Question about Medion MD 7317 17" Flat Panel LCD Monitor
MONITOR MEDION MD7317 NOT WORKING
MY MONITOR MAKES A NOISE AND HAS A FUZZY SCREEN. i JUSTED UNPLUGGED FROM ONE ROOM AND MOVED TO ANOTHER ROOM. NOT SURE WHAT HAPPENED.
  • 736 Answers
I have some 19 inch medion monitors that have the same problem .. they make a lot of noise and the screen might be jittery/fuzzy ... i found the following:
several capacitors in the power supply (inside the monitor) had their tops buldging .. that shows that internal pressure was high in the caps, usually caused by them being hot and thats caused by high internal leakage .. the caps may eventually blow out the tops (explosion vents) .. the caps are designed to do that instead of becoming a bomb ..
all the bad electrolytic capacitors i have seen so far on these monitors, motherboards and other electronics have been chinese made .. they made millions of bad caps over several years ..
almost all the bad caps had buldged tops but not always .. once in a while i see one thats open but not bulbged .. probably venting elsware ..
i changed the obviously bad caps and the monitors returned to like new performance ..
i dont know about the 17 inch but the 19 inch medion flat pro display is not too hard to take apart .. about 30 screws or so ... speakers have to be unscrewed and you have to be careful not to stress cables that go to the push buttons .. of course you have to know how to solder without bridging paths
Posted on Sep 29, 2008
My Angelcare monitor was working fine for 1 month. Then I went to unplug it to move my crib to another room, went to plug it in and now it makes a weird constent beeping noise?? What is wrong with it the 2...
Without inspecting this item it is impossible to diagnose the problem. If the product is under 12 months old please return it to your retailer with proof of purchase.
Sep 10, 2011 | Angelcare Deluxe Movement Sensor & Sound...
Medion monitor won't come on
inverter has gone .cheaper to buy another monitor
Apr 26, 2010 | Medion MD 7317 17" Flat Panel LCD Monitor
Medion akoya MD 96640. started with the screen going fuzzy and the whole thing locking up till the only way to switch off was to pull the battery out. Now when you switch on the lights light up and the...
Same problem with my sons 96640 In at Medion now waiting for supplies of new motherboard to come in-from what I have read elsewhere the graphics chip causes the same problem on other laptops, not just medion
Jan 20, 2010 | Medion Computers & Internet
Computer not booting properly.
try taking out one of your ram sticks and boot up.
Mar 03, 2009 | Medion MD1777 (MD1777C67) PC Desktop
Monitor lcd acer al2016w 20" letters and image are fuzzy,,why?
I also have an Asrock motherboard (M266A) and have the AL2216W. The image and text is also fuzzy. I did improve it a by by unplugging/replugging all of the connectors on the back of the computer. I believe my mouse had a somewhat loose connection and this was causing interference. I can actually create interference on screen by moving my mouse up and down.
These Acer monitors seem to be very sensitive. I also tried this monitor on a old Desktop with Win98 and another new laptop with XP and it looks good on those computers, but not on my Asrock based system.
Nov 30, 2008 | Acer AL2016W 20" LCD Monitor
Medion MD7317 17 inch Flat Panel Monitor
My MD7317 did the same thing until I actually installed the driver for it. My windows did not have the correct driver in it's driver base, so I found the driver online ( took a few minutes of searching) and within a few minutes of installation the monitor displayed a great colorful picture. Naturally, I had to use another monitor while I was searching. Driver is about 3.3 megs. It came in a zip format. I did not keep track of the link to driver, but it omly took a few minutes to locate it.
Jun 12, 2007 | Medion MD 7317 17" Flat Panel LCD Monitor
Kogi Monitor with fuzzy text
Here is one small solution. goto start: -> control panel -> display click on the "appearance" tab. then click on "effects" check the box that says: Use the following method to smooth the edges of screen fonts (and make sure to choose "cleartype") You should notice the fonts are a little sharper as well as having a backdrop.
Mar 23, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
The blue light of the monitor keep flash and no picture appears on the screen
I have exactly the same problem with my Medion 17" TFT monitor. It is not the video card (tried changing it) or the motherboard. Fitting a different monitor makes the problem go away. The monitor does not display the "No Signal" message when unplugged from the PC either. It must be a fault in the monitor, and as it seems to be a design fault. I suggest you contact Medion and nag for a replacement.
Dec 06, 2006 | Medion MD 7317 17" Flat Panel LCD Monitor
Medion MD 7317 17" Flat Panel LCD Monitor Logo
276 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
