Question about Epson Stylus C40UX InkJet Printer
Paper when i load the paper and press the error button the paper goes down on the right side 1st and ends up crocked i have gone a web site to see if that helps but i cant find nothing to help. my on/off button light is on and the error button is on but not flashing. i have two buttons on/off and the other is for ink/paper (error). please help as i really would like to get it working so i can print my 3 year old son some pictures off to colour in thakyou.
  • 63 Answers
Try to do a selftest first on your printer so you can check if the hardware on your printer is still working.
Self Test:
1. Turn the printer off
2. Press and hold the error button while turning it on
3. As soon as you see lights on the printer you can let go of the buttons
Posted on Feb 07, 2008
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
My printer is not functioning is sez error 5B00 what does it mean
Hey welcome to Fixya.
Error 5b00 means the waste ink counter is full, you need to reset it.
First of all to solve it you need to download PCM Service tool. Download it from Here
After downloading follow these instructions
Step 1
: Enter in service mode in order to used the re setter:
  • Turn off the printer without pulling the power cords.
  • Hold down Resume button and press Power button
  • Keep holding down Power button and let Resume button go
  • Then Press Resume button 5 times then let both buttons go
  • The Alternate Blinking error is gone, the printer is in Service Mode state
Step 2:
  • Extract the PCM servive tool resetter and then double click "servicetool.exe"
  • Click Reload Button and you will get a new USB port.
  • Load some papers in your printer and press the "Main" Button, wait until it shows "error 001" then press OK.
  • Then press "EEPROM" button and the printer will print some text, after that click OK
  • Then power off the printer (sometimes you have to press twice the power button to turn off) and turn on again.
  • You have done.
Credit for solution goes to
uxair shah
May 06, 2011 | Canon MP640 All-In-One InkJet Printer
Just want to get a new roll of paper to feed in
Simply press down on the spring loaded button above the F1 key on the right side of the unit, next to where the paper feeds out of its slot - you may see the symbol of a roll of paper and a right arrow. Then after you open the new roll of paper, just place it into the cavity with the end of the roll coming out from underneath the roll itself, towards the serrated cutting blade, leaving a small amount of paper (2-3") sticking out of the top of unit. Now close the lid until you hear it click closed, and the button you pressed to begin with has returned to its 'up' position. Your paper is loaded and you may resume normal operations.
Feb 22, 2011 | VeriFone VX510
I have a Canon Pixma MP145 showing error E2. There's paper in the printer. After I turn it off then back on when the cartridge gets over to the right hand side (at the end of the back and forth thing it...
E2 – No paper, Paper does not feed error.
How to correct, fix: If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Jun 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer keeps printing garbage
i believe that if you update the firmware for the copier, you shoud see that the garbage printing should go away.
Mar 31, 2009 | Minolta DiALTA Di183 Copier
Lexmark x2500
There 3 light on the printer that able to indicate to user when problem occur. Find your printer error accordingly as below and may solve your printer problem.
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
Hope this help.
YBC (/\)
Feb 05, 2009 | Lexmark X2500 All-In-One Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Paper does not feed completely properly.
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
If the error still exists then its the problem with rollers it needs to be serviced..
Good luck..
Nov 13, 2008 | Lexmark P4350 All-In-One InkJet Printer
Paper is 8x7
The User guide is available on the Epson web site.
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=6p8Gbf6kzcDjBDX5CN0IhYGAuQVqVCJs&tc=5
Essentially, this suggests (page 2-9) that you turn off, leave for 5 seconds min, and turn on holding the Tear off(Font) button. Press this button once and select the language, then press it again to print the settings and instructions for changing them. Set the printer to tractor-feed and your required length and you're away (turn off after).
Sep 12, 2008 | Epson LX-300+ II Matrix Printer
Paper wont feed then says paper jam
Got rid of my problem!
In an act of despair I started to poke around the inside of the printer with a wooden match. Especially I found a small black lever mentioned on a Dell web site (general paper jam help page) that could be pressed a little. It is placed just a little bit right of center behind the carriage and just above the roll that feeds the paper beneath the printer heads. I'm not sure if this was what finally did it, but now the paper jam problem has gone away.
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect)
Apr 08, 2008 | Dell 924 All-in-One InkJet Printer
Epson Stylus C40UX InkJet Printer Logo
49 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
