Question about InFocus LP290 1100 Lumen XGA LCD Projector Multimedia Projector
PROJECTOR STARTS FINE,GOES GREEN,COMPONENT VIDEO HOOK UP
Infocus lp540 goes green after short time,if i disconnect green feed i lose the picture.If i disconnect red or blue,all stays the same.
  • 563 Answers
Hi
Your Mainboard needs replacement.
Posted on Apr 01, 2008
I have replaced new lamp to InFocus LP540 projector, but it still indicating in the LED display "please replace lamp".. and LED is blinking two times as red.. Lamp door is closed properly and the safety...
To reset the lamp timer , press the increase volume button on the remote and the increase volume button within 3 seconds
The maintenance manual is on the infocus web site
Aug 19, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
LP540 Projector Lamp Does Not come on> it has an error message; "Lamp didn't Strike". Does that mean the Lamp/Bulb is bad?
It's most likely the lamp is bad or the part that starts the lamp called a ballast is bad. The LP540 model has an issue with the ballast burning out. The ballast is a part that starts or strikes the lamp. The only sure way to test is to try starting it with a known good lamp.
You can check for signs of a bad lamp. Think about how long you've had your projector & estimate the total hours on your lamp. If it's over 500 it very well could be the lamp as they fail at any time. Remove the lamp cover door & pull out the lamp to visually inspect it. Look in good light & use a magnifier if available too check for any cracks or chips in the small bulb & look to see if the round part of the small bulb is covered with a lot of white or if it's not round anymore. If it's very white it means it has a lot of hours on it. If there's any loose glass inside (check by turning the lamp cage in different directions) then the lamp is bad. If it's nice & clear or has only a small white spot it's probably a good lamp.
I repair almost all Infocus models if you need a quote.
Thanks & good luck,
Jim
Jan 13, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
I have infocus sp5000 and the lamp has stopped working. I pulled it our of the unit and it looks perfect. I suspect it is the lamp counter, but I need a method to reset without being able to see the...
there isn't one. you need to see the menu. but what color is the led and is it blinking?
green- all is well
red blinking:
1 time- lamp not striking after 5x.
2 times- lamp has more than 3000 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fan failure. shuts down.
5 times- undiagnosed error. possibly ballast or colorwheel.
if the colorwheel won't spin, the lamp won't light. when you turn on the projector, do you hear a high-pitched whir? if not, the colorwheel needs replacing.
Aug 17, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
Jun 23, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
LP530 green Iamge
make sure the resolution on the projector matches the input resolution.
Feb 22, 2009 | InFocus LP70+ Multimedia Projector
Infocus LP540 --- display
It sounds like you may be feeding it with an HDMI source using an HDMI to M1-D adapter...
If this is the case, make sure the source in not set to a resolution higher than 720p.
However I really need more information to offer a definitive solution.
Take Care!
Sep 17, 2008 | InFocus SP-LAMP-017 Projector Lamp for...
Infocus lite pro 720
Sounds like the LCD inside is dying and you're losing pixels. Bummer.
Aug 31, 2008 | InFocus LP70+ Multimedia Projector
Projector InFocus LP540
ask the guys at GOTABULB.com Through e-bay they are very good in america
Aug 29, 2008 | InFocus SP-LAMP-017 Projector Lamp for...
LP540 Infocus PRojector
first try a new vga cable. if the problem persists, go into the menu and find the settings to that computer output. chances are it's on component. set it to vga. if that doesn't help, reset back to factory default, then set it to vga.
May 01, 2008 | Toshiba TLP 261 Multimedia Projector
LP540 INFOCUS
good luck. not even the infocus authorized service centers get those. besides, they were made by another company that does not make power supplies antmore. and infocus doesn't have any new ones in stock. if you're getting no power at all, replace the mosfets. it works half of the time.
Sep 20, 2007 | InFocus SP-LAMP-017 Projector Lamp for...
176 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
