Question about Onkyo HTR500 Receiver
Reciever shutting off
I have an onkyo htr500. When I power it on it makes a clicking sound and then shuts off after 4-5 seconds. I have checked the fuses and they are fine. I have tried to plug and unplug it and the speakers but nothing simple seems to help. Can you help?
  • Gabe Apr 08, 2008
    I have an HT-R510 receiver, that started to suddenly turn off and go to standby after about 20-30 minutes when I installed a new HDTV. I can hear music for 2-3 hrs w/ no problem, but it only shuts off when the TV is on.
    I turn the receiver back on and it will play for another :30-:40 and shut off. The receiver does not get hot.
    I do however, have speakers spliced with another. Would this be case and if so why wont it do it when the tuner is on with the HDTV OFF.
    Please help!!!
  • Anonymous Apr 12, 2008
    my receiver will not staqy on
To: "mrlong86"
This idicates problem with output circuitry. Have unit checked out by pro/tech
To: "flyhigabe"
You indicate you have speaker spliced in with another(?)
This changes the impedence which may be too low for amp to handle. It may cause amp to shut down to stanby.
Posted on Apr 27, 2008
I'm having the same issue
Posted on Feb 09, 2008
Has anyone found a solution for this problem? My unit starting clicking off to standby once in a while and now does it all the time.
Posted on Feb 05, 2008
Jvc reciever turns on and then shuts off with overload
disconnect all speakers and inputs and try again. If it stays on, you have a short in one of the connections. Try adding them one at a time and see if it shuts off.
If it overloads with nothing connected, you have an internal problem.
Jan 16, 2013 | Onkyo HTR500 Receiver
Reciever shuts off
Hi there
May I ask how many watts can your reciever handle ? And how many watts does your speakers need in order to be powered up (input). The two speakers you have installed might be too powerful for your reciever to handle. You might have to down grade to less powered speakers. All in all you have an excellent product there good choice...
May 11, 2009 | Onkyo HTR500 Receiver
After turning in my receiver, it immediately turns back off.
Sounds like it's going in to safe mode. This can be caused by a number of things but the first thing to look at is a failed output amp.
May 03, 2009 | Onkyo HTR500 Receiver
Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Apr 21, 2009 | Onkyo HTR500 Receiver
The reciever just shuts down
The manual suggests disconnecting inputs and outputs and power, letting it sit for an hour, then plugging it back in and turning volume to max to see if it still shuts off. If it does, the problem is with the unit. If it doesn't, the problem is elsewhere.
Judging from some other sites, this is a common problem. If you take it to a dealer, suggest they check the AC input. Before anything else, make sure that there are no stray wires on your speakers connecting the positive and negative clips, which will cause a short and activate the amp protection.
I had the same problem with an Onky502 and replaced it today with an Onkyo606. It worked fine for an hour then started shutting off automatically. I'm following the manual and letting it cool off now for an hour, and meantime I'll check my speakers.
Dec 30, 2008 | Onkyo TX-DS777
Losing memory settings
On remote control before you shut off yor receiver press "TEST" button to save the memory. It will save every setting. Make sure to do that all the time after you change the setings.
Nov 23, 2008 | Onkyo HTR500 Receiver
www.eserviceinfo.com/downloadsm/28790/Onkyo_HT-R500.html
Jun 03, 2008 | Onkyo HTR500 Receiver
Onkyo HT-R500
Unit has circuitry problems, take in for service
Mar 14, 2008 | Onkyo HTR500 Receiver
Amplifier protection circuitry
more than likely blown amp transistors on 1 or more channels. use an ohm meter to check resistance of the transistors.
Nov 14, 2007 | Onkyo HTR500 Receiver
Onkyo HTR500 Receiver Logo
308 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
