Question about Nokia N70 Cellular Phone
Assigning ringtones to a profile
I have a Nokia N70 mobile phone. My problem is when I assign a ringtone to a profile it works for one or two calls. Then again it goes to default tone. I have reset my phone to its original settings too. But I can't fix my problem.
  • cafaso Feb 03, 2008
    I can't veiw the solution
    President:
  • 1,017 Answers
If you set the profile ring tone to OFF. Then select a contacts' number and assign it a Ring Tone. When that contact calls you the Ring Tone you assigned will ring.
If you select the same Ring Tone for all your contacts in a group they will all sound the same when they call.
Or select the same ring tone for a profile, but cancel the Tone you assigned to the contact(s).
Posted on Feb 02, 2008
2 Suggested Answers
nasirahmed
  • 282 Answers
SOURCE: assigning ringtones to a profile
Do you often change your sim card. If you change sim card it may happen.
Posted on May 22, 2008
How do I access ringtones on alcatel one touch 2001x
To change the ringtone, follow these steps:
Ringtone for all calls
  1. From any Home screen, tap the All apps icon.
  2. Tap Settings.
  3. Scroll to 'DEVICE,' then tap Audio profiles.
  4. Under 'PREDEFINED PROFILES,' tap General.
  5. Tap the General Settings icon.
  6. Scroll to '[INCOMING CALLS],' then tap Phone ringtone.
  7. Tap the desired ringtone from the scrolling list.
  8. Tap OK to confirm.
Ringtone for calls from one contact
Note: You cannot assign a ringtone to contacts stored on the SIM card or Phone (device memory).
  1. From the home screen tap all apps.
  2. Tap People.
  3. Tap on the specific contact.
  4. Tap Menu.
  5. Tap Set Ringtone.
  6. Tap on the ringtone, then tap OK.
Mar 27, 2016 | Alcatel Cell Phones
How to change call ringtone on nokia e63
Hi Violin,
I have this steps for you for work around setting up call ringtone. Hope it helps.
--- there should be no prob to set a custom tone if you go to the tone and select options you should get an option to select from a list from the menu otherwise go to profile and select edit then when you come to ringtone select options and you will get options you should be able to select a tone from the gallery
---I discovered something about this problem. It appears that if you have the same phone number assigned to two (or more) contacts the ringtone plays the default ringtone. Once I deleted one of the contacts with the same number, it played the correct custom ringtone. What is strange is that both contacts had the same ringtone. BTW, the reason I had done this was to simplify the voice command to make a call to this contact.
Apr 25, 2014 | Nokia E63 Cell Phone
I have a nokia E72 and have been trying to change the ringtone assigned to certain contacts. When i select ringtone within the options menu i only get a list of the ringtones which come with the phone....
Select the music file you want inside the media gallery, open the Sound Clips folder where your music file is stored then select 'Option', choose 'Use Tones --> Set as ringing tones' or 'Use Tones --> Assign to contact'
Aug 18, 2010 | Nokia E72 Smartphone
How to assign a ringtone to a specific person on a
jus go to contacts....now select option while electing the contact....Add contact option....nw make chose ringtone option!!!!!....this is general for all mobiles...may be the commands would be changed in ur mob...i guess u ve got an idea.....cheers
Nov 26, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
My nokia 1208 won't ring on an incoming call although the demo tones are fine. I keep getting missed calls. Any help welcome. Have tried all the settings with no luck.
check if you have set the profile to Silent or Pager , change it to General , also check which ringtone you have assigned to the profile and the volume is not set to minimum
May 17, 2009 | Nokia 1208 Cellular Phone
Change ringtone on cect i9
1. At the main menu, select “Settings”
2. Now select “User profiles”
3. In the next menu, select “General”
4. Now “Customize”
5. Select “Tone setup”
6. Choose which SIM (on dual SIM card phones) you want to assign a ringtone to.
7. You will now see a list of available ringtone.
8. Select it.
You should see at the very bottom of this list 5 empty locations this is where you can add your own mp3's as ringtones.
Now I Know your second question once you get this figured out will be how to assign ringtones to individual contacts in your phone book so here is part 2. 1. From the Main menu choose Phone
2. Choose Quick search
3. Find the contact in the list you want to add the ringtone by scrolling down the list and tap on their name
4. Choose Edit
5. Scroll down the list of options to the Musical note called Associate sound and select the ringtone from the list.
Your new ringtone will now function for that contact whenever they call!
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
Dont know how to change ringtone on my sci phone
4. Now “Customize”
8. Select it.
Apr 09, 2009 | Dual Electronics CECT P168 Cellular Phone
My nokia n95 8gb doesnt display some incoming callers names?
Call ID must be activated in your phone. Your cell phone provider customer service must help you with that.
Artgirl
Jul 20, 2008 | Nokia N95 Cellular Phone
May 22, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Specific Ringtones for certain callers....Motorola W375
I don't think it's possible to assign ringtones to specific phonebook entries with the w375. You can't store many anyway!
Dec 28, 2007 | Motorola Mobility W375 Cellular Phone
Nokia N70 Cellular Phone Logo
312 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
