back for front right and front left. This should fix it. Surround only works when the media is encoded in surround, and you have the reciever set in a sorround mode. You should get more speakers if you want to have surround as an option. I belive the ports you were connected to are more for the rear element of sorround. Good Luck!
REAR SPEAKERS ON PIONEER VSX-401
@Michae Yokeum
"Rear Speakers on Pioneer VSX-401".
Hi Michae.
Wow, nice Hi-Fi!! :) :)
IF [manual_required] THEN
GOTO
https://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-01TXH_OperatingInstructions0523.pdf
ELSE
Check your SBch* setting which should be set to ON or AUTO.
*Speaker Back channels
More info on pg. 83 of manual.
PS - as this is a home hi-fi and not a car-radio, I've moved it from 'Cars & Trucks' to a new home 'Audio Players../Pioneer', where experts in that field can offer more help.
Oct 15, 2017 | Pioneer Audio Players & Recorders
Pioneer vsx-d810s only dvd 7.1 input works and static on all other inputs
Try resetting the receiver the Pioneer Web site should have the reset procedure for your model if that doesn't work time to send to the shop.
Oct 03, 2011 | Pioneer VSX-D810S Receiver
No TV sound, only DVD and CD players
Check your tv settings may need to change from speaker out to line out.
Check the tv input on the receiver, put the cd or dvd cables into the tv input. If you get audio the receiver is fine. No audio check the receiver settings.
Nov 16, 2009 | Pioneer VSX-54TX Receiver
Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Apr 19, 2009 | Pioneer VSX-D209 Receiver
Pioneer vsx-d508
I once inadvertantly set the audio output on my DVD player for a level that I didn't have the capacity for: IE: 7.1. check in your audio setup menu, and adjust the level down...Just a guess :)
Feb 14, 2009 | Pioneer VSX-D508
When i play music cd all speakers work but when put a dvd on only the 2 front ones and centre speaker goes? Tried all settings. Y are my 2 surround sound speakers not working? I have a pioneer vsx-816...
What is happening is the the pioneer is set up so that you can choose how you listen to your DVDs. So first you must see how your DVD is connected via the audio. I am fairly sure that the Default on the Pioneer is to play it through the standard stereo if all you have plugged in is the left and right audio plugs. If you buy an optical cable or a plug in the Digital Coax out put to the pioneer receiver, then the pioneer will decode the sound and out put true surround sound. Some DVD players don't have a digital out put, but these are the cheapest ones out there. If yours doesn't have a digital out put, then you need to get one that does. They can be purchased for as little as 39.00.
Okay lets assume you bought a DVD player with Digital out put for audio and you have it connected to the receiver. Now, you have to change the mode on your pioneer to let it know that your audio is coming in DIgital when you select the DVD. (Though this may already be the case and you won't have to do anything once you connect it.)
Dec 08, 2008 | Pioneer Televison & Video
Overload
Ok, how much is "a bit"? If you are operating your unit at the 50% or more level, your unit is working as it should, as DVD and CD players output more signal than other sources...accordianman
Nov 26, 2007 | Pioneer VSX-D307 Receiver
Pioneer VSX-D209 Receiver Logo
221 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
