Question about HP Photosmart 3310 Printer
FAX: INcalls: how to increase the "rings to answer" number
Configuration limits are 2 - 3 - 4 - 5 rings. I need more.
  • 3 Answers
Sorry, but that is the limit for the rings to answer function of the HP all-in-one devices. some people are complaining that this does leave them with few rings to grab the phone before the answering machine picks up, as the answering machine must have at least two lower values than the HP all-in-one.
Posted on Mar 07, 2008
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
Number of rings to answer fax?
have an HPOfficejet 6500A Plus and the ax number of rings is preset at 2 rings before answer.
How can I Increase the number of rings?
Nov 05, 2010 | HP Officejet J5780 All-In-One InkJet...
How do I increase the number of rings on my Brother MFC-780n fax/printer before it picks up?
Setting the Ring Delay
The Ring Delay sets the number of times the
MFC rings before it answers in Fax Only or
Fax/Tel mode. If you have extension
phones on the same line as the MFC or
subscribe to the telephone company’s
Distinctive Ring service, keep the Ring Delay
setting of 4.
(See Operation from extension telephones on
page A-4 and Easy Receive on page 4-3.)
1 If it is not illuminated in green, press
(Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many times
the line rings before the MFC answers
(00 - 04).
Press Menu/Set.
(If you select 00, the line won’t ring at
all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2010 | Brother MFC-7820N All-In-One Laser Printer
Number of rings
Press MENU, then enter #06, then press the number of rings before the fax picks up by pressing 1,2,3, or 4 (4 being the maximum number of rings)
Press SET, then press MENU again to exit. Best of luck!
Greg
May 21, 2009 | Panasonic KX-FPG376 Plain Paper Thermal...
Press
function
64
set
look at the printout
look for number of rings
to set the parameter
press
function 74
set
Feb 07, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
the default setting is 5 rings. if you need to change that:
set the ring to answer to higher number, however, that will put the machine in manual answering of fax.
the better setting is to rest the phone or the answer machine to a lower number of rings.
Jan 13, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
I have a discontinued phone and have lost the instruction book and need to figure out why the fax machine is not letting the answering machine pick up.
you have both the fax machine and the answering machine on the same phone line.
The fax machine and the answering machine are set to answer in a certain number of rings.
In your case the fax machine is set to answer the line in less rings than the answering machine. You have to increase the number of rings of your fax so that the answering machine will work.
Aug 06, 2008 | Lands Phones
HP Photosmart 3310 Printer Logo
142 people viewed this question
Ben Johnson
