Question about Dryers
Magic chef electric dryer
The dryer suddenly shut off. It was heating and I could still hear the timer running.
  • Anonymous Mar 27, 2014
    have no heat to dryer
    Scholar:
  • 43 Answers
Is there power to the Dryer? If so then Dryer most likely shut off due to a air flow blockage. This could be a clogged Lint Filter, or a Clogged Air Duct Exhaust (the hose that goes from your Dryer to the outsideof your house). If there is no air flow over the Heating Element the Heating Element will OVERHEAT and the Thermal Safety Fuse will Open cutting off the power. Some Thermals will re-set after cooling down. Others have to be replaced.
Posted on Feb 02, 2008
  • Totalwreck Feb 02, 2008
    Forgot to mention the most important component, The Blower! The Blower must be operating in order to circulate the air. If the Blower is not operating when power is restored, then do not run until Blower function is restored.
What does it mean when a dryer starts to tick like a clock
the ticking sound you hear is the timer motor.this is normal on timed dry.on auto dry you should only hear it when the heater is turned off.if the dryer shuts off and will not start after 20 to30 min. the motor has over heated and stopped to prevent over heating.venting is the no.1 cause of this.the vent system needs to be checked first.if it is a magic chef,admiral,or maytag under a few years the part below the lint screen needs to have all that lint removed every 6mo.
Mar 15, 2014 | Haier HLP140E Electric Portable Dryer
Stop running,no door light or motor running.
Check panel for tripped breaker. Check with a volt meter that you have 2 legs of 125v to back of dryer. See youtube for demonstration of testing. Can you hear the timer run? It is pretty quiet, but is a ticking noise.
Jan 11, 2014 | Magic Chef CYE4000AWW Electric Dryer
Dryer stopped working, sounds like timer still running
I suspect it is the thermal fuse. Seen here. You will need to determine what caused it to blow. on these machines the blower wheel is notorious for getting loose and causing the element to over heat. This makes the heating element shut down faster and takes a long time to dry the clothes. 7fc125e.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 10, 2010 | Magic Chef CYE4000AWW Electric Dryer
I've got a Magic Chef dryer that will not start. But power is getting to it, I can hear the timer clicking...what should be the first thing I check?
The door switch must be checked for continuity. The thermal overload fuse near the heating element must be checked for continuity. If either has no continuity it is a bad part and must be replaced.
Oct 04, 2009 | Magic Chef Dryers
Dryer won't shut off. Heats fine. Timer advances on air dry only. Vent is not clogged. Can't find moisture sensor replacement part.
https://www.repairclinic.com/Shop-For-Parts/a8b104d87061/Model-CYE2000AYW-Magic-Chef-Dryer-Parts
The dryer requires cycling of the heat to advance thhe timer on auto dry cycle. see ,link provided parts and repair guidance. Always remove from power supply first.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Sep 30, 2017 | Magic Chef CYE2000 Electric Commercial...
Won't start
replace the fuses and your problem is solved........
Mar 09, 2009 | Magic Chef CYE2000 Electric Commercial...
My magic chef dryer heats but will not blow air
A dryer fan is usually directly connected to the motor. If you hear the motor running, maybe the fan broke off, or the duct is really clogged.
Jan 11, 2009 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
67 people viewed this question
Top Dryers Experts
Marvin
Marvin
