Question about Dryers
Kenmore dryer 62828 quit heating
Looking for help introubleshooting no heating problem. I am not electrician but can follow directions or follow simple wiring diagram.
There are unresetable thermo controllers in diagragm. Could that be problem or do I go straight for the heating element.
Can you help?
  • jeepsterhore Feb 27, 2008
    Kenmore Dryer quit working and sears came out and replaced the thermo cutoff. It worked for about three days and quit working again. I cleaned the vent to the dryer was blocked at roof. How can I check the thermo cutoff to see if they went out again. Help!!!!!
  • 240 Answers
The best way to go about this is to check each peice first. In order to do this you will need a ohm meter. If you dont have one, you can get one pretty cheap. If you have one, set the meter for ohms (continuity) and remove the wires for each part that you test. Put the leads on each peice, and see if your needle moves. If it moves, the part is ok. Repalce as needed. Only other way is to remove the element, and inspect it carefully. You should see a broke part or wire MAYBE. There is no way of checking the thermal cutoff with a ohm meter. Good luck and let me know if you need further help.
Posted on Feb 02, 2008
Why is my dryer not heating ?
Likely the heating element took that opportunity to quit. These's a possibility something came loose but you need a good handyman/electrician to check the element and you will need the serial number/make/model etc off the sticker on the back when looking for the part or handing it over to your local appliance shop. Bear in mind the time you have had it and whether to bin it and buy new.
Mar 30, 2015 | Dryers
Kenmore dryer
looks like some contact problem. maybe you should call an electrician
Apr 28, 2013 | Dryers
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 24, 2017 | Kenmore Dryers
Kenmore electric dryer model 62828 takes two full cycles to dry instead of one dave
change the high-limit/cycling switch located on the element tubes outside,they get weak from heat and cycle too soon,so element cools frequently during drying
Mar 12, 2010 | Dryers
Dryer stopped heating
Reset the dryer breaker pair in the house electrical panel--push off, then on. If the breakers hold, retry the dryer (no clothes yet). If you now get heat, you are home free. If it tripped the breakers again, then there is a direct short within the dryer, usually the heater element(s). If the breakers hold, but still no heat, check with a voltmeter for ~230 volts AC across the two slanted slots in the power socket. If near zero reading, one of the breakers is bad and should be replaced or a wire connection coming out of one breaker is loose. Have an electrician check and repair this problem. If you read the required voltage, then the problem is inside the dryer. The drum must be removed to access the heating element(s). Either the element or the thermal control switch is open. If everything looks ok in the heater area, then it may be problems in the control area. Hope this helps.
Sep 07, 2009 | Kenmore Dryers
No heat, dryer runs fine it will not heat up. vent is clear all the way to the outside. I think it may be the fuse but I don't know the location, can you help?
hi..
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair...
thank u
rate me
Aug 18, 2009 | Kenmore Dryers
Kenmore dryer not heating
Check the following-- Gas valve coils Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Jun 05, 2009 | Kenmore Dryers
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer will not heat
Have a certified electrician check your outlet. The dryer requires 220VAC for the heating elements to work. If this is ok, check the heating elements it may be broken.If this is ok, check the high and low limit switches, this could be defective.
Apr 04, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Dryers Logo
187 people viewed this question
Top Dryers Experts
Marvin
Marvin
