Question about RCA D52W19 52" Rear Projection Television
Will not power up
Green light on power button comes on for a few seconds and then goes out ,no picture or sound .What is the problem and approx how much to repair.I am told that this is a common problem with this television,but I don't know exactly what the problem is
  • RCA Master
  • 5,138 Answers
First thing that your set needs is for repair shop to solder all poor and loose connections on power supply broad that most of the time will fix the problem but these sets do have alot of problems with them / bad flybacks- ribbons&connectors- tuner broads , most of all of these problems started out with poor connection bad solder joints and ribbons.You could be looking at 350. repair job.It really depends on what your set needs.Thank You for using FixYa and Have a Nice Day.
Posted on Feb 05, 2008
6ya staff
SOURCE:
Picture and sound turn on and off
I believe that model has a logic board in it and that is what it sounds like to me. That is just off top of my head, but I believe if you will notice the standby light it will be blinking so many blinks and stop and then blink again. If so this is a code that you can look up on the Samsung web site and plug in your model and it should tell you what just say ~ 4 blinks means. I worked on so many and it has been a while but I believe the last one I had was a Samsung and I put a logic board in it. If I can be of any further assistance please let me know.
Mar 12, 2014 | Samsung HL-R5078W 50" HDTV
No Picture/No Sound
This is very possibly a power surge, can you tell me how many times the light blinks, you probably have a bad power board now if you had a power surge.
Aug 11, 2007 | RCA HD52W59 HDTV Projection Television
My toshiba 40ft2u1 will not turn back on
I'm having the same problem right now. I get the green light for about 5 seconds (not Blinking) then the light goes out. No sound or picture.
Apr 05, 2012 | Toshiba Televison & Video
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
TV goes to green, sound stays on a few seconds then TV shuts off.
Sounds like you have a bad picture tube. More than likely the CRT could be shorted, which would cause the set to shut down.
My first advise would be to power up the set with an isolation transformer with the voltage about 60% approx. 72 Volts AC, and monitor what happens when you increase the voltage slowly.
If the set remains on at 60 -70 %, then when increased to 90 - 100% it shuts down, you have something drawing too much current ( which could be the CRT )
Sep 14, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Picture has gone blank
Press menue to see if the menue pops up (yanno for sleep timer and stuff). If not, you need to have it repaired or need a new tv. You could try unplugging it from power for a bit, might help.
If you can see the menues then and your using HDMI, switch to a regular cable line and see if it comes in. Or just tune to channel 4 or somthing and you should get snow. Could just be the HDMI cable.
But if you cant get ANYTHING not even the Ch3 or Volume to show up on the screen, its the screen, a fuse or somthing else
Oct 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
Will not power up
I had the same problem and It called for a lamp replacement to the tune of approx $600.00. Of course the extended warranty does not cover lamps.
Feb 02, 2008 | Zenith D60WLCD 60" Rear Projection...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
RCA D52W19 52" Rear Projection Television Logo
27 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
