Question about Microsoft Windows XP Professional
Startup problem my documents open up on starting windows automatically even when it isn't in startup items
  • 449 Answers
Copy all your files in that document and delete the folder.after folder has being deleted reboot ur system and create another folder and take all your docs back.
Posted on Feb 02, 2008
  • Obiora Micheal
    Obiora Micheal Feb 02, 2008
    copy all your files in that document and delete the folder.after folder has being deleted reboot your system and create another folder and take all your documents back.
How to Remove the Selective Startup Popup?
Open the Start menu of the PC, and select Run.
Type regedit in the text area and press OK. The registry editor opens. 26319213-bxzhjmonsmllydp0qa2riq2g-2-2.jpg Click on HKEY_LOCAL_MACHINE
26319213-bxzhjmonsmllydp0qa2riq2g-2-5.jpg Expand SOFTWARE then Microsoft
Expand Windows then CurrentVersion, then Run. On the right hand panel of the registry editor there will appear a list of program items which are related to the startup of the PC.
26319213-bxzhjmonsmllydp0qa2riq2g-2-14.jpg Locate the item called MSConfigReminder and select it. Go to the Editor's drop down Favorites menu and click add so that the editor will go straight to the item in future, should it ever be necessary.
  • Then, with the MSConfigReminder item still selected, press delete to remove it, and close the editor.
  • There is no need to save anything for the editor; it is saved automatically as it closes.
  • On next startup the offending pop-up will have gone.
Oct 20, 2016 | Microsoft Computers & Internet
How to Add Programs in Windows Startup?
Programs or shortcuts placed in the Startup folder will run whenever Windows starts.
  1. Click the Start button , click All Programs, right-click the Startup folder, and then click Open.
  2. Open the location that contains the item you want to create a shortcut to.
  3. Right-click the item, and then click Create Shortcut
Oct 19, 2016 | Computers & Internet
Automatic repair
hi Andrew.
"Upon the 'Preparing automatic repair' window, press-and-hold Power button 3 times to forcefully shut down the machine. The system will enter boot repair page after 2-3 times of reboot, choose Troubleshoot, then go on to Refresh PC or Reset PC."
Get Rid of Infinite Preparing Automatic Repair Loop - EaseUS
https://www.easeus.com/resource/fix-preparing-automatic-repair-loop.html
How do I bypass startup repair?Fix #1: Boot into Safe ModeInsert the disc and reboot the system.Press any key to boot from the DVD.Choose your keyboard layout.Click Repair your computer at the Install now screen.Click Troubleshoot.Click Advanced options.Click Startup Settings.Click Restart.More items...Startup Repair Infinite Loop: Fix for Windows Vista, 7, 8, 8.1https://neosmart.net/wiki/startup-repair-infinite-loop/Search for: How do I bypass startup repair?
How do I boot my laptop up in Safe Mode?Open Windows in safe mode using Command Prompt.Turn on your computer and repeatedly press the esc key until the Startup Menu opens.Begin a System Recovery by pressing F11. ...The Choose an option screen displays. ...Click Advanced options. ...Select Command Prompt to open the Command Prompt window.More items...HP PCs - Windows Safe Mode (Windows 10, 8) ' HP® Customer Supporthttps://support.hp.com/bg-en/document/c03439317Search for: How do I boot my laptop up in Safe Mode?
or go to this link if you need more help.
laptop preparing automatic repair Google Search
Nov 28, 2017 | Computers & Internet
PROGRAM OPENS AUTOMATICALLY WHEN I OPEN COMPUTER AND I DO NOT WANT IT TO DO THIS
You may Download CCleaner to disable the starup.
http://www.piriform.com/ccleaner
To control which programs start with Windows:
  1. In CCleaner, click the Tools icon at left, then click the Startup button.
  2. In the Startup screen, you'll see a list of all items that have been set to start automatically with Windows. Those that have been disabled will be grayed out and will state "No" in the Enabled column.
  3. Do one of the following:
  • To prevent a program from starting with Windows, select the program entry and click Disable.
  • To prevent a program from starting with Windows and to remove it from the auto-start list, select the program entry and click Delete.
Note: You can select multiple startup items by using CTRL+Click.
Sep 03, 2012 | HP PSC 1410 All-In-One InkJet Printer
Mensaje al cargar mi compu Vaio Sat Survey. exe has stopped working
The VAIO Sat Survey is an Application that loads at the Startup. If the Application in the Computer is corrupted, it will display an error message that the "VAIO Sat Survey has stopped working".
You can just remove the "VAIO Survey/VAIO Sat Survey" from the startup items to fix the error message.
Please follow the below steps to disable the Application from starting automatically and fix the error message.
  1. Open the run window by pressing the "Windows" and the "R" Keys.
  2. Then, in the run window, please type "msconfig".
  3. This will open the "System Configuration Utility" window.
  4. In the System Configuration Utility window, please click the "Startup" tab.
  5. In the startup tab, please scroll down to view the "VAIO Sar Survey/VAIO Survey.
  6. Then, please remove the check mark next to the above items.
  7. Then, please click the "Apply" and "OK" buttons.
  8. The Computer will prompt to restart.
  9. Please restart the Computer.
  10. The error message should not be there when you restart the Computer.
Sep 04, 2010 | Sony VAIO VGN-CS118E/P NoteBook
Vaio sat survey not working
Jul 27, 2010 | Sony VAIO VGN-CS118E/P NoteBook
When computer start my document open
Go to startup and disable auto open your documents..sodeep
Apr 07, 2009 | Microsoft Windows XP Home Edition
When i open up my computer my yahoo messenger and my messenger live used to open up automatically and now they say there is a problem with it and windows will notify you of a solution but it has been weeks...
Use Startup Configuration Utility to make them startup again automatically by following the steps below:
1) Click on Start (lower left corner of your monitor screen)
2) Click RUN
3) Type msconfig > Click OK
4) Click on Startup Tab
Check the Items on the list that reads with Yahoo Messenger and Messenger Live
Jan 02, 2009 | Computers & Internet
MS WIndows Startup Clean Up
Click Start > Run > msconfig > click Startup Tab and then go through the list. Items that are checked will startup.
Jun 30, 2008 | Microsoft Windows XP Home Edition
I have installed Belkin "Easy
There are two places you can look...
Under: Start button - Programs - StartUp, any items in the Startup list will automatically be run when you start your computer. Simply Right-Click on any suspicious entry and select 'Delete'.
Second Place: Select Start - Run, Type In: msconfig and click Ok.
In the config utility go to the StartUp tab at the top. In this window
you can uncheck items that you do not want to start when you turn on your computer. Any checked items will be automatically run when you start the computer. The availability of the config utility is dependant on what operating system you are running.
Mar 09, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
