Question about Consew 206RB
Bobbin Threading Hi, I have a new Consew 206RB-5. I followed the directions in the manuel how to thread the bobbin on the side of the machine. The only thing is I turn on the machine and nothing happens. Am I supposed to press something I don't understand.
    New Friend:
I have a singer machine and forgot how to wind the bobbin
Posted on Aug 01, 2011
Pree the foot pedal...
Posted on Jun 02, 2008
6ya staff
SOURCE:
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
Threading the bobbin is not smooth and even and tends to get hung up when sewing, how do I get it to work properly ?
Please post the brand and model of your machine, and a picture of the area where you insert the bobbin.
Dec 13, 2014 | Consew 206RB
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
Threading a consew RB-1 sewing machine
There are a few Consew models listed here http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm maybe one will be similar enough to help you with the threading of your machine.
Apr 19, 2010 | Consew 206RB
I need a downloadable Operating Manual for the Consew 206RB-5
I can not get the top thread to pick up the bobbin thread on a machine I have just bought .It was sewing fine and then the bobbin ran out. I have tried every which way but nothing works which way should the bobbin be winding
Apr 08, 2009 | Consew 206RB
Consew 206rb-1 thread was caught in the boobin area i removed
Had the same problen today, Remove your bobbin, the part where the bobbin is in should move a little, if it does not you have string you can not see behind that part. To get it out turn the machine backwards, it will really turn hard, but will turn, do this until you can see the thread come out or until the piece that holds the bobbin will move a little. good luck
Apr 06, 2009 | Consew 206RB
Bobbin Case will not snap into housing
Insert the bobbin case without a bobbin to see if it will go all the way into the locked position. If it does,the bobbin case and basket are okay.
Check inside the bobbin basket(where the bobbin goes) and see if there is thread or lint wrapped around the spindle the bobbin case sits on. If there is, remove it. If there isn't ,then the bobbin is probably sprung and needs to be replaced.
sewman7
Oct 14, 2008 | Consew 206RB
Consew 206RB, threading problem?
This machine has a safety clutch which is designed to protect the hook mechanism.To access it, place the machine on it's back. About 8-10 inches from the right side you will see an assembly on the main shaft. You need to hold this assembly with a push button located on the bed of the machine while you turn the handwheel. It will click in place when it is in the correct position. Once you've done this the machine should be back in time so it will sew.Hold the top thread ,turn the handwheel and draw the bottom thread up before you begin sewing. Place a piece of fabric under the foot , turn the wheel by hand to make sure there is no binding and that the thread is being picked up.
sewman7
Aug 28, 2008 | Consew Sewing Machines
Bobbin Threading
Divot on needle must be installed facing bobbin case.
Apr 24, 2017 | Consew 199R-2A Sewing Machine
Consew 206RB Logo
256 people viewed this question
Top Consew Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
TCHNICAL SUPPORT FOR...
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
