Question about Eddie Bauer 22-859
Booster seat For the booster seat do I stop using the latch system ??
    Novelist:
  • 126 Answers
Dorel Juvenile Group is the company you contact for any thing dealing with eddie bauer
call for help: (800) 544-1108
(7 a.m. to 6 p.m. EST Monday through Thursday,
and 7 a.m. to 4:30 p.m. EST on Fridays)
Posted on Apr 24, 2008
Does the car seat need to be bolted to the car when the harness is removed for a child over 50 lbs?
I have a similar car seat for my 4 year old. You should check your local laws about how long they have to use a car seat. Depending on the situation, if it's leaning around to far you may just go without it. I've never seen a model that is 'bolted' to the car. Most of them at the booster stage are held in by the childs weight and the safety belt in the car. If it has straps for the 'Latch' system, and your car has latch mounts, you might do that to help stabilize it.
Hope this helps! Don't forget to rate!
Gtaplytmpt
Jul 18, 2011 | Graco Nautilus 3-in 1 Car Seat
I have a 2003 2 door sunfire. I am installing a infant car seat base using the latch system instead of the seat belt. Can I do this in the middle of the back seat or does it have to go at one of the...
Ideally if there is a middle set of latches in the seat, you can install an infant car seat base there. If the seat has any kind of hump or other irregularity then it should not be installed there. Although the middle of the back seat is safest for a child, most vehicle do not have a latch system there. However most cars do have a lap belt for the center seat and that should be used if you decide to place your car seat.
Do not use the latches from either side of the right back and left seat. The latch system is designed to be a specific distance apart to work correctly. If you don' want to use the lap belt then you should put the child seat on either the left or right back seat using the latch system.
Aug 18, 2010 | 2003 Pontiac Sunfire
Help with installing dog booster seat
Hello
I have included an instruction manual down below. If this does not work for you call this number 1-800-426-8020
http://babycare.manualsonline.com/mdownloads/397f8789-0bff-45be-927e-11a3e35f6d8a.pdf
Thank you
May 03, 2010 | Eddie Bauer 3-In-1 with Latch
How do I hook the booster car seat up? What is
The "extra" belt w/ 2 hooks is for cars equipped with "LATCH" system. If your car is 2002 or newer, you should have it. Look for 1/2 inch dots in the seat fabric near the seat belts, feel just below it for a tiedown ring. I know it goes against guy rules, but maybe read the directions that came w/ your car seat. If you got it 2nd hand, go to walmart and read the directions on the floor models.
Mar 17, 2010 | Safety 1st Summit Booster Car Seat -...
When installing the forward facing booster seat do you not hook in any of latches to the seat? We have model #22-757-MRC. My children are over 40 inches so I am swithching them to the booster seat. My...
your child's weight and the lap & shoulder belt hold the seat in place.  Run the lap part across your child's lap and the shoulder part should cross your child's chest and not cross his/her neck.  There should be some slots on the side near the top to allow some adjustment of the shoulder strap.
Sep 06, 2009 | Baby Gear
Latch when used as booster?
No, boosters are never latched to the car, so when using it as a booster, disregard the latch.
Sep 22, 2008 | Eddie Bauer Deluxe High Back Booster...
Converting to a Booster Seat.
Better yet, please use this manual for clear instructions and dont forget to leave a rating for me. Thanks!!!
http://www.coscojuvenile.com/instructions.asp
Jan 19, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Booster seat
Converting the seat to a booster: (Alpha Omega Elite Deluxe 2004 version, Eddie Bauer)
After all said and done, the base can probably be left on, it helps to recline the chair when the child is asleep. If you want to leave it out, the manual says the base can be removed for narrow vehicle seats or airline use. Locate the center bar at the bottom of the seat, push the tab at the end of the bar and pull the bar out. The seat can then be separated from the base. The seat has a "kickstand" that can be pulled out to sit the seat upright. Put the bar back in the base so you don't lose it.
To remove the harness, remove the base first. Then from the back of the seat, unfasten the harness from the harness bracket. Store the bracket by looping it behind and around the back spine of the shell. You can unthread the harness from that point and pull it out. From the bottom of the seat, locate the buckle's metal clip. Insert the clip up through the shell and pad, from the front pull the buckle free from the shell. Lock latch plates into buckle for safekeeping.
Once the seat is converted to adult straps don't use the latch system; hook the hooks together to keep it from swinging around, and place the top anchorage strap behind the seat with the anchor hook under the seat.
Nov 09, 2007 | Eddie Bauer 3-In-1 with Latch
The Latch Tether difficult to tighten
Could you use the LATCH belt from the last seat that you used when your child was smaller? All the LATCH belts I have seen look the same.
Nov 04, 2006 | Eddie Bauer Deluxe High Back Booster...
Eddie Bauer 22-859 Logo
171 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Nikki  Mclean
Nikki Mclean
woodzowl307
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
