Bush DVD 2038 DVD player
This dvd player was playing fine until it was last used,it has not been used much (2 years old). It has recently stopped responding to the re-mote (new batteries) and manual buttons. There is power to the machine(red light on the dash),i have removed a disc from the inside of the player and reasembled but no change. Any advice much appreciated. I have a Bush DVD2080divx that's only a year old. It was working fine until recently. The power is on (the display reads -OFF-) but the player doesn't respond to the remote or the buttons on the actual player. I've changed the batteries, tried turning off the power, I've checked all the cales are properly attached but nothing works. I'm not very tekkie so I haven't even try to take anything apart. Any help, please? Desperate.
  • 1 more comment
  • Anonymous Feb 26, 2008
    hi have same problem with bush dvd2080divx im trying to find an answer
  • akeel1701 May 09, 2008
    I've also got the Bush DVD02080DIVX and it was working fine until this morning when it was displaying OFF in the display screen and totally unresponsive. I have unplugged it for the mo, and i'll leave it unplugged overnight before repowering it
    A friend of mine had the same make and the same problem. Now reading this I can't help but think that it's been programmed to shutdown after a certain time...
  • lozzy_lives May 31, 2008
    thanks for your help. Unfortuntely i t didn't work.
I contacted Bush custimer care and this is the reply I got:
We apologize for the inconvenience caused to you.
We would request you to kindly reset the remote control by following the steps mentioned below:
1. Remove the batteries and reinsert the batteries after 1 minute.
2. Press and hold the top, right and the bottom navigation button on the
remote control along with the number 1 button (as in 123) for 10sec.
It didn't work for me, but I have posted it on here, just in case it works from someone else
Posted on May 31, 2008
Just purchased bush dvd player with hdmi and i wish to play a dvd which i have had (sometime ago) transferred from video/cine film. I am unable to get it to load/play. As these are all memories from...
The older laser player/burners may have used a different angle for the read/write service. It is like a phonograph needle sitting in a groove that tracks the data as it pans the surface.
Try to COPY the CD/DVD to the desktop if you can. If you know the OLD player worked, use that to COPY the Data to your Current computer desktop and then copy that back to new CD using the new hardware.
Mar 06, 2015 | Bush Televison & Video
Is there a Unlock code for bush btvd91216w
This is everything that I have:
Try this general bush unlock:
Press Open tray
Press 2, 8, 1, 2 and Enter to get to the manufacturers settings
Select the required region, by pressing Enter on 9 for multi region
Press Close tray
If that didn't work, try this:
Try this one:
1. Press the Open button on your remote control to open the drive tray
2. Press the 9 button on your remote control
3. Press the 7 button on your remote control
4. Press the 3 button on your remote control
5. Press the 5 button on your remote control
6. Using the on screen menu, highlight the region option
7. Press the Right button on your remote control
8. Using your remote control, select 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
9. Press the Enter button on your remote control
10. Press the Open button on your remote control to close the drive tray
Then there is the following and good luck:
Bush 1000
  1. Open the tray
  2. Insert a disc with desired region code, but do not close the disc tray
  3. Press 0, 1, 2, 3, Play
Bush 1005 / 2004A / DVDAV7
  1. Press the OPEN/CLOSE on the remote
  2. Press 3, 3, 0, 8, 8
  3. Press the button for the desired region or 0 for multi-region
  4. Press OPEN/CLOSE
  5. The on-screen display will now indicate the currently selected region
Bush 2000
  1. Open the disc tray
  2. Insert RC-1 DVD, don't close the disc tray
  3. Press 0, 1, 2, 3
  4. Press PLAY
    To activate RC 2:
  2. Insert RC-2 DVD, don't close the disc tray
  3. Press RETURN and PLAY
Bush 2002 / 2004
  1. Press OPEN
  2. Press 7, ENTER, 7
    A menu should appear (codefree=13)
    Method 2:
  1. Press OPEN
  2. Press 2, 0, 0, 1
Bush 2005 / 2008 / 2009
  1. Turn on the player
  2. Press OPEN/CLOSE
  3. Press ZOOM
  4. Press A/B
  5. Press Up, Left, Down, Right
    A note should be displayed.
  6. Turn it off
  7. Turn it on
Bush 2023 / 2024 / 2523
  1. Press OPEN
  2. Press 2, 8, 1, 2, Enter
  3. Set the country code to 13 and press Close
Bush 2028
    already region free
Bush 2039
  1. Press OPEN
  2. Press PROG
  3. Press ENTER three times
  4. Use UP/DOWN to select region
  5. Press STOP several times to set the region
Bush 2047
  1. Press OPEN, SETUP
  2. Go to "Preferences"
  3. Enter 2, 8, 1, 2
  4. Use UP/DOWN keys to select the region
  5. Press SETUP, OPEN
Bush DVD-102
  1. Press OPEN/CLOSE
  2. Press 2, 0, 0, 1
  3. Press ENTER
  4. Select RC (codefree=13). You can disable MacroVision, too.
  5. Press OPEN/CLOSE
Bush DVD-142TV
  1. Press DVD function on your TV set
  2. Press DVD Setup on the remote
  3. Press 1, 3, 6, 9
  4. Press Left three times
  5. Press RIGHT once
  6. Select VERSION
  7. Change the region code
Bush DVD-143TV
  1. Press DVD/TV, DVD
  2. Open the tray
  3. Press SETUP, Right, Left, Down, Up, Display
  4. Enter 0 (or 1-6 for other RC)
  5. Press Enter
    VCD/SVCD playback
  1. Press SETUP on remote
  2. Press Next, Prev, Next, Prev
    Ver should appear in the top right
  3. Change 3001 to 3000
  4. Change 5001 to 5000
Bush DVDAV11K
  1. Open the tray (be sure to be in stop mode)
  2. Press SETUP, Next, Prev, Next, Prev
  3. Select 255 for region free (use LEFT/RIGHT)
  4. Press SETUP
Bush DVDR3000
  1. The disc tray has to be empty
  2. Press TV/DVDR
  3. Press RETURN, DISPLAY
  4. Enter 8, 8, 8, 0
Bush DVHS1
  1. Press the DVD button on the remote
  2. Press OPEN
  3. Press 0, 5, 2, 0
  4. Press UP, DOWN, LEFT, RIGHT
  5. Change the region (0 = multi-region)
Bush DVRHS02
  1. Push SETUP button on the remote
  2. Select SYSTEM INFO on the menu
  3. Enter 1, 1, 0, 1
  4. It shows the current region code
  5. Push 0 on the remote for region free
Bush 2001 / 2020 / 2026 / 2029 / 2035XI / 2038 / 2042 / 5020 / BTV213DVD / DVR3000 / DVRS01 / PDVD0707 no known hacks
Jun 12, 2012 | Bush Televison & Video
I REQUIRE A REMOTE CONTROL FOR BUSH DOLBY 2038. CAN YOU HELP
Try website like Remotes.com to buy the DVD player original remote.
Aug 29, 2011 | Bush DVD2038 DVD Player
My phillips dvp5140/37. video player ,stops
Does the player ask for a password?
If it does look in the manual or contact Philips on their website.
This helped me a lot once.
Jun 13, 2010 | Philips DVP5140/37 DVD Player
BUSH DVD2038
hi i'm trying to change region so i can watch can you help
Nov 13, 2007 | Bush DVD2038 DVD Player
BUSH DVD2038
Try this it worked for me!
Bush 2038
  1. Press OPEN
  2. Press PROG
Oct 08, 2007 | Bush DVD2038 DVD Player
Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Sep 06, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Not alot a user can do with these units unless you have all the proper tools and jigs. Read this and see if it helps. http://www.techlore.com/article/14550/ Good Luck PS please dont forget to rate this thread.
Nov 25, 2006 | Bush DVD2038 DVD Player
Televison & Video Logo
269 people viewed this question
Top Televison & Video Experts
