Television won't power up
This television first started with the picture messing up, think that was to do with the cable connection on the back because I smacked it on the side and the picture straightened out and it was fine. Recently I went to turn the set on and it sounded like it was going to turn on and then it made another sound and would not power up from that point. I have worked on some televisions and installed fly back transformers, but that was long ago. I have tools, soldier iron and volt/ohm meter. I was thinking that I can open the set, discard the tube and this might have a broken connection to the cable but the power going out I suppose I could trace back from the power button. I am leery of discharging the set since I have not done this for so long. Can you instruct me as how I should do this and what to look for or test. Your help would be greatly appreciated
    Novelist:
  • 123 Answers
The set has gone into protection overload status.
You must unplug the power cord for 3 or 4 hours and power it up again.
If the hard reset above does not bring it back to life it needs technical service. There are about 10 sections that would need to be checked to see where the overload conditions are causing the problem.
As a general rule this type of failure is severe and expensive. Typical costs of repair are always over $200 and most often closer to $400.
Common failures are main power supply, high voltage supply, deflection amplifiers and so on.
This is not a user or home remedy type repair. If you are lucky it may be something not so costly, but experience tells otherwise.
Hope this helps.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 02, 2008
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Feb 02, 2008
    A turnoff as you describe is generally caused from current overload which sends
    the set into protection mode.
    This is a very common occurrence.
    FIRST: Give it a hard reset. Unplug the tv for a couple of hours, then try it again.
    SECOND: Whack it good with your hand or fist. Doing so will often reactivate a bad joint,
    connector or cold solder.
    THIRD: It may need servicing if the above two remedies bring nothing to the for.
    The cause is often a failure in the power supply, high voltage or deflection amplifiers.
    It is never from the same cause as other sets. Cost of repair can be from $100 to $400,
    depending on the final diagnosis.
    Good Luck
    Good Luck
JVC 42" Tv has cut off and when it came back on
If using a cable box try connection direct without the box---also try to remove power from set and box for a while and then power back.
Dec 03, 2012 | Televison & Video
Netflix will not connect internet on vizio blueray player
see this steps and fix it. God bless you
    • 1 Reset the player if the device stops behaving normally. (Keep in mind that rotation sounds and picture issues during search are normal.) Select the "System" menu from the setup area and choose "Restore Factory Settings" or a similar option. Allow the device to restart and then try the disc again.
    • 2 Insert the disc face up in the tray. If playback fails to start or if it starts and then stops, wipe the disc with a soft cloth and try again. Throw out any heavily scratched discs that won't play.
    • 3 Change the "TV Aspect" to 16:9 in the setup area of the menu if the picture expands left and right or if the picture size is wrong and you're using an HDMI (High Definition Multimedia Interface) cable.
    • 4 Set the wireless Internet router to automatically allow new devices to connect to it if the Insignia player won't connect to the Internet. The player uses only WPS to connect. Some routers that use different automatic setup protocols won't work.
    • 5 Make sure that the connection between the player and the television uses an HDMI cable if you're watching a Blu-ray movie. Some Blu-ray discs will only play over an HDMI connection. Also, remember that some Blu-ray discs won't work with PiP (Picture-in-Picture).
Oct 15, 2012 | Vizio VBR220 Blu-Ray Player
My son parked his bike in front of a loca store someone messed up his front brake (I think on purpose) the wire connecting the brake pads on the bike - is loose and the brake pads won't...
Sorry to hear about your sons bike have been messed up. First you have to check out if the brake works. Pull it with your fingers (brake itself, where the cable is attached). If it squeezes and springs back, there is no probs. Then loosen the cable and check if the brake lever works (use it as if you are braking). It should go down and spring back itself. If it does, there is no probs. In that case all you have to do is to loosen the cable at the brake itself and then re-fit it by pulling the cable with pliers and securing it with the appropriate screw.
Jun 02, 2011 | Schwinn Cycling
42" television that won't display
You have the picture mode set ion 4:3 if its not the TV it will be any cable or satellite you have connected, you need 12:9
May 15, 2011 | LG Televison & Video
I have a Plasma Monitor Model PX-42VP3A that I won in a raffle. It didn't come with any cables or anything. What do I need to purchase so that I can connect it to my cable box? I had cable come to my...
These televisions do not come with any cables. It is just the power cord that comes with it, and it is the power cord that You connect to the power outlet and power port on the television. The cables You are to buy to connect the television to Your cable is:
  1. RGB adapter cable( that is if Your cable has the RGB port at the back of it that accepts the RGB cable).
  2. White, Yellow and Red jack cables(a 3 in 1 cable), these cable connects the audio and video of the cable to the television from the port that You connect the cables into. Sometimes, these ports are covered in with a plastic casing to protect the port from dust.
  3. You get a power cord that is used to supply power to the television if Your television did not come with one,
  4. HDMI cables also can be used to connect the television to the cable if the cable has the type of port that supports it.
Hope this helped. Thank You for using FixYa!!!
Jan 19, 2011 | Televison & Video
My playstation wont transmit a picture to my television
Make sure everything is connected correctly. Then, turn on the PS3 from putting your finger on the "power button" but HOLD IT DOWN. After a few seconds it will beep at you a few times. Check the TV. If the video OUT settings got messed up somehow, it should now display picture on whatever cables you are using "HDMI" or "Composite" . Hope this helps!
Jul 22, 2010 | Sony Playstation 3 (PS3) Console
I have a symphonic tv. when you turn the tv on all i get is one color line across the top of the tv. if you mess with the cable in the back the picture will come in.( i disconnected the cable and still...
Hi,that is comme from your cable connector in the back off the tv /or its could be the tunner its self having a bad solder where its conecting pinfrom cable in to inside the tunner/pr or try another cable conector,
hope that help you
thank to ask fixya..
Mar 31, 2010 | Televison & Video
Basic cable connections using rear coxial connection
better call your cable tv provider.it seems that the problem is out of your premises
Jan 13, 2009 | JVC AV-56WP74 56" Rear Projection...
No cable picture or sound
only thing I can think of is for you to check your cables... assuming you are using a coaxial cable for the satelite and rca cables for games and dvds, I would recommend trying a different coaxial cable. There is also the chance that the coaxial connection on the tv itself is messed up. you may try buying an RF modulator that will convert coaxial to rca, most rf modulators convert rca to coax. so make sure it does what you need before you buy it. tech guys at store should be able to help if you can't figure it out.
Jun 19, 2007 | Toshiba TP50F60/61 TV
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
