Question about Creative Labs ZEN Vision:M Digital Media Player
Will not rebuild
My Vision M got suck and after pressing the reset button. it went onto the normal REBUILDING process, but after loading halfway through. it gets stuck and does not go any futher.. No matter how long i wait for it.. I cannot connect the vision M to the computer as i am visiting my parents... Any one got any solutions ...
cheers
  • yas666eer Feb 04, 2008
    thanks will do that whenever i get the chance....
My solution is to wait until you can connect it back to your computer. When you do, post what happens and I'll get back to you, because it can be a number of problems (I own one of these)
Posted on Feb 03, 2008
I WAS LOADING MUSIC , THEN WHEN I FISHED I GOT STUCK ON REBUILDING, I'VE RESET IT SEVERAL TIMES BUT IT GOES BACK TO BEING STUCK ON REBUILDING
if your unit is still under warranty, let them check your unit for you to be able to find out what really the problem is?
Sep 14, 2010 | Creative Labs ZEN Vision:M Digital Media...
My Zen M 30g keeps rebuilding....tried to reset but it won't work...I put the pin in the reset hole and it won't do anything til I pull the pin out then it comes on but is rebuilding???? Help please!!!
Hello.
Welcome to Fixya's Community.
Your Mp3 Player is Having Problem with the Firmware(Corrupted) Now you need to Upgrade it Firmware, in order to solve this problem Please follow these Steps:
  • To install this firmware
    1. Download the file into your local hard disk.( check out the link below)
    2. Close all application windows that are currently running on your computer.
    3. Connect your player to your computer.
    4. Double-click the downloaded file and follow the instructions on the screen.
  • When your player restarts after installing this firmware, the following will occur for the first time only:
    • The Rebuilding Library screen will appear.
    • Photos may take slightly longer than normal to appear.
  • This firmware supports the playback of Audible Type 2 and 4 tracks.
  • Important: to transfer Audible content, you must have AudibleManager version 5 or later installed. AudibleManager allows you to download, burn, organize, transfer and listen to Audible audio content.
Downloads:
The Firmware updater.
AudibleManager
Additional Help:
Creative Zen M 30Gb Manual Guide.
Thank you for Using Fixya.
Please let me Know if you need any further Info.
Good Luck.
Nov 09, 2009 | Creative Labs ZEN Vision:M Digital Media...
Freezes on the 'Rebuilding...' screen.
The same thing happened too me about six months ago after about a year and a half of using my zen with min. problems. It would freeze on 'Rebuilding..' and then there was an endless cycle of reset but eventually it would Rebuild completely and all my music and information was fine. It seemed to be playing fine but if it froze I had to start the reset game all over again. Then the real problems started. There are a few load screens before you make it to the Rebuild and it started to freeze on that instead after awhile. I was actually revealed when I froze on 'rebuilding..' and made it that far.
If you can get it into recover mode and reboot it seems to have less problems freezing but that doesn't even work for me anymore. Then occasionally when it freezes it starts to vibrate terribly and make a horrible sound. Then it stops and flashes hard disk problems.
This all happened slowly too me. It really wasn't worth the time I put into it trying to fix it. My advice is to work on getting a new MP3 player. If you can get it past the 'rebuilding..' your going to have to play the reset game every time it freeze and it will probably freeze more often.
Aug 21, 2009 | Creative Labs ZEN Vision:M Digital Media...
My creative media player stock to rebuilding
First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
May 29, 2009 | Creative Labs Zen Digital Media Player
Firmware Problem?
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
May 03, 2009 | Creative Labs ZEN Vision:M Digital Media...
Stuck on "rebuilding" screen
This should help you right here: Detach the player from the PC and turn the unit off. Then slide the power switch towards the power icon and hold the switch. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove. Release the power button when the recovery mode appears. Select format (all) and select yes to format the player. After the player has finished formatting, select reboot. Then retransfer the tracks to the player as doing the format will erase the whole player.
Apr 06, 2009 | Creative Labs ZEN Vision:M Digital Media...
Rebuilds Randomly
Do the following on the Vision:M and run a cleanup. First, enter into rescue mode by detaching the Zen Vision:M player from your PC , and making sure that the unit is off.
Then, Slide the power switch towards the power icon and hold the switch in the Power On position.
Next, Push the end of a straightened paper clip into the reset hole,and press gently and remove.
The recovery mode will come up, I would choose clean up, this will not erase anything.
Also, I make sure the player is off before you shake it, as you can damage the hard drive inside if it is on when you shake it.
Mar 17, 2009 | Creative Labs ZEN Vision:M Digital Media...
Rebuilding problem
http://serviceman.site88.net/index_files/MP3Players.htm
Jun 27, 2008 | Creative Labs Zen Touch MP3 Player
Mp3 stuck in rebuilding library mode
hello guys sorry to hear your problems i have same problems too. Ok first plug ur zen player (mines V PLUS.. heheh) to ur pc then hold play button then keep pressing the reset botton until it turns on RECOVERY MODE then select YES to all (clean up, format, reload firmware) then download the RECOVRY TOOLS at creative site install it then plug ur zen player and run the recovery tools (cross ur finger) hopes it works mine a big smile hehehe email me at oracle101rage@gmail.com if it works..Gud Luck guys
May 18, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN Vision:M Digital Media Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
