Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Freezer not working
Woke up this morning everything in freezer is thawed. Fan is blowing, notice a periodic ticking sound coming from freon unit. any quick suggestions?
  • 1 more comment
  • Anonymous Feb 02, 2008
    i also woke up this morning and the freezer was not working
  • pdidy Feb 03, 2008
    I have the same problem with our 10 year old Kenmore. The fridge is good, but everything in the freezer is melted this morning any suggestions please
  • louis65 Feb 03, 2008
    got back from work today. freezer items were thawed, fridge not cooling either, also a ticking sound coming from compressor. fan on bottom back is running. is there another fan for the freezer or a compressor reset switch?
    Problem Solver:
  • 4 Answers
Sounds like a defrost timer problem.
Posted on Apr 04, 2008
Why are my fridge and freezer to warm?
Sounds to me like your freon is low. That is the gas fridges use to cool things down.
I may be wrong but I would get a repair man to check the freon pressure first.. Low freon is caused by a small leak in one of the lines or in the compressor its self. I had an old fridge and the freon went low just over time.and had to be topped up.
Jan 13, 2015 | GE Refrigerators
Maytag MTF1895AEW Not Cooling
Sounds to me the compressor start relay=> 63001003 Overload=> 63001004 and Run Capacitor=> 63001005
needs replaced, the clicking noise indicates that that is the problem, Sea Breeze
Feb 16, 2012 | Maytag Refrigerators
Freezer has had ice film on bottom for some time, leaks down into the frig, unit began making a periodic clicking noise last night, woke up this morning to defrosted food in freezer. Cleaned coils,...
Just by cleaning the coils and the keeping it shutdown should not have any effect on the freon in the compressor. It is only used to cool down the coils so that the air blows over them is also made cold. Please keep it running for a while and check if the problem persists. There is a chance that the air is first cooling down the ducts in the refrigerator and then afterwards the whole inner body. That can warm down the air a bit. If the problem persists, this can be a freon issue.
Apr 02, 2011 | Refrigerators
Frezzer not Keeping things Forzen. I turned up the adjustment, and left it over night to adjust to new Temperature setting. I woke this morning to find everything almost completely Thawed. Fridge seems to...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Mar 18, 2011 | Refrigerators
I woke up this morning to the fridge not working. Everything in the freezer is starting to thaw. Checked the outlet and it still works, what could be the problem?
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Feb 13, 2011 | Refrigerators
Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on, but the rest seemed OK. Today noticed a puddle from thawed meat. Sounds like...
I believe you freezer has sprung a Freon leak. You described it and if it changes levels is a way of measuring what Freon you have remaining. Sometimes they can be repaired it depends on how they were built. Hope you did not loose much food, Sea Breeze
Mar 21, 2010 | Frigidaire Freezers
Fridge/freezer running, but not blowing cold air
sounds like compressor has failed remove the fridge and put your hand on the black unit at the back (compressor) it should be quite warm if running if not its not starting compressor are at there most stress when starting up and if failing this defrost may have killed it completely
Nov 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
The Freezer and Refrigerator has stopped working completely
first check to see if the compressor and fan on the lower back of frig is working,if it is then check the freezer to see if the freezer fan is working,if it is then find the defrost timer(most of the time behind the front grill or inside frig. or on lower back)turn it til it clicks,wait 30 minutes and see if it comes out of defrost(you k=will know this if the freezer fan comes back on,let me know what you find-mike
Apr 16, 2009 | Refrigerators
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
139 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
