Question about Frigidaire Affinity ATF7000E Front Load Washer
Error / Pause Affinity ATF7000
I have had this machine about a year, the machine stopped while on a cycle and flashes pause and err, I have tried to hit the start / cancel buttons simultaneously and I receive 3 beeps, otherwise the machine is unresponsive. Is this a control board issue? Please Help!
  • Anonymous Feb 09, 2008
    my washer doesn't start it continuously shows display err ,pau then shows minutes. i have hit cancel and every other button no matter what i do turn the knob press any button i get the same thing err then pau it will whow minutes of the setting like 56 but when i press start it displays err again and again. i just need to know how i can erase memory to start all over
    new again
I had the issue with my Affinity ATF7000 washer displaying err pause err pause .... clicking any button would give me 3 beeps and lights would flash but would get no real error message. Repair man wanted to replace entire computer for $250 plus service call rate. So by dumb luck I did this and got it working.
1. Unplug washer
2. Take off top (screws on back)
3. Unplug connector to the pressure sensor (carefully). Looking at the washer it is mounted to the right side near the front and looks round when looking at it from the top.
4. Plug in the washer and it should display E31. E31 is just saying it cannot communicate with the pressure sensor (which makes sense because you unplugged it).
5. Unplug washer and reconnect pressure sensor.
6. Put top back on and plug in washer.
7. Washer should work but E31 error will remain in memory so if you do call a repair man he may think the pressure sensor needs to be replaced. There is a way to clear error codes but I could not get it to work.
This is my theory on why it worked. The computer program on the washer is stuck in a loop that will not allow the washer to function. When we unplug the pressure sensor we give it a real error and it exits the loop it is stuck in. I am a programmer by day so this may not make sense to some.
Posted on Feb 23, 2012
Frigidare affinity washing machine, piece of crappola...
anyway, tried this fix with the unit unplugged, didn't work, tried it again with the power on (be carefull, it looks like there is a 110 volt relay in the latch unit), it worked (didn't wait six minutes, worked anyway).
To take the door seal off, on the outter edge (towards you when you are looking inside wondering if you should really do this) there is a small metal ring that goes all the way around. On the bottom of this ring there is a spring, take a small flat head screw driver and work it under the ring, lift it over the edge and the door seal will come off. (wifey figured this one out)
John
Posted on Jan 01, 2009
OK i had this , 2 times, take the seal off and then take the door latch off and unhook all the plugs and wait 6 min then rehook everyhting and turn it back on and wait a couple min then try
Posted on Feb 15, 2008
Keeps pausing
Hello Friend, this is Z. Thank you for your post!
If you are receiving an error code PAUSE, it commonly indicates that the door of your washer is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If these basic troubleshooting tips prove ineffective, try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your washer. If the issue persists, then your washer could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Jul 18, 2014 | Frigidaire Affinity ATF7000ES Front Load...
MY FRIDGIDAIRE AFFINITY KEEPS PAUSING DURING CYLES DOSENT MATTER WHAT CYCLE I CHOOSE. IT STOPS ATLEAST 5 TIMES PER CYCLE AND SOMETIME WONT FINISH THE CYCLE. MODEL NUMBER FAFW3801LW3
Hi Brooke, thank you for allowing me to assist you!
Often this happens because the washer door is not securely latch or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If the issue persists, try reprogramming the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn the unit back on. If issue persists, then more than likely the unit has a faulty door latch, a communication error with the control board, or a potential wiring failure. You may wish to reach out to an appliance expert who is best equipped to pinpoint the exact problem, which can often save you funds and a headache.
Best regards!
Oct 30, 2013 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Affinity Washing Machine, 3 months old, pauses during cycle. Does not give any error code. Have tried different cycles, eventually it will run the cycle. Doesn't happen with every cycle, yet. Switches...
Did you figure out this problem? I think these machines are JUNK! We purchased our first Frigidaire Affinity in April 2010 & by September it started ripping our clothes apart. Not every cycle. At first we thought it was the dryer but nope - it was the washer. Something to do with the drum. We had it replaced in October 2010. Then after the truck dropped off the replacement, I tried doing my first load of laundry. It lite up & did nothing. Something to do with the motor. Again, we had a 3rd machine replacement. I wanted to give up, get my money back & go buy something else but I wanted it to match my dryer so I was kinda stuck. Our 3rd machine is now going to pause constantly during a cycle. I've read up on it & tried various things such as less soap, checking the drain etc. & nothing has changed this problem. I'm calling the store on Monday & demanding my money back & they can take back the dryer too. I have a feeling this might be a bit of a fight but I am disappointed with the results of this machine. We've lost about $100+ in clothing from the first machine, plus all the down time in all 3 of these machines not working & having to worry about going to do laundry elsewhere.
Sep 11, 2010 | Frigidaire Affinity ATF7000E Front Load...
How do I reset my Frigidaire Affinity Front Load Washing Machine? When I press a button the ERR code comes on and then it turns off.
My Fridgidaire Affinity front load washer has a ERR pause and I can't reset it. How do I clear this
Jan 17, 2010 | Washing Machines
Pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Machine stuck on pause/err
un plug the washer for 5 minutes and re try
May 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Won't Star keeps flashing Pause and Err
that was just happening a few seconds ago with mine and i just tried pusing the control button and the options button at the same time for a few seconds... i reopened the door and pressed start again...it's running now... good luck
Apr 20, 2008 | Frigidaire Affinity ATF7000E Front Load...
ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
ERR=An error has been detected
PAU=Cycle has been intrupted
58=High current on motor phase
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
together for a few seconds until wash cycle LEDs appear.
Feb 25, 2008 | Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer Logo
934 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
