GE Spacemaker Will Not Drain
My GE Spacemaker (model WSM2700DAWWW) is not draining after an incidentinvolving our autistic son. He stuffed a shirt in the washer betweenits drum and frame so that, when the spin cycle began, it could notspin. We smelled/saw some smoke. Initially, it had some clothes in itand would not spin even after removing the shirt, but after I removedthe clothes from the drum, it began to spin again as normal.
However, the water in the drum (probably 2/3 full) will not drain. Ichecked the hose in the back, and it appears to be seated properlywhere it enters the washer. Still, with the metal backing, it's hard totell much of anything.
So... I'm wondering what the next steps are. I'd love to fix it myself, and am relatively handy.
Thanks in advance for all your help,
Bryan
  • Bryan Stoudt Feb 11, 2008
    Thanks so much - turned out that something was caught in the hose from tub to pump. Cheap solution!
    President:
  • 878 Answers
Bryan, your drain pump on this stacked unit is electric so it is not operated by a belt. You want to remove the front panel. There should be 2 screws on the bottom front and the panel will either lift out and off or pull down and off. You will see the drain pump. You want to put it into spin and see if you have power going to that pump. If you have a meter, just insert the probes on the harness to the pump, should have 120V.. Or you can see if it's just humming. You could have something caught in the impeller. You might have something caught in the hose from tub to pump. Get yourself a bunch of towels or a shop vac ready and check out the pump. Catriver.
Posted on Feb 02, 2008
6ya staff
SOURCE:
GE spacemaker Washer Dryer Combo don't drain properly?
Check the drain hose for obstructions. Is it being pinched where it goes over the top of the drain pipe behind the washer?
The pump may be going bad...
Jul 29, 2014 | GE WSM2700W Unitized Spacemaker Washer and...
My GE Spacemaker wslp1100 top loader is draining very slow causing error code dr. I took black drainage hose off and it seems to be clean. Filters are clean inside washer. I want to know if a coin could be...
You don't reveal full model number. It's not likely that a coin is blocking the water. The pump (part of the motor assembly) may be partially blocked inside or a garment (sock, u-shirt, etc.) may be blocking the water inlet to the pump. It's too early to remove the agitator.
Nov 22, 2013 | GE Spacemaker WSLP1100D Top Load Washer
Wsm2700dawww dryer will spin laundry still wet
Possible that the speed is of the spin is not enough, check the belt , check for friction to the shaft in the washer.
finally check the drain valve /pump as if there is water logged on without flushing then the valve is clogged or dirty.
Aug 23, 2012 | GE WSM2480DWW Unitized Spacemaker Washer...
Ge stackable wsm2700DAWWW makes noise and not drying properly.
GE HAS A REARBEARING THAT GOES OUT OVER TIME .. NORMAL WEAR AND TEAR FROM USE COULD ALSO BE YOUR HEATING PROBLEM IF THIS IS ELECTRICAL DRYER TUB COULD BE GROUNDING ELEMENT
Jan 24, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
Ge stackable wsm2700dawww Dryer making noise,maby belt,and not drying very well.
USUALYY FRONT DRUM GLIDES AND REAR BEARING ASSYMBLEY PARTS ARE MADE OF TEFLON AND THEY WEAR OUT
My spacemaker will not drain or function in spin cycle
Hello & Welcome to FixYa
When the unit is unable to drain it will not even work in spin cycle, the problem is with blocked drain/drain pump filter which should be cleaned. If after cleaning the problem comes back then the drain pump needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 03, 2011 | GE Spacemaker Washer and Dryer Electric...
My ge wsm2700dawww stack washer will not agitate or spin
Hi
Please find the links bellow to diagnose your problem…since your problem to the washing machine can be caused due to various reasons.Please go through the article to have an in-depth knowledge to your query…
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntspin
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntagitate
http://www.geappliances.com/search/fast/infobase/10002166.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 06, 2010 | GE Washing Machines
Water is not draining?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
Washer does not "click" to drain and spin cycle
Hi, Check the lid switch. Most models will not drain or spin when the lid switch is bad.
If I can get the model#, I wil try and asist you further.
Vic
Jun 21, 2009 | GE Spacemaker Washer and Dryer Electric...
Washer does not drain water
Make sure the drain hose is not kinked
Dec 27, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Washing Machines Logo
328 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
