Question about HP Pavilion dv6000z Notebook
Compability issues between Vista OS and Western Digital Passeport 2.5
I was running the aformentioned WD Passeport 2.5" mobile drive on my laptop running XP Professional and this mobile drive was running perfectly well, this laptop is dead now (crack mother board), I have now a new laptop with Vista OS, unfortunately it cannot find my mobile drive thus I cannot access my files. For some reason my new laptop can read any other mobile devices such as san disck 2GB USB jump drive but not my WD Passeport mo
I contacted WD they don't have a clue, I contacted Gateway they sent me a quick fix thinking it was a USB port issue but that didn't help.
Do yo have a fix?
  • ThierryB1956 Feb 02, 2008
    No I didn't formated this drive using Windows XP, I plugged the mobile drive to the USB drive of my laptop and copies and schronized the file over time!
  • Zeata Apr 04, 2008
    I have a Toshiba Satelllite that came preloaded with Microsoft ( I hate it) Vista. After uninstalling all the USB devices in device manager the laptop was able to see my standard USB Junk drives as well as my san disk and IPod. It will not locate my and run my Western Digital USB 80 Gigabyte drive.
  • 43 Answers
Has this drive been formatted using Windows XP?
Posted on Feb 02, 2008
  • Gregory Young
    Gregory Young Feb 02, 2008
    If you have not formatted the drive,it could be a problem because with Vista it will not recognise the MBR_LDR.
    Try formatting a new partition & install any know drivers for the unit
I got a HP DV6833us. Originally has a WD scorpio blue drive (don't remember which model) and running Vista (OEM). the hard drive is dying. I want to replace it with WD2500BEVT from Best Buy. On WD...
Note: If you cannot find drivers for your WD drive, it may be because most WD drives do not include drivers as they use a standard driver built into the OS. If the driver is built into the OS or is already installed and the OS continues to look for a driver, your drive has most likely failed or been damaged and needs to be replaced.
According to Western Digital: "Most current WD drives do not require additional drivers on the Windows or Mac OSX Operating System (OS) beyond the ones that are included with the OS."
In order to simplify the installation process WD elected to use the standard drivers that are built into common operating systems. While there are a few exceptions to this, in general, there are no drivers provided by WD for our drives. That's because the drivers a WD hard drive or SSD uses are part of your Operating System. As such, any trouble with these drivers should be handled by the regular line of support for your operating system - in most cases by contacting your system manufacturer, IT department, or the publisher of your OS.
Internal Hard Drives and SSD: All internal Hard Drives and SSDs use drivers that are built into the operating system. There are no drivers available for download because of this. If your internal drive is not recognized, it can be caused by one of the following problems:
  1. During an operating system installation, it may not see your drive at all or may request a driver. Under Windows you will need to press F6 in order to be prompted to enter a driver. Once you are prompted for a driver you will need to remove your Windows CD, and place a CD with the drivers for your SATA or EIDE controller card. These can be obtained from your System Manufacturer (Dell, HP, Toshiba, Gateway, etc.) your motherboard manufacturer, SATA or EIDE card manufacturer (if it is connected to a PCI or PCIe slot). Western Digital cannot assist you in locating these drivers, as every controller card requires a different driver.
  2. Your driver may be corrupted. The symptoms of this problem can vary - if it is your boot disk, your operating system may fail to load. If it is a secondary drive it may request a driver. You will need to contact Microsoft or your System Manufacturer for assistance in resolving this issue.
  3. Your drive may be damaged or have failed. A good test for this is to try the drive in another system. If the issue continues to occur, then this is most likely the case.
Sep 16, 2011 | Western Digital WD Scorpio Blue WD2500BEVT...
Need driver & software
The Driver and software are built in, Stored on the WD it's self..
all you need to do is plug it in. It is a plug and play device.
WD Passport is not supported on XP or Vista 64bit
Xp and Vista do not put enough power to the usb ports to fire up the drive.
there is a cable you can get from WD that plugs into 2 USB ports to solve this issue.
Jul 02, 2011 | Western Digital WD Passport 250GB Portable...
I have a WD3200ME external driver..it works on vista but when i changed my OS to windows 7, it cannot be read..then i go back to windows vista thinking it could be read but the same thing happen.. it says...
If your WD external drive is not recognized, it can be caused by one of the following problems:
  1. Your driver may be corrupted. The symptoms of this problem can vary - The majority of the time however, the drive may request a driver, or will not appear as a connected device. You will need to contact Microsoft or your System Manufacturer for assistance in resolving this issue, as we are unable to provide assistance in diagnosing your OS.
  2. Important Information: It has been reported to us that some users have been able to resolve this issue using the SFC Command in a Command Prompt. When contacting Microsoft or your System Manufactuer, providing them with this information may assist in resolving this issue. Please note that WD Technical Support cannot assist with the usage of this command line program, and is not responsible for any damage to your system or data it may cause.
  3. Your drive may be damaged or have failed. A good test for this is to try the drive in another system. If the issue continues to occur, than this is most likely the case. For assistance replacing your drive under warranty see Answer ID 8: How can I replace a product under warranty?.
  4. In some cases you may need to install a drive in order for your drive to be recognized. Check the table below to see if your model drive requires a driver to be installed besides the one that is included in your Operating System. Please note that this table includes any drive that has a driver for any reason.In most cases the drivers listed are not required for the drive to function, but add some additional funcationality that the OS supplied driver cannot provide. If an OS is not listed in either column, your WD external drive is not supported on that OS. If a driver is available, select the OS in the list to go to the download page for that driver.
Microsoft Windows 64-bit Operating Systems working with Western Digital hard drives trnsp.gif Question Do Western Digital hard drives work with Microsoft Windows 64-bit Operating Systems? trnsp.gif Answer External Hard Drives
Our external hard drives should work with 64-bit operating systems. But, again, there are some things you need to keep in mind:
  • Drivers for most Western Digital USB and FireWire external hard drives are already included in all 32-bit and 64-bit Microsoft Windows operating systems.
  • When Western Digital drives are connected to the computer, the operating system should automatically recognize that there is a new device and install the drivers for that device to function on that system.
  • Western Digital does not provide any generic drivers for our external hard drives in the event that the system drivers do not load properly.
  • In the event that one of our drives does not install on your operating system, here are some simple troubleshooting tips you can follow:
    1. Plug the power adapter directly into the wall to make sure the drive is getting enough power.
    2. Change the USB/Firewire cable to make sure that the cables aren't bad.
    3. Try the drive on another PC. If the drive installs on that PC, and you can see it in the Windows Explorer, then you know that the drive is good.
    4. If it doesn't show up in Windows Explorer, but does show up in Disk Management, then the drivers are installed and you most likely have a format or partition issue. In which case, please see:
    5. If the drive doesn't show up in either Windows Explorer or Disk Management, then the drive should be replaced.
  • If the drive shows up on another PC, then there may be driver issues with the operating system where it's not installing. You will need to contact Microsoft Support at http://support.microsoft.com for further help troubleshooting your operating system.
Dec 21, 2010 | Computers & Internet
New laptop wont recognize external hard drive files
What program was used to 'Back them Up"?
It may be an incompatibilty with Vista and you should contact the backup programes support arm to get a converted fix for Vista
Please rate our help to keep FREE service online
Aug 30, 2009 | Western Digital My Book Essential Edition...
Ibm t43, xp pro won't recognize my WD my book
please write down the error and contact me now
anaesarora online
Feb 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
320GB WD passport essential works with XP os but not with vista
both of my vista machines worked perfectly... i am not using the software that came on the drive. as a mass storage device it works perfectly.
Jan 29, 2009 | Western Digital Passport WDXML800UE...
Problems with Western Digital My Book 1000 GB Hard drive on Vista
download a free hard disc eraser program erase the disc space, you do not need wd`s software. then reformat the drive from vista choose ntfs format
Jan 23, 2009 | Western Digital My Book Essential Edition...
WD Passport Elite 320 - won't install autobackup launcher
I just spoke to WD support...here is how to solve your problem:( I had the same problem and it works great now)
1. Connect your WD ext. drive.
2. Click open Computer.
3. Double click open the WD blue icon.
4. Double click open WD_Windows Tools.
5. Double click open WD drive manager.
6. Double click open the Setup icon for Vista 64 (the other icon
is for x86 windows)
run the setup and it will take care of your problem. enjoy!
Dec 01, 2008 | Western Digital Passport WDXML800UE...
Western Digital WD 1200VE; 120 GB external hard drive unable to boot
good eve prapad dont worry for your data ,first if you have a boot cd ,owerrite the OS ,then select repair option,it is occures due to 90% OS currupt ,
regards prasanna
Mar 05, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
