Question about Canon PIXMA MP830 All-In-One InkJet Printer
Cannon printer mp830
Error code 6A00 My scanner is not operating at all. I'v only owned it for 1 yr. and hardly use it. I get no error code but I do get the message Scanner not operating correctly.
    Sergeant:
  • 201 Answers
Hey there praymoss, if your OS is Mac X, v10.5, scanning from the unit's main operation panel, or from MP navigator / MP Navigator EX may not be performed., You can however bypass the issue by launching scanner drive from the TWAIN application, such as Image capture / Arcsoft Photostudio to perform Scanning. Good Luck!
Posted on Feb 02, 2008
    Genius:
  • 3,422 Answers
HI,
Well I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You will NOT be able to resolve the problem yourself.
I had the same problem on a brand new MP830. I brought it home, tried to do the easy setup steps, and after I installed the ink cartridges, the print head moved to the right (home) and then I received an error saying that I needed to install the ink tanks (which I just did!). After a restart, I was stuck in the 6A00 wilderness. After reading this thread, I realized that the issue had to be the purge unit. On my MP830, the purge unit is a white plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail. I moved it back and forth (actually forward and back) about 5 times, closed everything up, and after a restart, all is well. Note the the purge unit is NOT the print head!
Goodluck,
Please don't forget to rate me as fixya..
  • Priya darshan Feb 02, 2008
    You can also check this link below if u want..
    Click here
Warning light ON. Error messages:6A00, 5100,
regarding cannon printer mp830: how do I get to the printer carraige?
Jan 14, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I have a canon mp830 error code 6a00.
That error means the purge assembly is jammed. Check for paper caught in the right side where the printhead parks, if all clear you will need a new purge assembly. A shop repair for sure....
Dec 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
On printer screen it is showing Error 6A00 and error code. Whats does this mean and how can I fix it
In my IP 3000 during a print suddenly on the 3rd page, a big "crunch" sound. Paper was jammed - error 5100 or smthg, and managed to remove the paper... but then error 6A00 came up. I found this post and was saved. Manually moved the print head left and right, turned the printer on/off. Still the same error. Then I noticed a piece of torn paper lodged inside. Removed that, got inky fingers, and finally got printer in working condition.
Try to clean any foreign object inside.May be it can help you.
Sep 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printer reads error
Hi
Hope you come back for this
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 11, 2009 | Canon MP830 All-In-One Printer
Error Code 6A00
6A00 is a purge unit fault, if you have have a years canon warrenty i would call them and get a engineer out to investergate the fault, If not strip machine and and see if the purge unit is moving back and forward. it could be that the carriage unit is stuck on the purge and the carriage unit cant move.
Hope this helps
Apr 26, 2009 | Canon MP830 All-In-One Printer
I have a canon mp830. I had the 6A00 error code.
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Feb 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannon MP830 multi function printer Error code 6A00
6A00 is a problem with the sheet feed unit.
There is a flaky sensor .
Check the paper path to see for any stuck bits of paper.
Oct 19, 2008 | Office Equipment & Supplies
Canon PIXMA MP830 All-In-One InkJet Printer Logo
112 people viewed this question
old marine
old marine
