Question about E-Machines eMachines Desktop PC
Network drives i need 2 download network drives for my emachines 4210!!! i have a modem which works but cant connect to the internet until i install network drives! please help
  • 537 Answers
Ask a friend to download them for you and put them on a floppy or USB stick. Otherwise you are stuck.
Posted on Feb 02, 2008
Can not connect to internet
Cheeck all usb or ethernet leads and connections make sure they are not faulty with secure dust free connections to modem or router.
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver or you could download one
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Nov 15, 2013 | E-Machines eMachines Desktop PC
I accidently delated my network drive and now cant access internet,on my desktop pc, can anyone help with the drivers that I need to install as I have no idea
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc
http://download.cnet.com/realtek-rtl-gigabit-and/3000-2112_4-10278840.html http://download.cnet.com/realtek-rtl8139-family-pci/3000-2112_4-91313.html http://download.cnet.com/3dp-net/3000-2112_4-10915115.html If these driver packages aren't right http://download.cnet.com/2000-20_4.html Tick in either the all software or windows software box on the home page you should see a search tab just type in what you are looking for you might have to search/try a few times to get it right IE: Motherboard name Ethernet drivers or lan drivers Hope this helps.
Jan 13, 2013 | E-Machines eMachines Desktop PC
Windows vista crashed. changed bios to load xp. worked. old files on hidden drive. problem is cant connect to internet. driver files on hidden drive. Now what? Try to find driver and load it?
your explanation is very confusing. your internet connection must come from a modem either directly or remotely thru router. your mentioning of hidden drive does not make sense. drivers are not part of internet connection. you need to reset the modem and router if you are connecting through it. turn everything off. unplug router and modem. after 15 seconds unplugged, plug only modem in, wait until lights stablize; now plug router power back in, wait for lights to come on;,next turn PC on. Wait until completely booted up. go to control panel click on Network Internet, when opens try to find the local connect to network. if none, then your modem is not receiving signal or IP Address from your internet provider(comcast,centurylink, whoever). check status, if active fine. if active but icon says no internet access then your router is not set correctly. you may have lost its set up and you will have to reset up your router. you should have the step or instructions for doing that. after resetting and network active, restart computer so that is receives fresh settings from router.
if no network is found after restart you may have to reconfigure your internet connect by using the internet connection wizard(control panel).
Sep 27, 2012 | Dell Dimension B110 PC Desktop
I just cannot get on keep saying no network for two days now
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers if you cant find the driver hopefully one of these will help you
http://alpha.majorgeeks.com/Intel_Network_Adapter_Driver_for_Windows_7_d6273.html
http://majorgeeks.com/SiS191_Gigabit_LAN_&_SiS190_LAN_Driver_d5923.html
http://majorgeeks.com/IntelR_PROWireless_LAN_2100_Network_Connection_d4598.html Latest
http://majorgeeks.com/downloadget.php?id=5240&file=15&evp=5fbb1c6e47482358c61a5236fb38a112
VIA LAN Driver. If you don't have or cant find your land driver hope one of these will help you
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109025.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-pro-100-m/3000-2112_4-109029.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109002.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109004.html
hope this helps
Jun 24, 2011 | CMS (DELLX200200) 20 GB Hard Drive
Emachines EL1850 internet connection problem, brand new out of the box computer will not connect to the internet. Its not the modem or an internet problem, as i'm using the internet and modem to write...
hi,
other computers are working fine in your modem?in that case you need to check if your pc can detect the modem,or you can check if the ethernet driver (for LAN connection) and/or wireless driver (for wifi) are installed correctly...you can check that in the device manager if the drivers are properly installed
if Windows 7 - click start ; on the start search area, type device and the look for device manager
look for network adapters and you will see there you lan and/or wireless adapter
Thanx
Jan 05, 2011 | E-Machines eMachines Desktop PC
2004 Emachine- when desktop comes up on lower right there's a flashing icon when clicked on says "Network Connections", Local Area Connection, Network Cable Unplugged, Intel{R} PRO/100 VE...
If the local area connection icon specifies as network cable unplugged, then the computer has not sensed the connection between the computer to the cable modem / DSL modem, please reseat the cable behind the cable / dsl modem to the computer. If the icon still shows unplugged, then change the network cable between the two.
If the issue still persists, please revert with more details lik the kind of internet connection used and the reason for reinstalling.
Jan 04, 2011 | E-Machines eMachines Desktop PC
Start up and Signal problems. need to download WGT624 set up
.chk files are normally those produced by the system after a hard drive repair or some such, and shows lost clusters on your drive.
Your Broadband modem feeds the router (your problem device), which in turn connects to the computer's Network Card, the one with the RJ45 connector. The smaller connector goes to your modem, for use with Dial-up signals, not broadband. Cable modem feeds router, router routs signals to various computers, via RJ45 cables. Your router is probably for 802.11g signals, used by the majority of networked computers. The 311 in your computer plugs in to the 624 router. They work together to get you on the Internet.
Nov 07, 2009 | NetGear WGT624 Wireless Router
Driver downloads
You need to go to:
control panel
-system
-hardware
-device manager
-network drivers
if there is an exclamation mark within a yellow sign .. this means your driver is not installed and your network card will not work untill you get the driver installed which will identify to your motherboard that the device is network card.
I would suggest going to google and search the motherboard model number for drivers and go to the e-machines website or actual manufactuer website for genuine drivers then install it. The device should work.
Sep 14, 2009 | ASUS P4XP-X Motherboard
I dont have ethernet drivers.
Ok download drivers for vista then extract and find folder VISTAx86 open and right click net8185.inf and choose install option, if not install and have problem post coment rere, "dont work" ang find for xp, link here for official
Aug 07, 2009 | E-Machines T6420 PC Desktop
I need all drivers for emachines t2824 no internet or sound
I just checked emachines website and here is a link to the driver page for this machine and XP drivers
Feb 25, 2009 | Computers & Internet
E-Machines eMachines Desktop PC Logo
76 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
