Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba laptop how to open case and clean inside. Help me please
  • 43 Answers
Unless you know what you are doing,it is not advisable to open your laptop up.
Try using compressed air from a aerosol can,they can do wonders.This can be applied @ the exhaust vent,but not for too long.Make sure the laptop is "Off" & "Unplugged" from Mains Power.Don't forget to remove battery & blow away dust from the compartment.
Also,every so often,turn your laptop over & tap lightly on bottom to remove & foreign bits caught inbetween the keys.
Posted on Feb 02, 2008
Hi there is a toolbar coming up the whole time saying,,,,,WARNING a problem with the cooling system has been detected, please turn of the computer and return for service immediately
Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
Welcome to FixYa! Based on the error you have received, this means that the cooling fan of your laptop needs to be cleaned and checked at. This is a common problem with any toshiba laptop. I suggest checking the heatsink of your laptop. If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
  5. If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you.
Hope this helps! Thank you for using FixYa!
Jul 27, 2011 | Toshiba Satellite 1715XCDS Cooling Fan...
My Toshiba L305-S5875 Laptop seems to be overheating, especially when I'm watching videos. I'm sure that I just need to clean it out, but I can't figure out how to open the case. I removed...
http://www.irisvista.com/tech/
or this might be yours or close enough to help you get inside it, there will be a pound of stuff stuck in between the heatsink and the fan.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
Jun 10, 2011 | Toshiba Satellite Pro L300 Notebook
I have a toshiba equium l300, with no power at all
open it you will find if what is the problem.....open the whole case if not charging check also the dc connector of, check also the charger.
Jun 27, 2010 | Toshiba Satellite Pro L300-EZ1004X...
I have open up laptop..Some Help!
Sorry you are having trouble. I can help you with this. Remove the bezel with the power switch first. Then remove the keyboard. This should let you see what you need to see.
What trouble are you having with it?
Let me know if you need further assistance.
Apr 06, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba laptop will keep shuting off
It is because of the laptop overheating problem. This is a very common problem with and could be easily fixed if you clean the heat sink. If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
(If this tips helpful please rate this solution)
Feb 26, 2010 | Toshiba Satellite A215-S7422 Notebook
TOSHIBA M35X-S149????????? charger went inside the computer how do i fix it??? any help will be greatly appriciated
when you say the charger went inside the laptop that the piece that you plug into felll in. You have to open the case, get your soldering iron out and hot. Once you take off the bottom portion of the case you may need to remove the board to get to the plug piece. Once you get there you need to soldier it back on.
Dec 23, 2009 | Toshiba Satellite M35X-S149 Notebook
When i turn my laptop on it says password. i dont know it
This is a password for the BIOS. To override this and reset to "NO" password you will need to disconnect the power cord, remove the laptop battery and remove the clock battery inside the laptop for,,,say 10 minutes. This last step will require you to open the laptop. In Toshiba laptops, it is generally located near the RAM slots, and can be replaced without opening the whole laptop casing. Please find the exact location and replacement instruction from the Manual.
Good Luck
Dec 15, 2009 | Toshiba Satellite A55-S1063 Notebook
Fan problem
The fan is clogged an needs to be cleaned if you know how to open the laptop you can move the strip that houses the keyboard ans remove the key board from there you can see the fan that is on the CPU stick a tooth pic in the fan soo that it does not move and blow it clean with compressed air. if not take it to you local computer guy and he can clean it for you.
May 09, 2009 | Toshiba Satellite A215-S4747 Notebook
Toshiba Satellite M115 cooling problem
You could use canned air to try and blow it out
make sure you don't turn it back on for about 20 minutes
Jan 24, 2009 | Toshiba Satellite A135-S2246 Notebook
Toshiba laptop shuts down on its own
Solution:
Nov 27, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
