Question about Maytag MER6772 Gemini Electric Kitchen Range
Magtag double oven
The bottom oven on my maytag oven will not shut off unless I pull the breaker .
BETTY
  • 770 Answers
Sounds like you have a sticking relay here is a link to the service manual on your unit
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Posted on Feb 17, 2008
6ya staff
SOURCE:
Hi. When you turn on the top oven the upper element doesn't shut off after it gets to the set temp.
It could be a stuck or welded relay in the control board. Sometimes a sharp rap on the relays on the control board will jar the contacts loose. Be careful not to tap too hard and make sure the power is off. If this doesn't solve the problem you may have to replace the control board.
Mar 28, 2014 | Maytag MEW6630DDB Electric 30 in Double...
Tried removing element from bottom oven, with the bottom oven selector on to provide some light. As I pulled the element out one of the terminals touched the casing and caused the light to go out, the...
More than likely you have tripped the house circuit breaker or fuse. If you know where the house fuse box or circuit breaker panel is check to see if either one side of the two 240 fuses is blown or one of the two tied together circuit breakers is tripped. If it is a breaker then shut off both breakers completely and then snap them both on completely or they won't reset. It is rare that an oven has a fuse internally. There can be thermal fuses but they will trip when the temperature is out of range.
Feb 25, 2014 | AEG U7101-4 Electric Double Oven
Electrolux ew301s6cjsa
Not enough info and I dont have that code. But, there are thermal safety devices in back of the ovens that can shut everything down. Unless your electrically quailifed, find someone who is and has a meter, then pull oven(s) out of the wall and check all safety devices...
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 13, 2013 | Electrolux Stainless Steel Induction Slide...
Mod#cwe4800ace27/to long to heat up
ur heating elemnt inside on the bottom is out it has 2 screws in the back u take out n it will pull out just disconnect the @ wires make sure u turn off the breaker to shut off power !!
Apr 07, 2011 | Maytag Ovens
Maytag electric oven model cwe5800acb. The lower element in the upper oven will not heat up. Can the lower element be replaced without removing the oven from the wall.
Yes, replace the lower element by first turning off the circuit breaker to the oven (110V is still to half of the 220V element circuit even though the oven setting is turned off), then unscrew the two screws holding the element to the back wall of the oven, then pull the element out (may have to tug it a bit to get the connectors through the insulation), and pull the wire connector clips off the element.
Mar 14, 2011 | Maytag CWE5800A Electric Double Oven
I have just installed a Maytag built-in double oven to replace my old one (still working.) I shut off circuit breaker and reconnected wiring. The Control Panel and indicators on the digital readout all...
How many active terminals are there at the main terminal block in the new oven. Is this a single or 2 phase supply. Have you connected the active supply to all active terminals. If only half of the oven is working it sounds like it could be a problem at the terminal block. If so, you need to put a loop or bridge wire to the 2nd active terminal.
If all this was done correctly when connected the only other thing it could be is the electronic clock needs to be set to manual mode for the oven to work correctly.
Feb 26, 2011 | Maytag CWE5800A Electric Double Oven
My oven keeps beeping and flashing an f-7.....what can i do to stop it?
Turn off house breaker to the unit at the breaker box of your home. This will be a double breaker.
F7 Touch pad or Control board...... Most techs start with touch pad.
Sep 05, 2010 | Maytag CWE5800A Electric Double Oven
Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Jan 16, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Stove oven will not come on get a code F1-1
Put in a new thermastat in the top oven and it works great. Thanks for the advice(from other's having problems).
My Maytag was older than I thought, so the thermastat was not available on line, but found one at a repair shop that worked. Thanks!
Jan 10, 2009 | Kitchen Ranges
Maytag MER6772 Gemini Electric Kitchen Range Logo
217 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Marvin
Marvin
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
