Question about Sony VAIO GRT250 Notebook
Dim screen how to replace inverter on sony pcg-grt250
  • 689 Answers
Hi
You have not mention about your location. However there are many companies provide laptop parts including the FL inverters. if you have the the inverter with you it will be simple to replace when you open the display frame as you can remove the old FL inverter module and put new one. It has sockets that you can easily connect.
You can get the parts from Sony, also 3rd party dealers
here is the some links for them
http://www.sparepartswarehouse.com
http://www.priorityelectronics.com
http://www.simplemicro.com
Please post your question if you need further assistance.
Good Luck
Posted on Feb 02, 2008
6ya staff
SOURCE:
SONY VAIO PCG FRV27 I power on the laptop and the screen shows up but its very dark i adjusted contrast but it is not very visible
Diagnosis:
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen
Oct 06, 2010 | Sony VAIO PCG-FRV27 Notebook
The screen is dim and "sun" key doesn't help
It is very possible that you are losing the screen. The backlight is built into the screen and the inverter is usually very reliable. I would however most likely change both the inverter and the screen.
Oct 03, 2009 | Sony VAIO PCG-K35 Notebook
My sony vaio vgn-n365e screen is Dim
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 24, 2009 | Sony VAIO PCG-K23 Notebook
How the most large hd i can choose to do a upgrade on my notebook?
You can buy any 2.5 inch notebook hdd, just make sure you look at your manual to see if your connector is SATA before you buy. Good luck.
May 21, 2009 | Sony VAIO GRT250 Notebook
2003 vaio PCG-GRT250 (UC) fan noise
yes the fan can be replaced separately, and should be done immediately
but I would strongly suggest that you take it to a qualified technician to do the repair
Feb 03, 2009 | Sony VAIO VGN-FJ270/B Notebook
Dim LCD display
ccfl tube goes down or inverter cirucuit is fail
need to replace it
Feb 02, 2009 | Sony VAIO PCG-K23 Notebook
I have no sound on my Sony Vaio PCG-GRT250 laptop.
There can be a lot of reasons, 1) first try ths , Goto run and type services .msc  then check the audio  service to see i fit is started , if stopped start the service 2) you can also try and reinstall the drivers try add hardware icon in the control panel else use device manager
Dec 31, 2008 | Sony VAIO VGN-FJ270/B Notebook
LCD laptop screen
It is definitely the screen or the inverter. Usually the screen and inverter come as one piece. I would check with the manufacturer. Unfortunately for you, the LCD is one of the most expensive parts to replace on a laptop.
Just the simple fact of you mentioning that it works fine with an external monitor tells me that its not the video card. If it was the video card, you would see the exact same thing happening on your external monitor as well.
Hope this helps!
Apr 22, 2008 | Sony VAIO PCG-K23 Notebook
Open Questions:
See all Sony VAIO GRT250 Notebook Questions
Sony VAIO GRT250 Notebook Logo
198 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
