Question about GE Profile Prodigy WPSE4200A
Agitator loose Agitator seems to be loose. How can I get dismantle the agitator to check it and repair it? I took the agitator cap off, but there is an apparently unremoveable plastic separator on top of what look like bolts. Any suggestions?
  • pws1982 Jul 29, 2008
    my agitator keeps popping up off the base during the wash cycle i've tried popping it back in place i don't if i'm aligning it properly or not
  • Anonymous Mar 23, 2014
    Agitator comes loose
  • 240 Answers
Just reach down between the basket and the agitator, and lift really hard straight up. Be sure not to hit yourself in the head when it pops loose. GE agitators just snap on to the air-bell underneith. Be sure that bell isnt loose after you remove. Good Luck!!!!
Posted on Feb 03, 2008
Agitator seems to slip and not constantly move during wash cycle
no it is not suppose to slip it sounds like the agitator dogs need replacing it is quiet easy to repair and not expensive it only cost me $8 and took twenty minutes to do when I replaced the ones on my washer
Dec 28, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have read the instructions for removing the agitator, but my machine does not seem to allow me to get to a bolt or nut. I have removed the cap from the agitator, but the barrier cap and seals do not...
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets your needs, ..Thank you.
Jul 17, 2011 | Kenmore 22422 Top Load Washer
Diplomat ADP 8322 - 11 Flashes. Will not go beyond the Rinse cycle.
There's never a good time for the washer to stop working correctly. If a washing machine's agitator isn't working properly, your clothes won't come clean.
The back-and-forth movement of the agitator is a main function in the cleaning process of your laundry.
If your agitator isn't working, it could be the agitator itself or broken splines in the assembly beneath the agitator. Either one is a relatively easy and inexpensive repair that you should be able to do yourself.
Instructions and material needed :Socket wrench,Rope,Broom,Replacement parts
  1. Inspect the agitator for breaks. If the agitator is broken or cracked, you'll need to replace it. A broken agitator won't operate correctly, if at all. If the agitator looks fine but isn't moving, you'll need to inspect the plastic splines in the agitator assembly located underneath the agitator.
  2. Remove the agitator from the washing machine by first removing the fabric softener dispenser cap on top of it. This cap should either pull or screw off. It it's difficult to remove, you might have to pry it off.
  3. Unscrew the bolt beneath the softener cap with a socket wrench. Once you've removed the screw, try lifting the agitator out of the washer. If it doesn't easily lift out, loop a rope underneath one side of the agitator and over a broom handle. Continue looping the rope under the other side of the agitator and back over the broom. Using caution not to hit yourself in the head, pull up on the broom until the agitator comes loose.
  4. Replace the broken agitator with a new one. Snap the new one in place and secure the bolt underneath the fabric softener cap. Place the cap back on the agitator and you're ready to start washing.
    Check the plastic splines in the assembly directly underneath the agitator, if the agitator itself isn't broken. If the plastic splines are broken or worn down, this will keep the agitator from properly moving. In fact, it might not move at all. Replace the spline assembly with a new one and reassemble the agitator by reversing your steps to remove it.
Good luck and thanks for using fixya.
Dec 24, 2010 | Dishwashers
Agitator not moving--seems loose
This washer has what we call a bionic agitator and this agitator has a 2 parts:
it has a base and a top section.
IF the BASE IS NOT WORKING AT ALL, please have the transimssion checked and also check the coupling.
IF the BASE is working and the top is NOT
THEN replace the 4 plastic AGITATOR DOGS that are in the agitator.
Remove the CAP from the agitator...remove any plastic cap.
Get a socket wrench and get the socket that removes the bolt.
remove bolt...
PULL the agitator from the base and separate the top from the bottom.
Take the top and turn it upside down to remove the platic interior part that holds these 4 dogs. REMOVE the old dos and replace with new and do a reverse engineeriong putting agitator back.
Nov 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The top agitator does not work. It seems that
This problem is generally caused both by by overloading the machine and time. The kit to repair it is called an "Agitator dog kit" and can be purchased at any parts outlet for likely less than $10.
To replace the Agitator Dogs, follow these steps:
  1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
  2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
  3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
  4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
  5. Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
  6. With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
  7. With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
  8. Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
  9. Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
  10. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
Good Luck
Oct 03, 2009 | Kenmore Washing Machines
Agitator is loose
Does the plastic cap unscrew (CCW)? If you get it off, there is a plastic block attached to the top of the shaft that should just pull off. Check it for cracking or splines that are torn out inside--replace it if damaged. Make sure the cap screws down tight.
Sep 08, 2009 | GE Profile WPSR3100W
Mover agitator slips
The agitator bolt may be loose, or the dogs may need replaced. The following link explains how to access and repair:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
You can view what agitator dogs look like at appliancepartspros.com. Just type in your model number and look for item 18 under the Agitator, Basket and Tub heading. A replacement kit only costs about $5. For a bit more, you can purchase the entire agitator repair kit for about $11 (item 22). The exploded view diagram can also assist you.
Your agitator has a cap that comes off the center post, followed by an air gap cap inside. The air gap cap just pulls out, exposing the agitator bolt. The upper portion of the agitator (called the "auger") will lift off once the bolt is removed.
NOTE: Make sure when you reassemble the agitator that you remember to reinsert the air gap cap and that the rubber o-ring gasket is intact. Without it, water will eventually work into the gearcase (transmission). Also make sure you do not overtighten the agitator bolt. Doing so may damage the agitator or restrict its movement. Tighten until snug.
If you have any questions, please let me know. I hope this helps you.
Jul 21, 2009 | Whirlpool WFW8300SW
TOP AGITATOR NEEDS TIGHTENING
You need to get an agitator repair kit from the appliance parts store. Number ap3138838 This has a new thurst washer that will fix the loose upper agitator. Remave cap under fabric dispenser, it pulls up and you will see bolt. This kit also has cam parts to repair the worn ones on upper agitator too. Take model number to the store with you.
Jun 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Jan 31, 2009 | Whirlpool Inglis IP4400 Washer
Washing Machines Logo
643 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
