Question about Dryers
Need instructions on how to change gas dryer coils.
  • shurachai Jun 06, 2008
    I have a Maytag model number MDG7600A. How do I get into it to change the gas coils?
  • 240 Answers
Im not sure what type of unit you have, but most are the same once you get into the dryer itself. On the top of the gas controller, you will see the two round gas coils probably under a chrome or metallic plate. Remove the screws from this plate and remove. Unplug your gas coil wires, remembering which coil goes where. Slide the coils off, then slide new coils in there place. Replug the coil wires, and reinstall the metal hold down plate. Turn your gas back on, replug the unit and let run for a few minutes. Sometimes you may have to wait a few minutes for the gas to correctly start flowing, so dont be worried if it doesnt start right off the bat. Good Luck. If you need further information, send me a model number and make of the dryer.
Posted on Feb 02, 2008
The drum turns. It heats up. But only small loads of cotton get dry! We have changed the vent tube. Vacuumed the vent the lint catcher area and around the drum to remove lint and hair. Still not...
A very typical problem with GAS dryers is the soloniod coils that open the gas valve . When the coils are cool they operate just fine,but once the dryer gets warm from running the coils dont open the gas valve wwhen they are warm. If that is what your experiencing,the dryer heats when its cool but doesn't heat when it's been running for a while,the coils on the gas valve will need to be replaced.
GENE
Aug 16, 2011 | Roper RGX4634KQ Gas Dryer
We have a Kenmore gas dryer model #76832500. The ignitor glows and the gas will light for a short period of time and then go out. Once the dryer cools down it will light again. Our manual shows there...
The 3 pin coil is your booster and holding coil and it ignites the 2 pin secondary coil. Is the flame blue or yellow? I would change both. Coils are a lot cheaper than the whole gas valve assembly.
Make sure to check the dryer's airflow. If the dryer is ducted, pull the machine away from the duct and try starting it again. Does the dryer have some sort of electronic control which is sensing an error and terminating the heating circuit? If there is it would be a box type thing located near the gas valve and it would have lights flashing on it. If that's the case, it's a new problem in itself as you would need an error code listing to begin looking.
Assuming air flow is good and gas supply pressure hasn't dropped (also check that gas inlet hose is kink free) and it is the coils that are failing, change both and fix your problem
Aug 29, 2010 | Kenmore Dryers
Cold dryer
if the dryer runs normal for the first 15 to 30 minutes you have bad gas coils located on the top of the gas valve,take out the 2 phillips screws,remove the top cover and change out the gas coils.when the coils are failing they will work until they heat up then they stop letting the gas come into the dryer,when they cool down then they will work again.change out the gas coils part number 279834
Mar 27, 2010 | Kenmore 73952 Gas Dryer
Coil replacement
I'm not an expert but assuming you ordered the coils for your dryer your dryer must have them. I just finshed repairing my kenmore gas dryer after about 10 minutes the gas would shut off. This is becasue the coils that are on top of the gas line before the ignigter were defective. The coils control the gas valve and when my dryer got hot the coil being defective would close the valve. There are 2 coils a 2 prong and a 3 prong. Remove the front panel to gain access to the bottom of the dryer from there you will see your coils about as round as a quarter and 10 or so high. unscrew the screws holding down the retainer and undue the electrical clip. reverse for the install. good luck!
Dec 13, 2009 | Kenmore 72802 Gas Dryer
Gas dryer will not stay warm for long
Hi, You will need to replace the coils on top of the gas valve.
There is a small plastic cap that you can remove in the lower front panel. Start the dryer and see if the ignitor glows and shuts off before the gas ignites. If this is the case, the coils need replaced. This is a very common issue with the gas dryer.
Here is how to change the coils:
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jul 10, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool model #WGD5500SQ0 heats up, then goes cold and doesn't heat up again.
Hi, You will need to change the coils on top of the gas valve. They overheat and will not open the gas valve.
Here is instructions on get to the coil.
Thanks
Vic
Jul 10, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
Thanks
Vic
Jun 01, 2009 | Dryers
How do I take off the front panel of dryer so I can install new coils
There are no coils in a gas dryer only an ignitor and, gas valve
Heating coils are only on electric dryers
May 21, 2009 | GE Dryers
Gas LG dryer works fine, but heat wont stay on more than a minute. then if i try to start it again, the heat wont come on at all. if i wait a few hours, then the same things happens again. heat comes on,...
First, check to see if there is strong air flow out the house at the exterior dryer vent. It is very important to have good air flow for gas dryers. Second, if you do have good air flow and you do get ignition but the burner shuts down quickly and won't relight, the most likely cause is the coils on the gas valve. They heat up when current passes through them and can open up electrically. When they cool down, the process can repeat. The coils for LG gas valves are not available as separate parts. You have to order a complete gas valve, but you can then take the coils off the new valve and swap them out onto the original valve so you don't have to change out the entire valve. If you need instructions on how to get at the gas valve, let me know (with your model number).
Remember, check your air flow first !
Please rate this solution once you have completed your repair. Thanks.
Dec 12, 2008 | LG DLG5932W Gas Dryer
Dryers Logo
176 people viewed this question
Top Dryers Experts
Marvin
Marvin
