Question about Nokia 6630 Handheld
Battery won't charge in the phone
My trusty Nokia 6630 has thrown a bit of a wobbly and won't charge any more. I can charge the battery OK by resting it's contacts against the contacts of my other Nokia, a 6280, and then put it back in the 6630 and it works fine. When I plug the charger in, either the mains one or the car charger, I get the message "Not charging" with a phone icon with a red cross on it. Also the charging bars go back to zero when the charger is plugged in, althought they revert to normal once the charger is removed. This all started a couple of days ago when the phone rang and immediately switched off as the low battery warning had been beeping for about half an hour and the phone ringing must have taken the last bit of power from the battery. I plugged it into the charger but was maybe a bit impatient waiting for it to start up again as it seemed rather sluggish accepting my PIN code, so I switched it off before it had completed doing this and when I switched it on again it had this fault. I would be very grateful if anyone could advise on how to cure this problem. Do I need to make a backup and do a hard reset or reinstall the firmware? If so how do I go about doing that?
  • Anonymous May 21, 2008
    i have the same prb. so coukd any one anser? if he have the anser
    President:
  • 169 Answers
System might be damanged,
You can hard reset the phone (Factory Settings)
This will reinstall the operating system inside the phone back to how it first was.
(internal memory gets formatted then the rom reloads the os back)
(Solves all kinds of problems.)
Switch the phone "OFF"
Hold "3" (button) + "Green Call" (button) + "*" (star button)
Switch the phone "ON" while holding the above three buttons.
Continue holding for about 20 seconds then let go.
Please note this will format all the saved information stored in phone memory. including phonebook numbers (if not stored on SIM card).
Try to make backups first.
You have been "Warned".
Best of Luck.
Posted on Jun 21, 2008
6ya staff
SOURCE:
I have a Nokia 6630 Second hand phone.Sometimes I have displayed 'Not Charging' when I am using my NOKIA Original Charger. but my charger is working properly.Is it a battery problem or Power IC problem
yes once check ur charger and all pins of that charger and check the phone pin at connnet of the charger if it not works u should change ur chrger or phone pins ok thinks and all the best and please
OR:
Please change Phone In The CHARGING JUMPUR
rate my answers too
Dec 28, 2010 | Nokia 6630 Cellular Phone
6630 phone charging but not charge full charging simple is 2point
my nokia 6630 is sow charging but batry is not charging
Apr 22, 2010 | Nokia 6630 Handheld
How to delete nokia 6630 phone memory
enter *#7370# phone ask to security code enter 12345 if u not change it phone will restart ur phone will now formatted & OK plz send thanx
Aug 21, 2009 | Nokia 6630 Cellular Phone
Nokia 6630
sorry but and?
your phone is dead,
we cant bring it back,
sorry
okay
check the battery
check the battery connectors
does the phone charge
try and put another battery of the same type in the phone
if that fails
yes your phone is dead
Jul 05, 2009 | Nokia N70 Cellular Phone
Battery is not charging nokia
check batt model r it arthorised batt and check charger and batt model no
Jan 23, 2009 | Nokia 6630 Cellular Phone
Nokia 6630 is not working
try to change your battery....ok
Dec 26, 2008 | Nokia 6630 Cellular Phone
6630 charging problem
Hi Friends,
I am Raheel Ansari from Pakistan, Karachi. My 6630 's battery is getting discharged very soon I have buy New Batteries but issue still remain. kindly help me out in this regard.
Thanks & Regards,
Raheel Ansari.
Aug 31, 2008 | Nokia 6630 Handheld
Nokia 6630 wont charge or turn on
HI THIS IS DUE TO YOUR MOBIL DOES NOT GET THE POWER FORM THE BATTERY = pla check is the battery is connected properly == in order to check if there is problem in battery you can unplug the battery and connect any other battery == if the phone is on then the problem is in the battery other wise i m afraid the problem is in the phone GOOD LUCK
Nov 22, 2006 | Nokia 6630 Handheld
Nokia 6630 Handheld Logo
128 people viewed this question
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Ekse
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
