Question about Epson C64 InkJet Printer
Return address label stuck on rollers
Need to take this apart to get to the rollers but dont see any screws to do so?
  • 749 Answers
Wow... That's tough... there are hooks to be pushed via under the printer are located on the sides, use a flat screw driver to reach and release those... That's the start...
Goodluck man... I wish, I'm there to help... Fixya...
Posted on Feb 02, 2008
I cannot retrieve FABRIC from inside machine. I was printing labels and now one is rolled around the roller inside.
About 1,350,000 results (0.86 seconds) Search Results
    [PDF]How To remove a stuck label from the LabelWriter? 1. the ...
    global.dymo.com/.../cRydqiFncuah2s6Pf5DxrozTFs...
    DYMO Corporation1. the labelwriter. 2. ... The cover is now completely removed. 7. lift up the innerguidance ... Make sure the rubber transport roller ... under the stuck labels with the cutter ... the front is completely in place. 31. Your LabelWriter is now ready to print.
    [PDF]Instructions & Troubleshooting - Pelikan Artline
    www.pelikanartline.co.nz/images/.../5InstructionsTroubleshooting.pdf
    Page 1 ... E Labels. F Platen Release Knob. G Ink Roller Loading Catch. H PrintHead. I String. Lift off the ... Determine whether the label roll is the ... on the roller inside the label ... Label Loading is now complete ... Index Bands all around.
    [PDF]Label Path Diagram - Primera
Jan 18, 2016 | Office Equipment & Supplies
Will not go forward
Probably the gears or other parts are jammed with the plastic and sticky substance.
Make sure it is unplugged. Then see how to take some of the unit apart. Many of these kinds of units will be held together by screws in deep indentations. You will need a screwdrive of the type of the screw-head. Remove the screws and then you can split the unit apart and see what the problem is.
More than likely, it will be a matter of removing the sticky plastic jammed into the unit between the gears and or the rollers or other parts.
Jul 26, 2008 | Aurora Global AS702MX Shredder
I have a label stuck in a Brother QL650TD
You will have to take off whatever component you can to get to the label and pull it out. Make sure to clean off the roller it is stuck on or you will get stuck again.
Oct 05, 2012 | Brother P-touch Ql-650td Thermal Label...
STUCK LABEL IN THE P-TOUCH QL-500 LABEL MAKER, This is now the third printer I have purchased and replaced because of stuck labels on the rubber roller, this is a great printer until this happens. Any...
I downloaded service manual
You need to remove the top cover
Remove the curved cover 1st , has 2 plastic pins to press inwards
Lift the curved cover upwards
Remove the darkcover beneath the labels
At the back 5x self tapping screws
At the from 2x machine screws, left hand one is under a label
Prise off the cover by inserting a screwdriver at the back edge
Voila
Remove the stuck label
Reassemble
Apr 01, 2011 | Office Equipment & Supplies
How do I take apart my Brother typewriter to remove a label stuck to the metal bar where the paper feeds in?
I wish I had one in front of me, but I don't. Brother used two ways of holding the Platen (big black roller in place. Open the top cover and look at the frame where the platen is held. You will likely see plastic clips holding the axial that runs through the platen (85% of brother machines have clips), or you will see that the axial runs directly through the frame. If you see clips just squeeze the tabs and lift up. Note which side has the gear, so that it is reinstalled the same way. If you don't have clips you will need to loosen the Allen screws holding the knob to the platen roller, and the roller will lift right out. If the label left any of the rollers sticky they must be completely cleaned before reassembly, Goo-Gone is a good product to remove gummy labels.
Best of luck, Ron
Jan 06, 2011 | Brother ML-100 Typewriter
Paper jam, unable to remove paper that is stuck
how do you get to the roller because you need a special screwdriver to undo the screws in order to get to the roller
Oct 16, 2008 | Office Equipment & Supplies
Easy peel Labels stuck to rollers cant print
On which roller are these labels stuck? On the drum roller? or at the back in the fuser.
If it is the drum you can always try with a soft cloth and some denatured alcohol.
Soak the label first with alcohol to loosen the glue, then remove the label and take a new
clean cloth to remove the glue with alcohol. Notice that the drum is light sensitive, don't expose it to bright light for too long.
If it is in the fuser you'll have a bigger problem. You'll have to remove the fuser first to access the rollers (caution, let it cool down first, fusers get really hot)
You need to remove the duplex unit (if available) or duplex cover and the 2 small side covers.
In the left and right you will notice 2 screws that tighten the fuser. Remove these screws as well as the dataconnector on the right and the fuser lamp power supply to the left.
Now you can easily slide the fuser out.
The tricky part is to open the fuser up to access both heat- and pressure-roller to clean them in the same way you should clean the drum unit. Normally you can open the top cap of the fuser loosening 2 screws don't know exactly which ones
When this is done you can reassemble the printer and all should work fine.
If you intend to open up the fuser, let me know, i'll get you the detailed information for that.
Notice:
when you use lables that are suitable for laserprinters always use the manual front feed and open the rear cover, that way the paper does not get folded, it just runs flat right through the printer.
Oct 13, 2008 | Brother HL 5170DN Laser Printer
DYMO DUO LABELWRITER
The labels have a 2 yr warranty, so contact Dymo customer support and if they can't help you return the printer to the retailer you purchased from for a new printer. The Dymo LabelWriter DUO is an expensive printer that Dymo stands behind.
Feb 16, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Printing return address on #10 24lb regular envelope
Are you free hand addressing or are you using "Word - envelopes and labels" tool. It should be goof free. If you are, check the pull down rollers on that end of the printer for damage or contamination. When you lift up the cover like you're installing a new cartridge, you should see the black rollers. Clean them with a q-tip and alcohol, wiping across while rolling it with your finger. If you're not using Word, pull down the tools tab and select letters and mailings, then envelopes and labels.
Jun 29, 2007 | HP PSC 1510 All-In-One InkJet Printer
Epson C64 InkJet Printer Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
