Lowe's Item Number: 140389
My 40 gal hot water heater wil not work the water wont get hot we just installed it
  • 168 Answers
Assuming you have waited a couple hours and the water is still not getting hot there are too many different reasons that the tank might not be heating. Is it Gas or Electric? Is the burner on? Is the thermostat set to turn on, or set to a higher temperature? if you open the water valve at the bottom of the tank, check to see if the water is warm, cold, or hot. (POSSIBLE BURN HAZZARD BE CAREFUL so dont put your hand under the valve and open it, have it pour into a container, and then touch the water with a stick, and then touch it to your hand or some other safe way like that)
Check the simple things 1st, like if its Gas, that the gas valve was turned on, or if its electric, then then electric was turned back on etc.
More info would be needed to help you further.
Good luck
Posted on Feb 03, 2008
I have no hot water, how do I change the filter in a Bock Water Heater 32E 32 gal oil-fired hot water heater ?
Unfortunately, looking at the manual for the water heater, the filter is a separate item. And the recommended Delavan line filter page just shows a picture and part numbers of the item, not how to remove it.
I suspect it works in such a way that you hold the end nut portion and turn the large nut portion with open end wrenches. You will need the internal filter replacement and possibly new seals, probably in a kit.
Line Filter
You'll want to turn off the power to the oil pump so you don't make a large mess.
Jul 20, 2016 | Water Water Heaters
Pilot light will not stay lit. already replaced thermal coupler. 6 gallon
A thermocouple makes 30MV power by a temperature differential across the end of the thermocouple, many times people set the entire end inthe flame heating the entire end thus dropping out the power, you cannot bake them into working there must be a temperature differential from the base to tip about a 1.5 inch section. It wil not work correctly if the entire end is hot.
Otherwise the gas valve is bad.
Nov 06, 2013 | Atwood 10 Gal LP Gas /Elect. WATER HEATER
I have a 640dors reliance capacity40 water won't stay hot long(electric)
remove the two covers one high and one low and set the temp higher. This time of year with colder water comming in the house the water heater has to work harder to raise the temp of the incomming water. In the summer the incommong water is much warmer. 40 gal is a small water heater and you will only get about 15 gal of hot water with the ice cold water entering the water heater as you use the hot water. You can get a bigger water heater. even better is to go tankless and a have never ending hot water and save money at the same time.
Jan 10, 2013 | Reliance & 40 Gal Electric Mobile Home...
Atwood Hot Water heater wont' shut off
sounds like defective thermostat/gas valve
Aug 05, 2012 | RTO Atwood Water Heater - 6 Gal LP
No hot water
test the thermostat and the heating elements --also there are resets that can pop push and make sure they have reset
May 17, 2017 | Water Heaters
They worked on our city water and now i'm getting no hot water... before that it worked but i don't think to capacity.. it wouldn't fill the tub before getting cold.... it is a rheem 50...
As long as the water heater is not leaking or not big enough that would be the only reason to replace heater. If you are running out of hot water or it's cold, check the power source first to make sure you have power to heater. Then check the reset button on the top thermostat and make sure it's not tripped if it is it wil not heat. If so press red button aloow it a little time check for hot water.
Next step woul dbe to turn power off and drain water to replace both elements out. Once changed out turn water back on and open a faucet to remove air out of the wtare lines. Once you get water flowing out of water lines now you are ready to turn power back on. allow about 30 to 40 monutes and you should have hot water.
Jul 09, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem RHEEM 50 GAL ELEC TALL Water Heater 1.5 yrs old, power at the elements, new elements installed new thermostat installed, still no hot water.
Hello Check the red overtemp reset button at the temp control.Check for contintuity at the elements with a volt meter (pull one wire off first) they should have a reading otherwise they are open & shot.Last is overdrawing (busted pipe) shut off the cold water supply for a 1/2 hour and open it back up and feel the hot water supply pipe.Is it hot?The tank can't keep up with the demand.
Sep 16, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
No hot water
I am afraid that you have burned the heating element out or an inline fuse is burned out
May 15, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
No hot water
Take these steps, ensure you are recieving correct voltage to the heater. If this has been confirmed, then using an ohmmeter, with the power turned off, check the resistance through you heaters. You should read a resistance through the heater(s). If you read OL, it means the heater is broken, and if you read 0 the heater is shorted. Hope this helps
Mar 29, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Heating & Cooling Logo
579 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
