Question about Emerson EWL20S5 20 in. EDTV-Ready LCD Television
Emerson tv mod. Ewl20s5
Tv turn on momentarly and shut off
  • C-Riles Apr 01, 2008
    Tried to adjust sleep mode but not successful.
  • raggastojin May 11, 2010
    my mivar tv has pictures in the middle with dark top and down what is the cause?
5 Suggested Answers
SOURCE: Emerson EWL20S5 20 in.
This TV has a network of diodes connected to a PROTECT-1 line monitored by the control IC. If any circuit pulls this line low, the control IC turns the system OFF. The diodes act to isolate all the circuits from each other, its called a diode-OR circuit.
You can troubleshoot by opening a diode which disconnects a circuit from pulling the line low. I had a hunch the EL backlight board was bad, so after opening that protect line the power stayed ON.
I found a bad .068uF 250V cap on the transformer primary, it measured .002uF. I've replaced the cap and the other two on the other transformers just for good measure.
It probably took more time than the TV is worth, but my friend's Mom will be happy, and thats worth it.
I hope this helps, look around for the service manual, it can be found online.
Posted on Jan 15, 2008
tvtek
  • 1284 Answers
SOURCE: I need a replacement stand (base) for an emerson
You will need part number 1EMN20039B just do a goolge search with that part number. Good Luck.
Posted on Nov 05, 2009
  • 132 Answers
SOURCE: tv automatically shuts off after being on for a
The most common problem for this set that will cause shutdown after a few seconds is the inverter board. Looking at the set from the back, it is the long slim board that is normally located on the far left side of most lcd tv's. There are 3 electrolytic capacitors located on this board, and changing them will fix a lot of these sets for this problem. The location numbers of the caps are c330, c350, and c370. If you have any experience working on electronics, I would start by changing these caps. They are very inexpensive. If you would rather just change the inverter board, try shopjimmy.com. That is a good place to buy boards for flat screen tvs.
Posted on Jul 29, 2010
  • 25 Answers
SOURCE: is emerson ewl20s5 tv digital or do I need a
The set can recieve analogue transmissions or cable signal only, for digital transmission a converter box would be needed
Posted on Mar 05, 2011
Pairig tv EWL20S5 C
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 01, 2016 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
We have lost our manual for this TV. Is it possible to print one from online or to have one mailed to us?
Emerson TVs are built by Funai. You can get the manual from the Funai site, http://www.funai-corp.com/support/manuals.aspx . Search for your TV model to find the manual as a PDF and then print the file.
The direct link to the manual for the EWL20S5 is http://www.funai-corp.com/6pdf/om/EWL20S5.pdf . For the best results when you want to print the file, save it to your computer and then open it in Adobe Reader (instead of using the plugin). You may need to change the scale at which the document is printing. Use the Print Preview feature to guide your printing choice.
I hope this helps.
Aug 09, 2011 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Is emerson ewl20s5 tv digital or do I need a converter box?
Mar 05, 2011 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Where can i get a manual to help me program a LCD EMERSON TV model EWL 20S5 TVwill not show picture if not connected to cable
<a href="http://tv.manualsonline.com/manuals/mfg/emerson/ewl20s5.html">http://tv.manualsonline.com/manuals/mfg/emerson/ewl20s5.html</a><br /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span>
Aug 25, 2010 | Emerson EWL2005 20 in. LCD Television
I need a replacement stand (base) for an emerson tv model # ewl20s5.
Nov 05, 2009 | Emerson LC195EM9 19 in. LCD TV
What does an inverter transformer look like?
0f528c9.jpg On my 32' TV, they are the 6 black squares lined up in the fornt of the picture. This goes to an Emerson 32' LCD TV.
Apr 01, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
I know TV model # but not remote model #
go to remotes.com and enter in your model number.
Mar 23, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Emerson 20" lcd
bad power board or bad capacitors on the power board service required
May 27, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Emerson EWL20S5 20 in. EDTV-Ready LCD Television Logo
54 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
