Question about Yamaha P2500S Amplifier
Appears to be no output signal from P2500S
I connected an MP3 player to the 1/4" inputs with a stereo splitter cable. I then connected 2 6 metre 1/4" plugs to both the output sockets, turned the amp on and started playing an MP3. Now, when i turn the knobs on the front (the -dB ones) to the right, the "signal" LEDs flicker in time with the music. So far so good. I then connected an oscilloscope to the other leads from the output 1/4" jacks, and got no signal on the scope! Why? Is my amp broken or am i retarded? I'm planning on setting up a large stereo system for parties etc, and i want this thing working to drink some full range speakers. :( HALP NAO!!!xx
  • xephiir Feb 02, 2008
    "to drink some full range" drive** some full range speakers
    Some crazy word assocation goin on when i was typing that there
    Ah, legend! I know what i was doing wrong. I was wiring the scope up to a 1/4" female solder terminal thingy i got from maplin, connected in turn to the output. Seems that its faulty, when i wired the scope directly to the jack i got a reading. Gorgeous. Im thinking ill turn the amp down and connect it to some passive speakers ive got in my attic, thing is theyre only at most 100W, so ill have to be a bit careful not to blow em. As i understand it though, speakers more usually blow when theyre more powerful than the amp.
    Cheers for the help anyway dude!
    Sergeant:
  • 261 Answers
Make sure you use the sleeve as ground reference on the 1/4" connector then check that aginst the ring and or tip and then you should see something on the oscilloscope. Let me know if that works. Have you tried hooking up some speakers? We can live chat if that help you any. Let me know Guru Jay
Posted on Feb 02, 2008
I need help setting hooking up my DVD player to my hisense tv
There are 3 options for connecting a DVD player to a television. HDMI, Component or VGA. The most common, and best, these days is HDMI which requires 1 cable, called a HDMI cable, between the player and television. These input / output sockets are clearly marked & there is usually about 3 of them on most televisions. HDMI 1, HDMI 2, HDMI 3. The next is component. These consist of 4 separate connections. RED, GREEN, BLUE & YELLOW. Again simply connect like to like. The third (VGA) are RED, WHITE & YELLOW. Same deal, simply connect like to like on player and set. Once one of the connections are made select SOURCE on the television remote and select the connection that you have made. Cheers
Dec 14, 2016 | Televison & Video
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
I am attaching a digital set top box to this TV Model C21F200 and have a video/dvd player to attach as well. I can't seem to get both working. Can I tune the video to the TV with the set top box attached?
If your TV has AV inputs available, you can connect the video player there and switch to that input to watch it. I don't think your model does, though; I think it has only an antenna input connector. This means your set-top box will connect there but you have no place to connect the video player. In fact, most new video players only have AV outputs, and don't have an RF (radio frequency - a channel 3 or 4 TV signal) output connector, and you'd have problems connecting it anyway.
All is not lost, although you'll need some extra parts to hook everything up. I'm assuming the set-top box (STB) is going to your TV on channel 3 or 4, using a cable from the box to the TV antenna connector. If your video player does indeed have an RF output, the simple thing to do is get a splitter. They look like this:
Normally, a splitter is used to break one input signal (into the single connector) into two outputs (the connectors on the other side). But you can also use one backwards to combine two sources. So you can connect the RF cable from the STB to one output jack, connect the video player RF cable to the other, and connect the "input" side of the splitter to your TV antenna jack. If your STB is set for channel 3 output, set the video player for channel 4 so they won't interfere. Then you can tune the TV to channel 3 for TV signals from your STB, and to channel 4 for videos. I know, it sounds confusing.
If your video player doesn't have RF output, but just video and audio outputs, you need an RF converter. This device takes the AV output from the player and generates a channel 3 or 4 RF signal the TV can tune in. A typical converter looks like this:
Connect the AV outputs from the player to the jacks on the converter. The output cable from the STB will go to one of the round antenna connectors on the right, and the cable from the other one goes to your TV. When you aren't playing a DVD or tape, the converter passes the signal from the STB through to the TV. When you turn on the video player, the converter switches and you'll see the picture from the player. Most converters switch automatically, but on some you might have to flip a switch. RF converters are available from retailers who sell TVs or online.
I'm sorry if this seems unnecessarily complicated, but most TV sets today have plenty of inputs for all these things, and usually you just plug in the connecting cables and go. But with older sets or sets that don't offer the inputs, you need to go through these shenanigans. But once you have the parts hooked up, it's not too bad.
Hope this helps, and thanks for using Fixya!
Jan 01, 2011 | Hitachi C21-F200 21" TV
I'm running a tape player into one of the mic channels, then out the tape out; problem is any stereo presence is lost. Is it possible to run a 1/8" to RCA in the RCA in, route that to the level meter/main...
Each mic channel is MONO. You could use a 1/8 stereo splitter cable into two mic channels and then PAN them opposite to retain the stereo.
You can also use a splitter cable into the 1/4 inch stereo inputs on the mixer. The 1/8 inch plug must be a stereo plug that then splits to two RCA plugs or two 1/4 inch plugs.
Note that the manual specifies that the Tape/CD out is merely paralleled off the mains out. This means that your main fader controls the level to the CD/TAPE output... which may mean your main output has to be too loud to get adequate output from the CD/TAPE outs to be effective. This would require balancing the levels into your external amp better.
Aug 05, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Dear Technician, I have 4 components that I am trying to connect together, a Panasonic HDTV model #TC-L32X1, a GO Video DVD/VCR model #DV2130, a Yamaha stereo receiver model#RX-690, and a Scientific...
Hi and welcome to FixYa,
Unfortunately, size limitation of what could be attached prevents posting a connection diagram. Still, proposed connection scheme:
  • 4250HDC's HDMI to Panasonic's HDMI 1 or 2;
  • 4250HDC's VIDEO OUT to GoVideo's LINE IN 1 VIDEO;
  • 4250HDC's AUDIO OUT to 2 pcs of RCA Splitters (shown below);
  • 1 pair from the 2 splitters to GoVideo's LINE IN 1 R-AUDIO-L;
  • the other pair to Yamaha's LD/TV L & R;
  • GoVideo's LINE OUT VIDEO to Panasonic's VIDEO IN 1 VIDEO;
  • GoVideo's LINE OUT R-AUDIO-L to 2 more RCA Splitters;
  • 1 pair from the 2 splitters to Panasonic's VIDEO IN 1 L-AUDIO-R;
  • the other pair to Yamaha's VCR 1 IN L & R;
  • to watch cable TV in HD quality, set Panasonic to HDMI 1 or 2 by pressing Panasonic remote's INPUT button, then 3 (or 4), then OK;
  • to hear cable TV programs on Yamaha's speakers, set Yamaha to LD/TV;
  • to watch DVD or VHS, set Panasonic to Video 1 by pressing Panasonic remote's INPUT button, then 6, then OK;
  • to hear DVD or VHS on Yamaha's speakers, set Yamaha to VCR 1;
  • to record cable TV programs, press GoVideo remote's TV VIEW button a couple of times to cycle through the signal sources or until Line 1 is displayed.
The use of the splitter shown below would effectively double the AUDIO OUT of the cable box and the DVD/VCR combo to feed both the TV and the stereo. Additionally, this would allow use of the cable box and/or the DVD/VCR combo with or without the Yamaha.
dd46b75.jpg or
27340be.jpg or
Good luck and thank you for asking FixYa.
Apr 27, 2010 | GoVideo Go Video DVD/VCR Combo
Our first tv has a booster amplifier on the coaxial cable, i have purchase a new tv and need to know what product i need to us to attached the new tv's coaxial cable too. We have used a splitter box, but...
To have good picture quality you need zero DB (decibels) for one TV without a splitter. You can use and inline amplifier for each individual TV hooked up to the cable input with a output leg connected to each TV. If your house in wired in parallel (one main input hooked up to a splitter with all of the other TV's run off of the splitter) you can use a whole house amplifier hooked up inline between the input line and the splitter. If you house is wired in series (the input goes to the first outlet, then splitter to second outlet and so forth) each splitter knocks your signal levels down 50% each splitter. Amplifier placement depends on how the home is wired and how many TV's are in the home. Splitters can be either balanced (50/50 split) or imbalanced (75/25) etc. On a two way splitter 75% of the signal goes out one leg, while 25% goes out the other (usually for FM transmissions). If you have a three way splitter the signal is divided by the number of output legs. Splitters do go bad as well (sometimes only one leg). You can also buy an amp that is multi- port (which splits the signal and amplifies in one unit/ one input and 2,3,4 outputs). Amplifiers are electric and there is no way that the splitter can interrupt the power that would take all the signal away. If you meant that it drops the signal level so the picture is unacceptable, that's different. If you have another splitter in the house try using that one, the other might be bad. All in all you can purchase most anything you need at a Radio Shack and are very inexpensive. Amps can be purchased in different gains (boost). +10db, etc. I cannot believe that your cable company is giving you such minimal signal that 1. you need an amp?, and 2. that one splitter drops your picture to nothing? Your line extenders (amps for the lines that feed your neighborhood) might have problems or need adjustment by the lazy, cheap, cable co. also. I had problems with my cable company (when I had one) my modem would not stay online. 4 months later, they diagnosed the problem and my drop (RG56 cable line that feeds my home from their tap in the cable box outside) was bad. My friend could stay online and 2 months later comcast adjusted their amps (line extenders) in the neighborhood and then he was fine. I know this is a lot to digest, but I'm just trying to draw a clear picture so you can understand it all. I hope this helps and good luck!
Nov 07, 2009 | Televison & Video
My amplifier has one pair of rca inputs. radio only has 1 output
Subwoofer signals should be MONO - not stereo (hence the single Component out on the radio)
Only use one RCA to send signal to your amplifier.
If you use a Y splitter - the signal voltage will be cut in half - deteriorating the quality, and therefore amplifying "dirty" signal.
If you require further help, simply reply to this thread.
Thanks for using FixYa - a FixYa rating is appreciated for answering your Question.
Apr 09, 2009 | Jensen Car Audio & Video
Pc connection
yes,,,i think it will on run 2 speakers,,, get y cables
Jul 11, 2008 | Celestion S10 Subwoofer
Yamaha P2500S Amplifier Logo
162 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
