Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Spectra Gas Oven Problem
Oven won't light when u put dial on a certain setting,used too. Put the dial on broil and it lights right up.
    Novelist:
  • 130 Answers
Harley2457 you propably have a bad bake ignitor. Remove the floor inside the oven to access the ignitor.
Posted on Feb 04, 2008
GE gas oven spectra xl44 takes forever to preheat &sometimes will not
The way the oven works is like so:
1) User sets the desired temperature
2) Power is sent to the ignitor
3) The ignitor is then energized, drawing 3.2 amps of current
4) When the 3.2 amps is drawn, the gas safety valve is allowed to open and gas flows into the burner assembly in the oven.
5) This gas is then ignited, causing the oven to heat.
6) As the oven heats up, the oven sensor, which is the metal rod located at the top on the rear oven wall, converts the heat into an electrical signal, relaying this information to the main control which in turns displaying the temperature.
(In models with a dial thermostat, there won't be a sensor, though a metal wire with a bulbous end will be present, which is actually connected to the thermostat.)
Will all that said, more than likely the ignitor is bad in the oven, not drawing enough amperage to allow the safety valve to open. Even though the ignitor is lighting up and glowing, I'm 99% certain that this is the problem. Here is the part number for ignitor. WB2X9154 and can be ordered from any parts distributor or from a local supplier.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 21, 2012 | GE Profile Spectra JGBP90 Gas Kitchen...
How do I remove a GE oven door, gas model number JGBP29WEJ1WW
With most gas ranges, you simply put the door in the "broil" position and lift the door from its moorings. To find the broil position, slowly open the door. You will feel a slight resistance when it is opened about 2-4 inches. This is the correct position for broiling foods, hence the name "broil position."
Nov 15, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
No broil or oven cook top works
try checking the ignitor or the thermostat in the oven.
Sep 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Do you kep door closed when broiling
Hi, yes, your oven door should be closed , at all times whenever you're using it, otherwise your home will become oven, use oven thermostat to maintain temp, door should be closed, especially on broil. knob you turn, to light oven is also a thermostat. good luck.
Aug 10, 2009 | GE Spectra JBP78 Electric Kitchen Range
GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Jun 12, 2009 | GE Ovens
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Oven and Broiled will not light - GE JGBP30 oven
I think it was the 'Guest' who commented on this and we just exchanged information again.
You can read it here:
GE Oven-Broiler problems
Feb 08, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Where do I light my gas oven?
Hello Slacker3158 how old is this oven? I only ask as GE hasn't built a standing Pilot range in over 18 yrs. The issue may be a bad oven ignitor. Put the oven on broil, if it works then the bake ignitor is bad. It is found under the bottom of the oven. There is 2 to 4 screws inside the oven that allows the bottom to be removed.
Feb 03, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
80 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
