Network card i have a built in network card which is fawlty and have purchased a new card how do i fit it .
  • 43 Answers
You will have to open your system case & install NIC into one of the PCI slots.Preferrably closest to CPU.
Caution: Turn computer Off & disconnect from power.
Once installed,boot computer & Operating System should find New Hardware & install.If not you will have to get drivers for the NCI
Posted on Feb 02, 2008
I need to install a mobile network on my irulu tablet with a 64g sd card.
You can't install a mobile network if the device doesn't have it built in already. Your device is probably Wi-Fi only.
You'd have to purchase a new tablet with 3g or 4g, but if I were you, I would purchase the tablet from your mobile network provider, that way there won't be any compatibility issues.
Dec 05, 2016 | Tablets & eReaders
I need to replace the network card. How do I do that and what product do I need to buy? Thank you
as far as i see you the network jack is built into the motherboard,
you'd either have to replace the mother board
or purchase a new usb exterior network jack
http://www.ebay.com/itm/GATEWAY-NV52-MS2274-NV5214U-AMD-motherboard-55-4BX01-051-MBWDJ01001-48-4BX04-01M-/251327720635?pt=Motherboards&hash=item3a844cacbb
Oct 29, 2013 | Gateway NV5215u Notebook
Presario sata setting
I take it you mean your ethernet (network) card has stopped working? This is a common fault, especially with ports that are built into the motherboard. I suggest you buy and fit a PCI plug in network card--- not expensive and hook your ethernet cable to that.
Modern Windows operating systems should have no problem detecting the new card and installing a driver automatically.
Be aware that if you do this you may have to contact Microsoft to re-activate your Windows, as the MAC address you are using will have changed.
Oct 16, 2013 | HP Sr1130nx (PC134A) PC Desktop
How can i use the sim card slot given behind my battery of dell studio 15 laptop? which type of sim card is supportable?
The SIM card is for a mobile data plan. If you go to say...AT&T and purchase a wireless data plan on the cellular network and insert the sim in the back of your laptop you will have internet access on the cellular network.
Jan 23, 2011 | Dell Wireless 5530 Mobile Broadband...
How to replace ethernet card on hp pavilion a706n, it looks like it is built in to the motherboard, can I just buy a replacement and put in one of the empty slots??
It is buillt in however if you have a spare PCI slot on the motherboard you could fit another ethernet card which would override the built in one.
Sep 14, 2009 | HP Pavilion a706n PC Desktop
Questions about replacing ethernet card on my Dell desktop
Any ethernet card will work fine. Just be sure it's the fit's the correct slot. You probably have a "white" slot which is a pci slot. If it's a longer "black" slot then it's isa. More than likely it came from a pci slot. Before you buy one, confirm the type of slot. In additon, before installing it go to control panel and system settings, hardware, device manager and remove the old one by right clicking it and select delete or remove. Shut down the computer follow instructions for new card.
Probably will have to install the drivers first then shut down and install the new card. Good Luck.
Apr 17, 2009 | Dell Ethernet Card Network Adapter
Modem bad on Dell Dimension 2400, Can it be replaced?
Ethernet port or dial up modem?
If it's the built in ethernet port, all you need to do is purchase a PCI ethernet card, disable the one that's built in in the device manager and you're good to go.
Thanks and please take a moment to give this solution a rating of fixya.
Mar 11, 2009 | Dell Dimension 2400 PC Desktop
Wireless Card will not fit in slot
First, make sure that the type of card that you bought is compatible with the slot. Your presario can use Type I or II standard PC or PCMCIA cards. If the linksys adapter that you bought is not a PC/PCMCIA card, rather an ExpressCard, it really won't fit.
Jan 01, 2009 | HP Compaq Presario 2200 Notebook
Can i use a usb adaptor on the c700
Your laptop should have a built in network card and 10baseT network port, if your laptop does not have a built in network card you can use either a PCMCIA network card or a USB network adapter. Your desktop computer may not have a network card, you will need to purchase a network card and install the drivers.
To connect the two computers together you only need a cross over cable. If you use a hub you can connect two or more computers together using standard 10baseT network cables.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Network cable wire too large to fit laptop connection
If your laptop is too old probably does not have a network card built in. In that case you need a PCMCIA network card and PCMCIA slot available in your computer.
You can get one here:
http://cgi.ebay.com/LAPTOP-PCMCIA-Network-Card-10-100-Ideal-for-Old-Laptop_W0QQitemZ280106314967QQihZ018QQcategoryZ45000QQcmdZViewItemQQ_trksidZp1742.m153.l1262
Thank you for using FIXYA!
Dont forget to rate my help!
Have a great day!
Pablo :-)
Oct 18, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
