Question about Sony PlayStation 2 (PS2) Compact System Shelf System
Disc won't spin after replacing laser
Hello again. I just got the laser of my Slim PS2 replaced, but for some reason it won't spin any of my discs. I tried adjusting the pots and still no luck. The discs still spin with the old one however, but I want the new one to work.
  • Agu Fungus Feb 02, 2008
    Soldered joint? Where can I find that?
  • 281 Answers
Have you replaced the laser yourself? before installing it you should remove a soldered joint on the laser, it is just like two points soldered together, just desolder that and put it back, it will work. Good luck
Posted on Feb 02, 2008
  • Arun John
    Arun John Feb 04, 2008
    Hope you have found the spot and fixed it.
I have a playstation 2 slim here. It wont spin the
Is that the only disc you seem to be having the problem with?? If so try getting the disc repair kit and using that. I had the same problem with mine but it was only some of the discs. The ps2 slim can be very sensitive and even the slightest defect in a disc will cause it not to recognize there is even a disc there.
Oct 17, 2013 | Sony PlayStation 2 (PS2) Console
Ps2 slim will not spin disk i have cleaned everything inside everything seems to be working normally yet the disk wont spin
If you have removed the cover and cleaned the glass laser eye lens unit, then the laser lens motor is faulty.
Nov 10, 2009 | Sony PlayStation 2 Slimline Console
Playstation 2 slim will not read discs. disc inserted and door closed still nothing happens. no laser movement, nothing.
There are THREE reasons that a Slim PS2 will not read discs. I willstart from most common and end at the least common (almost rare)problem.
1. A bad laser. Lasers labor on Playstation 2 [and all other videogame] consoles. They eventually fail, especially if you use your PS2as a DVD player. You can find Slim PS2 lasers at the followingwebsite. They are pretty simple to replace:
http://store.richspsxparts.com/v12laser.html
2. There are two "lid closed" sensors on the Slim Playstation 2. Theylet the PS2 know that the lid is shut and it should scan for a disc. Sometimes one or both of these sensors can become broken. It doesn'treally happen by itself... usually if someone drops the console, one orboth of the sensors can break or become dislodged.
3. A Bad Motherboard: This is rare. We mostly see this if someoneinstalled a mod chip into the system and it eventually fails.
Click into the following website for Do It Yourself troubleshooting todetermine why your PS2's discs aren't spinning, and how to fix it.
http://store.richspsxparts.com/slpsnospdi1a.html
Nov 07, 2009 | Sony PlayStation 2 Slimline Console
Disc wont spin
There are 4 reasons a disc won't spin on the Slim PSP. The most common is a failed laser.
1. Failed laser -- the disc will not spin up to speed, or not spin at all, due to a bad laser. If you close the PS2 with no disc inside, the ps2 will never spin the disc. If you chose the PS2 with a disc inside but a bad laser, it still thinks no disc is inside and will not spin.
2. Lid closed sensors. There are two of them. One on the motherboard and one on the reset switch. These sensors let the PS2 know that the lid is closed. If one or both of these break, the disc will never spin because the PS2 will think the lid is still open.
3. Damaged case. If the case of the PS2 is damaged, the two parts of the lid that are supposed to press the lid-closed sensors will never press them.
For more information, pictures, and parts, click into the following page:
Oct 21, 2009 | Sony PlayStation 2 Slimline Console
PS2 slim- Disc not spinning
definately the laser has died.
Give us a shout if you need any help.
FixMyConsole
May 13, 2009 | Sony PlayStation 2 (PS2) Console
Disc doesnt spin , the lens dont move up and down , only lights red
Sounds like a motor issue, not a laser issue.
http://cgi.ebay.co.uk/PSTwo-Slim-DVD-Drive-Snake-Motor_W0QQitemZ290237209741QQcmdZViewItem?IMSfp=TL080609158a11571
That link is for a new snake motor which moves the laser back and forth
http://cgi.ebay.com.my/Playstation-2-Ps2-PS2-Spindle-Motor-V3_W0QQitemZ250083031090QQihZ015QQcategoryZ11328QQcmdZViewItem
This link is for a new spindle motor.
Jun 11, 2008 | Sony PlayStation 2 Slimline Console
PS2 Slim New Lens, Not Spinning
Hi guys,
Well, there is 2 switch. one at  the back left of the cd tray and one one the reset /power switch. both sitch have to be close in order for the disk to spin.
If you try this dont forget to put a disk on the spindle as you will start the laser. this is for your safety. then, if the disk does not spin, then you can try replacing the laser. or at least verify the ribbon cable that is hook to it. if the ribbon cable is not well inside the plug the laser might move but again the disk won t spin.
it is related to each other, the PS2 seem to verify the laser prior to start the spindle so what ever happend to the laser affect the spindle.
and then, if you buy a new laser lens, don't forget to remove the soldering bridge. it is a small ball that is use to avoid static while shiping the lens.
most of the seller will include a small peace of paper with procedure and also there is web site with picture of this soldering bridge.
I replace some of them, and I have to say that the small plastic lock for the ribbon  cable to the lens has been an issue and the soldering bridge another one.
but I got most of the PS2 back and running by replacing the laser.
I hope this will help you.
Feb 26, 2008 | Sony PlayStation 2 Slimline Console
My slim PS2 will not spin the disc.
you will have to buy a new laser motor you can buy them on the net and they are easy enough to fit this is a commen problem most people throw the ps2 away as they think it cant be repaired but they can they r reasonably priced but a lot cheaper then buying another ps2 you should be able to fit it yourself it is easy enough a computer repairman out of the local papers will do it for you if you dont think you can do it i have seen them for sale on ebay maybe you try their first easy to do 30 min job hope this helps you out
Oct 29, 2007 | Sony PlayStation 2 Slimline Console
Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Disc won't spin,
If your PS2 slim console is chipped for playing fake games then try it by replacing the modification IC otherwise replace the lens with new one and your problem should be solved.
Aug 21, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Compact System Shelf System Logo
130 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
