Question about Insignia IS-LCDTV32 32 in. Television
Insignia TV doesnt turn on
I am unable to turn on the TV..The power in the TC comes for a split sec and goes off....Best Buy says that there is no warranty on this...TV technician says that it is hard to fix...What to do?? Please help!
  • 23 more comments
  • Anonymous Feb 16, 2008
    Same problem.  TV won't turn on.  TV sucks!  Had it less than a year and Best Buy and Manufacture won't do anything about it!
  • Jimharry Feb 18, 2008
    I noticed my LCD32 will turn on and stay on when it is cold (it is currantly in unheated garage), but won't turn on when its warm--LCD screen flashes for a split second, then nothing. I believe it is a power supply, but not sure where to get a new one. I am pretty savvy with working on tech things--PC's, Copiers, etc.
  • billygess Feb 20, 2008
    i have an insignia ns-32 lcd tv. i've had it for less than a year and i was watching tv and i went to turn it off and was shocked. it turned off by itself and now the insignia light on the front just keeps blinking and it wont turn on.... what could the problem be and how can i fix it??
  • Anonymous Feb 20, 2008
    I have been through two set with the same problem on both sets sound like a design flaw to me.
  • Anonymous Feb 21, 2008
    I am having the same problem. The television seems to be turning on and off by itself and it makes kind of a popping sound each time it turns on. It is a 36 or 37 inch television and I have had it for less than a year.
  • billygess Mar 01, 2008
    i changed the mother board in my insignia ns-32 lcd tv and it still doesnt work what else can i change
  • Anonymous Mar 26, 2008
    We are having the same problems. The tv takes about 5 minutes to go on after we turn it on. It makes the popping sounds also. Best Buy said to call Insignia but from the problems expressed, it might be best to buy a different brand next time.
    Sylvia
  • Anonymous Mar 27, 2008
    My Insignia TV doesn't turn on either.
  • Eileen9557 Mar 29, 2008
    I have an NS-LCDTV32 (not IS) and having the same problem--and it the power light comes on you can't turn it off.
  • iratherfly Feb 05, 2009
    Same exact problem at exact same time. Happened for the first time last week and after cycling it on an off and quickly getting to one of the menus I managed to change TV sources and it stayed on afterwards. The problem returned again today but the cycles are too short for me to get to any menu this time. Best buy however were nice to me over the phone (even before I told them that I have extended warranty). They found the problem on their database, so you and me are not the first to have it happen to them. They attribute it usually to dirt and dust or excessive humidity inside the TV. A technician will come in and look at it. In the meantime - no TV for me. This TV is 3 years and 2 months old now. Luckily I bought a 4 year service plan with it. Worth the $130. If anyone knows of a trick or a master reset switch for this TV - please post!
  • emilyjoellef Feb 05, 2009
    I also have the same problem, We have had it for about 2 years and about 4 days just wouldn't turn on. Now the insignia logo blinks red when you press the power button. Can this be fixed or should I buy a new tv?
  • Anonymous Feb 17, 2009
    i went to turn my 37 insignia wall mounted television and gor a static shock now it keeps turning on and off
  • Anonymous Feb 24, 2009
    where can you get the 680uf 35 volt cap.?
  • casm24 Feb 24, 2009
    same thing.
    came home turned on tv, and nothing, light keeps turning on and off.
    tv is-lcdtv32 is 1 year and 3 months old
  • Anonymous Mar 31, 2009
    Same Problem. There should be a recall.
  • Anonymous Apr 03, 2009
    Had for a short time, and now it won't come on. This sucks.
  • a5150copper Apr 06, 2009
    power light cycles on and off, worked fine last night, but today it wont come on.. is there a recall on this?? will best buy stand behing the repair?? thanks Neil
    a5150copper@yahoo.com
  • nrvasquez Apr 07, 2009
    Insignia IS-LCDTV32 my dad was watching it and it just turned black, blue light comes on but no picture and no sound. It is only 2 years old.
  • John Long Apr 07, 2009
    TV has power but screen would not come on. No menu, no nothing.
    Saw best solution post and replaced the three caps. Two of them were visibly smoked. My caps however were 1000uF at 35v. Replaced them with 680's as posted. The sales guy said they may burnout faster but they won't hurt anything. So if your caps say 1000uF, buy the 1000's.
  • Anonymous Apr 10, 2009
    After reicieving a static shock while pressing the power button, blue light just turns on than off. No picture at all.
  • Anonymous Apr 14, 2009
    Same problem here; we got two sets thinking it was a good deal. Serves me right for straying from a name brand.
  • Anonymous May 07, 2009
    my 34 inch insignia doesnt turn on. my repair man said the main power board is burned out and part not a vailable
  • Anonymous May 08, 2009
    my 13 month insiginia tv bought at best by (no warranty) 34" turned off manually and was shocked on/off cycle goes on 10 sec the off one second and repeats my repair man said the main power board is burned out and not available
  • cpbedor May 17, 2009
    no sound, no picture, takes about 5-10 minutes for it to actually get a picture after it cycles off and on every couple seconds.
    I did buy the service plan, which I was pissed about at the time, but the tech is coming monday to check it out. Ideally, I want him to declare it unfixable so I can get a different brand and a much larger one.
    This TV has been the main TV in our home since 11/25/2005 and we've not had a problem with it other than my 3 year old keeps losing the remote for it.
    I suppose I can update this entry Monday night after the service guy is finished. Cross your fingers that he says it's no good!
  • Jimharry May 11, 2010
    Solution #2. You say you have the parts to fix? How do I get them?
Best Solution posted on Feb 29, 2008 Insignia TV doesnt turn on - 4%20stars.png
noavatar_s.png Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Insignia Polaroid Advent Audiovox
ISLCDTV32
lcd
Tries to start then Shuts down!
Insignia IS-LCDTV32 , Polaroid FLM2601 andFLM3201, Advent 203L32K50B Also Audiovox FPE 3205 LC32K5. Cure:Replace the three 680uf at 35 volt caps at the top left of the power supply board.
It works!! I replaced the caps--about a buck each. The bad caps were swollen, and soldering in new caps wasn't hard to do. THANKS!!!
Posted on Mar 14, 2008
  • Jimharry Feb 19, 2009
    It has been almost a year since I replaced the 3 caps on the power supply of my Insignia LCDTV32. The TV is still working just great!!
YOUR POWER SUPPLY IS MOST LIKE BAD
Posted on Feb 11, 2008
Tv is 3yrs. old Insignial 32in.flat screen will not turn on, the tv is in Jamaica can we get the part for it in the US and can it be fix. please help thanks
Posted on May 15, 2009
I went to turn my wall mounted 37" insignia tv and got a static shock now it keeps turning on and off
Posted on Feb 17, 2009
My insignia 42in has no picture. owned it for one year. nobody is resposible and to expensive to fix. I say do not buy anything from Best Buy for their lack of customer service and do not buy Insignia televisions. Defective and cheap. Read alot of complaints about both. Spread the word and we can all put the pressure on both companies or let them go broke. I am buying another big screen at CASCO at least the will let you return defective merchandise. I also read that Best Buy knew about the problem and still sold these Insignia tv's. Don't buy either pass this on!
Posted on Mar 23, 2012
For those of you facing this and similar issues, here is the contact page for Insignia's customer service. Write them and turn up the heat! Complaints in large numbers is the only way to incite some action on their part:
http://www.insigniaproducts.com/contactuspage.html
Posted on Sep 17, 2009
This TV (at least the 26 in. version) has been recalled by Best Buy.
Posted on Apr 12, 2009
I have solution with several ways.
If you live in toronto, Canada, Please free to contact me.
park8817@hotmail.com
Posted on Apr 11, 2009
Followup...
Technician indeed came over and reported the power source as bad. I can no longer turn the TV on - it just cycles on and off now.
Repair guy also want to replace the mainboard (motherboard) but I think they only do that because they cannot find a readily available replacement power source and if they add the motherboard to the repair bill it will be so high that the Best Buy warranty will prefer giving me a new TV, letting the repair people will be off the hook.
Can't stress enough how important it is to get those extended service plans...
The guys who said that the 3 capacitors is the problem are right...
Posted on Mar 26, 2008
Complain to Insignia customer service so they recall the tv.Too many people have the same problem
Posted on Mar 15, 2008
ISLCDTV32
lcd
Posted on Feb 29, 2008
Heat back with blow dryer 10 min it will work . then leave on
Posted on Feb 27, 2008
  • john8252 Oct 02, 2010
    Best damn answer on here...it worked for me...thank you!
Hello I have the Parts to fix these TVS
Posted on Feb 10, 2008
2 Suggested Answers
  • 814 Answers
SOURCE: Insignia TV doesnt turn on
You should go to Insignia website and complain, about you problem either to their customer service department or sales department. Explain the problem to them and tell them that you thought you were covered by the warranty for any failure of the television not caused by you.Try to speak to people incharge of the departments if you can and keep calling asking to speak to the v.p.'s of sales.Tell them that best buy treated you badly and that you paid good money for the tv there, and they will not honor the service contract. Persistence is needed here. Hope this will help you with your problem.
Posted on May 13, 2009
What is wrong with my tv
if there was a storm ,there is every possibility that there was a power surge that has fired parts of the circuit board
I suggest that you have it check at an electronic shop and get quotes for repairs.
Aug 05, 2015 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
I have a fusion flat ccreen tv. the model # is fus42dvd. the tv will not do anything besides turn on and off. and thats only if you unplug the power cord. any suggestions on what i should do before i give...
Sir what do you mean by return it, is your tv new? if the tv is new you should return it where you bought it because it has a warranty for one year and for sure not to void the warranty. Feel free to send feed back good day and best regards.
Aug 22, 2011 | Televison & Video
My TV TC-32lx600 have a sound problem. The sound cutting every second.It happen 4 times in the past. When it was on warranty, the expert just did a power reset. my question is: how to do a reset on my TV....
if this is under warranty u can request service technician to reset it. from where u buy it. dont do anything if you dont know any mistakes will avoid your warranty. or tell them to guide you by phone etc.
Jun 02, 2011 | Panasonic TC-32LX600 Television
My tv starts on at least the green button goes on, but we don't see nothing on the screen
Insignia are a low-end Best Buy brand, and as such their reliability is poor.
If you're plugged in, the inputs are set correctly and the power comes on on the TV but you receive no picture, there is an issue with the TV itself.
Insignia offers a 2-year warranty, but you must have the original box and must be willing to pay for shipping. If you lack the original box or your purchase was longer than 30 days ago and you didn't purchase the extended warranty from Best Buy, you're most likely going to need a new TV, as they cost more to repair than they're worth.
Mar 07, 2011 | Insignia NS-LCD32 LCD TV
Picture won't come up
Insignia is Best Buy's house brand. If it's still under warranty, contact Best Buy. If not, find an electronic repair shop you think you can trust and take it in. There is absolutely nothing you (unless you're an electronics technician) can do to fix it. I know that's not what you wanted to hear, but, that's the way life is now.
Aug 21, 2009 | Insignia NS-L42Q-10A LCD TV
Sharp D64 37" issue (Power+OPC light flash and won't turn on)
I'm going to guess your friend's model is LC-37D64U. ( 37" screen; D64 series)
It's sounding like a power supply problem for the LCD screen. It's somewhat common problem for big LCD screens. But, too early for your friend to be having this problem with the TV.
I would have your friend use the warranty at this point. Last thing you want to do is void the warranty by opening up the TV.
I would first try leaving the TV unplugged for 30 mins so it can reset. Then, try turning it ON again.
If that doesn't work, it warranty time.
If your friend just bought it, have them exchange the TV for another one. I wouldn't want a TV that has problems that just came out of the box. The Sharp TV only has a 1 year warranty. Upgrade warranty life if possible. A repair for a problem like this would cost about $100 for someone to look at it; and $200 to $400 for the part at a TV repair shop.
May 12, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
May 11, 2009 | Insignia 37" LCD Flat-Panel HDTV
Dont have securtiy code to unlock tv
  1. Press and hold Action and Power on the TV until self check appears-- then unplug the TV wait for 30 sec. then plug back in.
  2.  Volume down on unit and sleep on remote. Same process wait for self check then unplug for 30 sec. plug back in and turn on.
  3. Volume down on the unit and RH-Split on the remote-- same process
Try these one at a time until you find the right one.
Let me know if this helps and please rate this solution. Lone99star
Jan 18, 2009 | Panasonic TC-32LE60 32 in. LCD Television
Insignia IS-LCDTV32 32 in. Television Logo
4,199 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
