Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Grinding noise, sounds like a bad bearing. Need replacement instructions.
  • 1 more comment
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    If there are oil stains showing up on your clothing, it can mean that the tub bearing seal has been breached and water has gotten inside it. When this occurs, a brownish colored stain starts to appear on your clothing and inside the wash tub. This is an early symptom of a tub bearing going bad.
  • Jeff Rockwell
    If this is a front loading Neptune, it doesn't have a snubber. The advice I gave was based on the heading you used above. Is the washer we're discussing a Maytag Neptune?
  • Jeff Rockwell
    Not a recommended repair job for the average do-it-yourselfer. I'm not trying to insult your abilities in any way, but this job requires the replacement of the entire rear tub shell if the bearing is bad. The bearings do not come out, as they are molded into the plastic of the tub. The tub shell alone, could run over $200 (just for the part). It is also recommended that you replace the tub seal and bearing seal at the same time. You will need to disassemble the entire washer which involves removing the the door, top of the casing, tub supports, counter weights, drive pulley, belt and entire wash tub assembly. You may reconsider if you want to attempt this repair or not. Let me know if you do...sorry, I hate to discourage anyone, but this is quite involved and usually takes an appliance repairmen a couple of hours to do.
I just replaced the two tub bearings and the seal and wax motor. It took a while to figure out how to get it apart but after getting the inner tub out it went pretty quick. $24 for the seal (you get 2 in the kit: for a 'new' syle and 'old' style spinner).
You will need BIG hammer and a large chisel with a flat nose but it made me feel good to beat the crap out of it to pop the bearings out.
Now works great. (High speed spin had incredible vibration and seal leak was obvious). I did not know it took special e-soap to make it happy).
Posted on Mar 04, 2008
Oil stains appear on closthes after they are washed, can you tell me why? thanks
Posted on Feb 09, 2008
Question:
Do I need to change the Snubber
Posted on Feb 05, 2008
6ya staff
SOURCE:
2003 GMC Yukon- when driving I have a weird grinding noise in lower speeds and then again when driving around 50-60 mph. it does seem to affect the steering wheel as well. Now when turning left the I get...
It sounds like a wheel bearing is going bad. They are easy to change. If you have a place to jack the vehicle up. Try spinning the front wheels. You should hear a scraping noise as the wheel turns.Also replace both sides at the same time,as the otherside is not far behind.
Oct 01, 2017 | 2002 GMC Yukon XL
Noise on front driver side and i replaces rotors and brakes
may be the backing plate is hitting. or it may be the wheel bearing is bad. check by making turns and see if the noise goes away or starts grinding like a washing machine. IF grinding is worse replace wheel bearring.
Apr 16, 2013 | 2005 Pontiac Montana SV6
Metal flakes in transmission fluid and grinding on front passenger side
sounds like a bad output shaft bearing in the trans but if the trans fluid is burnt then yes you need a rnr overhaul done sorry for the bad news
Jan 08, 2018 | 1999 Ford Explorer
Defy autodry tumble dryer
This will be bearing noise, the front of the drum uses a felt strip as a bearing and this can wear causing a metal on metal grinding sound, or it could be the rear bearing. You need to dismantle it to investigate further.
Mar 06, 2012 | Cell Phones
My son has a 2002 GMC Sonoma crew cab that is making a grinding noise when making turns, both left and right. This may be an unrelated problem but the tires are also squealing when taking off from a stop,...
the grinding noise sounds like the axle shaft joints are no good and need replacing.also the wheel bearings could be so bad that they are causing this problem.i have seen where badly worn out brakes have made a grinding noise on turns.the tire squealing i don`t think is related to the grinding noise.check out the other things just in case it is changing the tire angle which could cause squealing.
Apr 05, 2011 | 2002 GMC Sonoma Extended Cab
Hub making grinding noise tie rods need replacement
A grinding from the hub sounds like a bad wheel bearing.
Jun 01, 2010 | 2001 Buick Park Avenue
Hear a grinding noise from the right front wheel when I make left turn (mostly). Noise has now progressed to anytime the wheel is in motion. Also hear squeeking sound (ball bearing possibly?). I've changed...
You should definitely pull the front wheel and check the bearings (they are roller bearings, not ball bearings). With the wheel off, you should be able to isolate where the noise is coming from, but I vote for the bearings. Check, replace and/or repack, and adjust properly. If you have noise, you should be able to feel the "play" in the bearings, or see the wear problem on the spindle and bearings. I hope this helps you.
Oct 30, 2009 | 2000 Nissan Maxima
Focus GRINDING NOISE during excellaration
I had the same exact problem with my 2003 Focus with 108,000 on it. Making right turns and accelerating was even worse. Had many ideas from differant mechanics saying it was wheel bearing, steering rack, loose heat shields, transmission...ect. Well after having wheel bearing replaced and steering rack replaced, the grinding was still there. It was finally discovered that the noise was coming from a bad motor mount on the right side. Had the dealer replace the motor motor mount and finally!!! the problem was solved. Thank God.
Apr 25, 2009 | 2003 Ford Focus
Grinding noise in the left front wheel while turning right - gets more noticeable the harder the turn is. Checked tire clearance - no problem, but it's not a rubbing noise but a grinding noise. No problem...
grinding on front wheel is caused by 2 things. a bad or loose wheel bearing,or worn out brakes, have them both checked
You might also want to check the level of fluid in the power steering reservoir - low or lack of fluid will also cause a noise (although more of a whining than a grinding).
Jul 29, 2008 | 1999 Volkswagen Cabrio
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
115 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
